After we replace convergence chips we are still having the same issue what else could it be
We chAnged the convergence on the tv but still having th same issue with the screen not lining up and when we go to fix convergences we aren't getting blue cross and red and green will only move up and down not side to side.
  • Televison & ... Master
  • 9,742 Answers
The memory that holds those settings are on a different board and may need replacing too.
Posted on Mar 29, 2015
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I bought this new 4 years and I'm deeling with green and red issues mostly on the left side
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
What part do I need to replace to fix the convergence on my TV?
There are two big black ICs mounted with aluminum heat sink, these are convergence out chips, replace it with same numbers written on it to fix your tv problem.
Let me know if you have additional question.
Thanks.
Apr 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a sony Projection TV KP46WT510 convergence issue. How can I fix it? I see fusy picture with red and bleu double picture. I tried the convergence fix in manual and it shows the issue but could not...
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Dull picture after even after i replaced the lamp
Sorry to say it but your so called Technicians don't seem to have a clue.
One person talks about adjusting the convergence which you can't on this set, besides the TV shutting off on its own have NOTHING to do with convergence.
All the answers given are the same...replace the lamp, replacing a good lamp will NOT fix the problem with this TV. I have the same set and it has the same issue.
None of your "Technicians" seem to know, they just pretend or come up with standard answers.
Apr 08, 2009 | Philips 55PL9773 55" Rear Projection...
Bowing at top and bottom, can't adjust convergence replaced IC
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 22, 2009 | Toshiba 57H81 57" Rear Projection...
My panasonic big screen screen has shadows and fuzzy picture
Your TV most likely has one or more possible problems.
  • Screen looks 3D
Dec 31, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Sony KP-53S75 Red convergence problem
  • Screen looks 3D
Sep 17, 2007 | Sony KP-53S75 53" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
