Question about Hitachi Televison & Video
Hitachi no signal - Hitachi Televison & Video
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Hitachi Master
  • 1,745 Answers
Check for input: have you occasionally switched to a different source?
Posted on Mar 30, 2015
Hitachi TV freezes aft viewing for few minutes. Can turn off n back on for few min then freezes again
before doing any thing check signal level,if it is low this can cause picture to pixlate or freese to test use a dvd player as a signal source ,if it plays fine its low signal level to tuner good luck, butler
Oct 02, 2016 | Hitachi Televison & Video
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
HITACHI L22DP04U displays no signal
Press source and select the digital/usb option, sounds like you have 'TV' selected which is analog and will just display no signal with a blue screen.
Aug 15, 2010 | Hitachi Televison & Video
When I turn my hitachi flat screen tv on,
you are not getting a signal change soure ie box or dvd player and input jack then try
Jul 26, 2010 | Hitachi 32HDT20 32 in. Plasma Television
I have a Hitachi 26LD8000TA LCD tv - does it have a built in digital tuner or do I have to get a set top box to receive the new digital channels?
The Hitachi 26LD8000TA is HD ready which means it has a digital tuner. You do not need a set top box unless you are getting your signal from a cable company that encrypts their digital signal.
Oct 09, 2009 | Hitachi 26LD8000TA 26 in. LCD TV
I have an older Hitachi 36'' Ultrvision TV. It has worked fine for years up until resently. The problem that I am having is I can not get the direct TV signal to come in. The out from the Direct TV box...
Sounds like you have something in the wrong setting that won't allow the signal to get through. If the video 1 line works OK but regular input will not work, that is almost certainly the problem. I would try just unplugging it (turning it off is not the same thing), let it reset for a few minutes; then plug it back up and see if it will reset by itself. hope this helps.
Jun 11, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
HI i have a 42" Hitachi HDTV 1080p (LCD)
Most newer Digital TV's don't display Analog signal very well. Often worse then an Analog TV. This is normal to a degree. If your Wii has component  cables, try using that. As for cable, you might get a better signal with Digital Cable.
Apr 23, 2008 | Hitachi 46F510 46" Projection HDTV
Hitachi cp-x430?
My projector is not Hitachi but I had a similar problem. My manual suggested checking under "signal" to make sure that "auto" was "on". The thing is, there were two places where "signal" came up on the menu. I had to go under "set-up" to "signal" and then I was able to correct it by setting "auto" to "on". I hope this helps.
Nov 01, 2007 | Hitachi CP-S210 Multimedia Projector
Televison & Video Logo
52 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
