Question about Optics
I have a model #476 ramset ans a 22 casing did not reject. How can I get it out?
A 22 shell casing is stuck in the chamber and will not eject or come out. How2 can I get this out?
  • 2,192 Answers
Try pushing it out with a cleaning rod from the muzzle
Posted on Apr 14, 2015
Anything you can tell me about Winchester Model 97 Ser# 201413. when it was made and value.
The Winchester Model 1897 evolved from the Winchester Model 1893. The Model 1897 and 1893 were both designed by John Browning. The Model 1897 is an external hammer shotgun lacking a trigger disconnector. This means that the user can hold the trigger down while cycling the shotgun and once the action is returned to battery the gun fires. The gun itself is classified as a slide action pump shotgun. It was the first truly successful pump-action shotgun produced. Throughout the time period the Model 1897 was in production, over a million of the type were produced in various grades and barrel lengths. 16-gauge guns had a standard barrel length of 28 inches, while 12-gauge guns were furnished with 30-inch length barrels. Special length barrels could be ordered in lengths as short as 20 inches, and as long as 36 inches. Along with various grades and barrel lengths, the Model 1897 came in two different chamberings. One was the 12 gauge and the other was the 16 gauge. The shells should be of the 2-¾ inch or 2-? inch model. Any shells larger are not recommended. An average Model 1897 held 5 shotgun shells in the magazine tube. After including the one shell that could be held in the chamber, the average Model 1897 held a total of 6 shotgun shells. However, this would vary from grade to grade. When working the action of the Model 1897 the forend (fore grip) is pulled back, forcing the breech bolt to the rear which extracts and then ejects the spent shell while simultaneously cocking the external hammer by pushing it to the rear. When the forend is slid forward again, the breech bolt pushes a fresh shell into the gun's chamber and locks into place. This action of sliding the forend back and forth (pumping) is why the gun is classified as a slide action (or pump) gun.
Oct 23, 2016 | Winchester Optics
Why doesn't rifle eject shells?
Extractor claw spring or claw worn out of tolerance
Shell expanded to much in chamber and sticking
Chamber throat worn and neck of case moulding to lock in case to the chamber
Jan 18, 2016 | Optics
Manual for Red Head model 823 tool concrete nailer
Ramset - Powder Actuated Tools - YouTube
? 2:28
https://www.youtube.com/watch?v=MD-yAjSPgwU
May 2, 2008 - Uploaded by New Hope Media
Short compilation from the full 15 minute Ramset Powder ActuatedTools DVD. Available ... Fastening ...
Omark 823 powder actuated 22 cal tool concr
Dec 19, 2015 | Air Tools & Compressors
This rifle has not be used much. Maybe 500 rounds. Problem is it does not eject the casing fired or unfired. It pulls it from the firing chamber but does not throw it out in every case. .
could be faulty shell casings
take it to a gunsmith and discuss the fault with him as he will be seeing this problem on a regular basis
Nov 04, 2015 | Sewing Machines
My shotgun is not ejecting the shell-
If what you are saying the empty Shell is still in the open ejection area and another is trying to push in..if so your ejected is either worn or has gunk built up around it or your chamber is dirty and causing the just fired shell to stick momentarily...try firing and eject an empty shell without another feeding in and see if it clearly and quickly ejects the empty..if not it is the ejector or dirty chamber the new steel is spring fed so it should not be the poblem ..you can try another spring and see what happens. My bet is a worn or dirty ejector..or a long shot it may be the shells expanding too much do to age damp etc try different ones..good luck..
Nov 10, 2014 | Optics
I have a early model 12 remington pump. 22 short, long and long rifle, the shells load into the barrel fine but are very tight and hard to get out after fired. why is this?
Sounds like it's actually made for 22 shorts, only, and the long and long rifle are extending past the chamber and wedging in the slightly smaller bore beyond the chamber after firing. (the casing expands slightly...)
Feb 16, 2014 | Sport & Outdoor - Others
Cast shell holder j20 ramset gun
You can try Eamset direct, but the tool is out of production for some time.
http://www.ramset.com/
Dec 15, 2012 | Tools & Hardware - Others
I have a shell stuck in my Remington Power Actuated Tool Model 476. How do I get it out? Thanks!
Is it a spent shell? If so, try gently and carefully prying it out with the tip of a pocket knife.
Aug 20, 2011 | Remington Powder Actuated To Power Load...
Screen.comI have a remington model 476 that has a shell jamed in the chamber. How can i free it
If the shell is discharged you can try using a ramrod to push it down a little bit and get it unstuck. If it hasn't discharged, be very careful. Through a little research I found that there is sometimes a problem getting it to go off, try removing all but the stuck shell (if possible) and smacking it a little harder to see if it just won't fire that one. No matter what, be very careful.
Jun 15, 2011 | Remington Garden
After 1st is fired it seems to not eject the empty casing or next round misfires. Several times it will misfire. I'm using Federal Long Rifle, High Velocity, 36 Grain Hollow Points. My email address is...
First, listing a gun problem in the Toys section is kinda confusing. 36 grain, so i assume .22 caliber. Is this by chance a P22 or P99?
Next: ejecting vs extracting. Extracting is the act of the spent brass being pulled from the chamber as the slide moves backwards. Ejecting is when the spent casing is thrown from the gun, leaving a clear path for the next round to slide into the chamber.
The most common problems with .22 pistols is that they are dirty. Hands down, and I know this from working at a range. Strip that gun down, and clean the hell out of it. If you're not comfortable, have a gunsmith do it for you. Next, check for burrs (rough edges of metal) on the extractor. Also check for burrs or rough spots on the feeding ramp into the chamber.
If everything looks good, try different ammo. I've seen all different types of ammo fired through different weapons systems, some worked and some didn't. Wolf ammo hates American rifles, its just true. .22 LR is cheap, buy a few boxes of different brands, and see what your weapon likes to fire.
If this is still giving you problems, let me know, and i'll walk you through it step by step
Mar 29, 2011 | Walthers Toys
Optics Logo
284 people viewed this question
Top Optics Experts
james laughton
james laughton
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
