Question about Hardware & Accessories
My switch didn't come with instructions on how to set the timer? Where do I get them?
  • 5,089 Answers
HOW TO SET TIME AND DAYS SWITCHES
Copy following link for instructions setting analog timers:
http://waterheatertimer.org/How-to-set-timers.html
CU750 appears to be Mr Steam with 30 minute digital timer, or 30 minute spring-wound mechanical timer.
Copy links following links to download Instruction manuals for these timers:
CU 99216DIG timer manual:
http://waterheatertimer.org/pdf/Diehl-652-Operating-micro-II.pdf
CU 99216B timer manual:
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Apr 22, 2012 | Hardware & Accessories
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 21, 2011 | Kenmore Dryers
I bought a Major Tech Mtd9 programmable timer but there are no instructions included, only features. I have no idea how to set the date and the timer. Say I want the light to switch on at 6PM and switch...
First press reset (use pen or paperclip). Press MOVE button until you get OFF at right bottom of screen, then press SELECT to select mode (to set time and date, to select on/off for the 2 timers or to select rundown timer. Use OK to move to different setting, eg. hour,minute, year,month day etc. Use SELECT to change up one digit at a time. Play around with buttons to change settings, for example to have timer on on a specific day of the week or everyday etc. When it is set, use move to change from OFF to AUTO, timer will then switch on and off at set times. Hope it helps
Jul 31, 2011 | Kitchen Appliances - Others
I have installed a new adjustable thermostat unit (E1-BCANRT1W). Temp is set at 91 deg and I am using the timer. Two time periods are set and the switch is set to timer (not ON). The unit comes on at...
Double check your slide switch.
For timer: set switch to TIMER
For thermostat: set switch to ON
If slide switch does not operate, then Autocirc may be defective
Laing (800) 554-6853
http://waterheatertimer.org/pdf/Laing-E1-E3-E10-install-instructions.pdf
http://waterheatertimer.org/pdf/Auto-circ-manual.pdf
http://waterheatertimer.org/Water-heater-recirculation-system.html
1) Household AC wiring will not affect the timer.
You can check your outlet using cheap circuit analyzer from home center.
The clock rotates one direction and the pins push small lever down which turns motor on-off.
When the OFF pins pass, the small lever snaps back and the motor turns ON.
I cannot immediately find operation manual for the E-1 model.
Typical ACT303 auto circ manual says following:
2) If timer controlled operation is desired, set timer and move slide switch to TIMER:
Manual says: tabs/pins are outward for ON times.
Another sentence says UPWARD, so I don't know which way the pins are set for sure.
So if you want timer ON for 2 hours, you would set 4 consecutive pins outward or upward.
ON for 6 hours, set 12 consecutive pins outward or upward.
If the timer turns ON in reverse of instructions, then set the pins that way.
Autocirc does not make the timer, they buy timer modules from clock-makers like Grasslin, Intermatic, etc.
3) To operate Autocir thermostatically without the timer, slide switch to ON position.
The clock dial will continue rotating
Apr 14, 2011 | Laing Thermotech Autocirc Undersink...
Can't set timer
You posted under Grasslin in-wall mechanical timer.
Instructions for this timer are nearly identical to GE
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
First, the timer has to be wired correctly, so review wiring instructions shown on link above.
Next, the pins have to be set, so read instructions and look at image of pins shown on link above.
Last, the timer switch has to me set. I believe timer switch is moved all the way right for timer program to operate.
To check operation, manually rotate dial clockwise to watch lights turn on-off.
This will tell you exactly how to set pins and switch.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and pins trip a lever that opens and closes switch to your lights.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 08, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
HOW THE HELL DO YOU SET IT?
You posted under Woods 59204
If this is not your timer, add a comment
Open link below to view all Woods timers and manuals, to identify product:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Several folks have been writing in about Woods timers that don't come with instructions.
Or instructions say click switch and there is no switch.
Woods 59204 is dial-type timer has tiny segments located around edge of dial.
Segments pushed out = timer ON
Segments pushed inward = timer OFF
To set current time, rotate dial clockwise until current hour lines up with arrowhead located on inner dial.
Small switch is located in upper right, above dial.
Move switch to timer ON for timer programs to operate.
If your timer does not have switch, I suspect this could be promotional timer.
Woods sells different timers packaged under different numbers & brands.
Try timer without 'switch' and then add a comment with information to assist others with same problem.
Dec 03, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Westinghouse photoelectric switch 28KC,# E257484 outdoor timer.
Here is the manual!
The Westinghouse 28451 is the exact same timer. I found the manual online.
Enjoy!!
Nov 29, 2009 | UPM Programmable Outdoor Timer
Hardware & Accessories Logo
77 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
