Question about Miscellaneous
We have 2 and both remotes work both cars at the same time. Is there a way to change this?
    Master:
  • 969 Answers
It depends on the make and model of the cars.
Dealer can reprogram remotes.
Posted on Jun 04, 2015
Remote key fob not working
Many autoparts stores have a tester for your FOB. Also the frequencies of the FOB are married to your cars' brain. Can't say if there is an antenna for the brain to pick up the FOB signal. There may be a Menu option similar to your attempt with turning the ignition switch eight times.
Sometimes a mechanic at a quick change oil place will change the settings on your car while trying to reset the oil change counter.
Sep 26, 2015 | 2002 Mercury Mountaineer
I have a 2003 clk 320 Mercedes benz that I can't get the keyless entry to work on I had to change the car battery about a month ago and ever sent then remote has not worked I have also changed the in the...
You can try the following steps:
1 Place your key in the car's ignition and turn the key two clicks to the "On" position for any Mercedes car.
2 Press and release the lock button on your Mercedes keyless remote.
3 Press and hold the unlock button on your remote.
4 Press the lock button on your remote five times consecutively, while the unlock button is still held, at one or two second intervals.
5 Release the two buttons and wait five seconds after pressing the lock button for the fifth time. Press either the lock or unlock button once to finish.
Nov 02, 2014 | Vemo 1998 - 2003 Mercedes-Benz CLK320...
I changed battery and now it dosnt work
You lost your program of the key module follow these instructions.
To Program a Remote for a VW
Put your good key in the ignition and turn to "ON", do not start the engine. Make sure all the remotes you want to use are present because they have to be programmed at the same time.
- Close the door and insert key #2 into the driver's side lock. Lock the door.
-Within 5 seconds of locking the door, press unlock 2 times on the new remote, key #2.
-(if this is remote #3, press unlock 3 times. if this is remote #4, press unlock 4 times).
-If there's a chirp or beep do not press it again. This means that the car has recognized the new keyless entry remote.
- Repeat with other remote or unlock the car and turn off - done.
Mar 23, 2010 | 1996 Jaguar Vanden Plas
Changed battery now remote start won't work
the remote has lost the memory and must be program . Replace the battery in the remote.
Mar 05, 2010 | 2005 Chevrolet Malibu
The remote only works some of the time. can the
it could be a weak battery or the remote itself. To change the battery you need to pry the remote apart with a screw driver where the two halves come together. Look carefully at the sloder joints inside the remote they sometimes come apart causing a poor/no connection between the battery contacts and the little circuit board inside the remote.
Nov 17, 2009 | 2005 Buick LaCrosse
Remote starter does not work after the battery change. How to reprogram it? Audiovox ID:BGAAV2TF
Turn key on and press valet button 3 times then press butoon on remote.Turn key of and thats it
Nov 14, 2009 | Car APS921 Remote Starter - Keyless Entry
'99 chevy tracker power locks work intermittently
You might thing about either taking the remote apart and cleaning the contacts. Or get a new remote of ebay (make sure to check the FCC ID and IMED ID of the back of the old remote to make sure they match the new remote)
You will also need the instruction on how to program (usually the seller on Ebay will provide these free of charge if you ask for them upfront)
Feb 08, 2009 | 1999 Chevrolet Tracker
Changed batter remote start not working
Hello, What has happened is your remote has lost its programming.. Just like with most electronics, when something is reset or powered off, or even when the battery dies ....the programming software is lost. The remote has to be reprogramed either by a dealer (suggested) or by an aftermarket outsource..Hope this helps...This could help with almost all remotes.
Nov 22, 2008 | DEI GM Immobilizer Bypass
Miscellaneous Logo
32 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
