Washing machine fills up but then immediately drains instead of going thru cycle
  • Washing Mach... Master
  • 5,323 Answers
I suspect the control board but u can also check the water pressure switch
Posted on Mar 30, 2015
Washing machine will agitate on spin cycle instead of spinning. All cycles work fine, fill, wash/agitate, drain, fill, rinse, drain, but anytime it should be spinning it is agitating instead. Is it the...
Could be, Try any of the online appliance parts stores, Mfg, model possibly year. There is a possibility depending on age that a "reversing switch" is not working properly or connections from or to it are bad. Or possibly the drive motor is not "accepting" the switch's instruction.
Apr 05, 2015 | Washing Machines
Washing machine starts agitating before fill
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Jan 12, 2014 | Maytag Washing Machines
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Kitchen sink hole fills up with water when using the washing machein
After washing cycle all the water flows immediately from tub to drain pipe. If the flow capacity of sink is slow sink hole fill up with water .
Connect washing machine drain to proper place for drainage.
Oct 05, 2013 | Washing Machines
Wahing machine will not wash
the entire agitator is not moving during the wash??? or just the top section that looks like a big plastic corkscrew???
or is the unit actually just filling with water, making the motor running noises and going thru the motions of running a cycle yet not actually moving anything within the unit, then draining out as normal??
if just the top section of the agitator is free spinning instead of ratcheting as normal you'll need to replace the agitator dogs if present.
if however the units just filling and draining of water with no inner movement then more likely the drive coupling is bad and needs replacement..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
My washer fills and runs tru the washing cycle then stops. It won't go thru any other cycles, won't spin and does not make any noise. Is it the timer?
Does it drain?? If not then you need to replace the pump. The pump drains the water hence allowing the spin cycle to engage. Sorry for the bad news.
Oct 17, 2009 | Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Fills but does not wash
Hi!
That happens when for some reason any of the two drain/spin cycles are interrupted. Try this:
have the washer empty, then set the machine to run the last cycle to the end of it, when you usually
lift the cover to take out the clothes, that ought to do it, I had the same problem when diagnosing a
timer problem.
Nov 09, 2008 | Maytag Performa PAV2200
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
