Question about Hardware & Accessories
My heaters will not shut off. - Hardware & Accessories
    Top Expert:
  • 51,513 Answers
No make or model here sorry but no help either
Posted on Mar 29, 2015
WATER HEATER WAS LEAKING FROM BOTTOM OF TANK, I SHUT OFF WATER VALVE, AND SHUT OFF PILOT IS IT NECESSARY TO SHUT OFF GAS LINE GOING TO HOT WATER HEATER HAVING A NEW ONE INSTALLED TOMORROW
Yes, you have to shut off the gas going to the water heater. There should be an inline shutoff around it. Otherwise your going to be leaking a lot of gas which is very dangerous.
Apr 03, 2016 | Water Water Heaters
The heater runs constantly, the thermostat seems to work, I check continuity through it, it opens and closes. What else could cause not to shut off?
QMark MUH (0521) Compact Heater Wont shut off ... - Fixya
www.fixya.com > ... > QMark > QMark MUH (0521) Compact Heater
QMark MUH (0521) Compact Heater, wont shut off related issues. Get free help, solutions & advice from top QMark experts.
QMark MUH (0521) Compact... Repair Questions - Fixya
www.fixya.com/support/p437492-qmark_muh_0521_compact_heater
Recent QMark MUH (0521) Compact Heater questions, problems & answers. ...thermostat on and contactor makes buzzing noise, fan dont run but its not seized it willfreewheel when you spin it ... How do I turn off my q mark wall heater there.
QMark MUH (0521) Compact Heater Shut - Questions - Fixya
Dec 01, 2015 | QMark MUH (0521) Compact Heater
Heater shuts down and message says "Fan Lockout".
Shut off the breaker to the heater and turn it back on to reset heater and clear error code.
Oct 16, 2013 | Rheem 266K to 399K BTU Swimming Pool...
2003 Alero, heater won't shut off? Fan shuts off but can't turn heater off.
Faulty heater control valve.Its located under the hood on the passenger side in front of the firewall.
Oct 29, 2012 | 2003 Oldsmobile Alero
Where is water shut off valve on Rheem Electric Water Heater?
The shut-off is not on the water heater.
The shut-off is usually located on cold water pipe that enters water heater.
See image of shut-off:
http://waterheatertimer.org/images/Low-water-pressure-2-800.jpg
If shut-off is not located on cold pipe at water heater, then turn off water to house at water meter.
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Sep 25, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Alarm comes on for no reason a couple minutes after turning it on
I have a presto heater what i did was tape the buzzer botton up. if the heater fall over the buzzer will not go off because it is taped shut. the problem is your buzzer is sticken. the heater works fine once you shut the botton shut. to eliminate the buzzer.
Dec 07, 2010 | Presto HeatDish Compact Heater
Heater shuts off , it shuts down after a minute or two looks like low flame and its blue in color i do hear a popping sound when it shut off
The heater thermostat senor for this heater could be bad or indicating a abnormal temperture shutting it down. You might want to return item if still under warranted
Nov 06, 2009 | Mr. Heater (F274825)
The heater will not ignite properly and the heater will not shut off
Judging by your pics (helpful, by the way) you have a high limit wired into your thermostat wire. Try disconnecting that wire nut connection in front of your valve and hooking the thermostat straight to the top and bottom posts on the valve (eliminating the high limit). If it runs fine, either the connection was poor or your high limit wire is pinched.
Feb 28, 2008 | Cozy (W352E) Heater
Gas wall heater
the R70ET is not a wall heater but a bullet style torpedo heater. it runs for a while then shuts down. first check that the photocell is clean. you'll need to unbolt the top cover. when pointing it make sure it "sees" the flame in its holder. if it still shuts down replace the photocell. the site www [dot] desatech [dot] com is the same place I get parts from for heaters.
Dec 03, 2007 | Reddy R70ET Utility Heater
Hardware & Accessories Logo
47 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
