Question about Kenmore Dishwashers
Dishes do not get cleaned
The dishwasher is right next to the sink, we run the hot water tap for a couple minutes before starting the dishwasher. The dishes come out dirty no matter which cycle we use. We have tried various different soaps.
  • Kenmore Master
  • 9,587 Answers
Look at the spray arm to see if any of the holes are plugged with calcium build up. Check to see if the arm pivots freely and nothing is blocking it from turning. If all these things look okay, check the filter screen at the bottom of the dish washer to see if it is partially obstructed. You may have to disassemble the filter to see inside it. If all seems ok, then look at a work water pump impeller which will reduce the pressure going to the spray arm.
Posted on Mar 29, 2015
Dishwasher not cleaning food is still on dishes
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Oct 28, 2010 | Kenmore Dishwashers
No matter what cycle the dishwasher runs, the glasses always have stuff stuck to them. have run a couple of different washer cleaners through it but no luck .heating elements are fine. any suggestions
Sep 14, 2010 | Kenmore Dishwashers
Dishes are not being cleanrd properly.,there are films on the dishes and stains
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Sep 06, 2010 | Jenn-Air 24 in. JDB1100AW Built-in...
Film left on dishes
Aug 31, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishes are not clean at end of cycle g e g l d 4300l00ww 3 years old
Aug 31, 2010 | GE Dishwashers
My dishes are not getting clean and there is a film all over everything.
Aug 31, 2010 | Maytag 24 in. MDB6657 Built-in Dishwasher
Dishes are coming out dirty, is there a filter?
No filter. Toss two cups of vinegar into the empty dishwasher and run your tap water til it is as hot as it gets. Then run your longest cycle. This will clean the machine. After that always rinse the dishes and always run the hot tap water into the sink until it is hot before you run the dishwasher. Problem solved. J.
Jun 13, 2010 | Dishwashers
Takes two and a half hours to run a load of dishes
They probably aren't running the hot water at the sink before starting the dishwasher. You know how it takes time to get hot water at the tap when you turn it on? well the new dishwashers use such little water, that they will fill with cold/warm water, and try to heat it up to 170+ degrees before continuing the cycle
Apr 04, 2010 | Dishwashers
My dishwasher is not cleaning my dishes the inside of my dishwasher is thick with white residue
hello. I can help you. Make sure your dishwasher is empty. Then pour two cups of vinegar into the dishwasher. Next run the hot water into your kitchen sink until it is as hot as it gets and start your machine. Run it on the longest and hottest cycle you have..
This will clean your machine. Repeat the process with more vinegar if you need to.
Once your machine is clean, be sure to always run your sink water until it is hot before turning on the dishwasher and also rinse your dishes. good luck with it.
Sep 13, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
81 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
