Moved it to new home, now won't start, replaced power cord. how do I reset/where is the reset button?
  • Office Equip... Master
  • 2,160 Answers
Some models of hp printers can be reset holding down power button for 10-15 seconds after all power is removed from unit, unplug from wall and unplug adapter from unit.
Posted on Mar 30, 2015
Proform elliptical 820 left sitting for months in florida room but worked fine before, batteries replaced, now the rpm's don't show and programs won't start. i have a feint memory of havin
1) replace by new batteries with the same type fulll charge, with the same mark, with the same polarity
2) clean the contacts batteries with contacts cleaner for a dirty, corrosion, etc
3) adjust the REED switch, test it, clean it, and tight any plug or connector.
4) tight the ribbon cables for keypads good connection.
Try again.
Of course you must know the power cord is o.k the c. breaker you must reset and some fuse is o.k o replace see the b.diagram
God bless you
Nov 19, 2012 | Exercise & Fitness
Soundbar will not turn on
1. Check the power cord is plugged in properly by removing it and replacing it. 2. Try a different outlet on the surge protector.3. Most surge protectors have a reset button, try resetting it.
Is the sound bar the only device plugged into the surge protector?
Oct 25, 2012 | Vizio VSB200 40" Soundbar - SRS...
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
Ran over power cord and now won't start with new cord.
did the breaker on the plug your using trip?do you have a gfi outlet that tripped?
Jul 01, 2012 | Garden
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
What is wrong with new home overlock serger when motor is slugish or won't move.
there is something wrong with the machine, the feed dogs are what move the fabric, it could be many different thing, the motor, some part is worn or loose or broken, power cord, it needs to be serviced
Feb 27, 2012 | Sewing Machines
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
Looks like dead. when powering on, control panel shows "self test" and then nothing shows up on the panel and printer is dead.
Try to reset the memory on your HP Officejet. Do the following:
  • Turn off the power to the HP Officejet and unplug the power cord.
  • Hold down the "# + 9" button.
  • Reconnect the power cord and continue holding the button for another five seconds.
  • Turn the HP Officejet on, and the memory should be reset.
If this won't work, you can try to upgrade the firmware but you can only do this if the printer is still detected by the Computer. You can check control panel and see if the printer is listed as "online" or "ready".
If the above steps won't work. Your printer is deem defective and needs to be replaced. You can try calling HP support for more info. Here's their US number: 1-800-474-6836
Hope this helps.
Jul 07, 2011 | HP Officejet 5510 All-In-One Thermal...
Refrigerator will not work
no such reset button that im aware off id check for the obvious power in, thermo on, perhaps a wire off the rear panel somewhere
Nov 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
k24674
