Question about Samsung Televison & Video
What are the most ideal equalizer settings for my Samsung HDTV?
I want to adjust the equalizer settings to achieve the best possible sound for my tv. I want to eliminate distortion.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,745 Answers
Hm-m-m. It's all on your preferrables
Posted on Mar 30, 2015
Need to adjust speed Need to SLOW it down
Sounds like the carb needs to be adjusted. There are two set screws on the carb. One adjusts the low end and the other does the high end. I think you will have the best luck with those to achieve what you are looking for.
Dec 14, 2015 | Garden
CONTRAST ADJUSTMENT
it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels.
I am further looking into ur problem..
Goodluck..
Feb 07, 2008 | Hitachi 57F500 57" Rear Projection...
Tip
How to adjust the seat on an indoor cycle
Video of How to Adjust the Seat on your Indoor Cycle
  • This video will demonstrate how to adjust the seat on your indoor cycle properly
  • Tools needed:
    • Adjustable Wrench
  • To begin loosen the nuts on each side of the seat equal turns
    • Ideally, there should be equal portions of the clamp bolt exposed on each side
  • Once you have them loose you can adjust the seat back and forth on the mounting rails as well as adjusting the angle of the set
    • The best position for the seat is level and in the center of the mounting rails adjustment
  • Once you have the seat positioned as desired finger tighten the nuts on each side of the seat equal turns and then tighten the nuts using a wrench an equal number of turns as well
    • Again, the goal is to have equal portions of the seat clamp bolt exposed on each side
  • This is all that is required to adjust the seat on your indoor cycle.
on Jun 06, 2016 | Lemond Revmaster Revolution Trainer
Tip
Indoor Cycle Seat Adjustment
  • Tools needed:
    • Adjustable Wrench
Video of Adjusting the Seat on an Indoor Cycle
on Apr 28, 2014 | Exercise & Fitness
How do I adjust brightness level on reading page of my kindle app
Fixing the brightness of your screen is easy on the Kindle Fire, Kindle Fire HD and Kindle Paperwhite, all of which provide screen brightness controls. This feature is not available on the original Kindle, however, as the screen is not backlit.
Kindle Fire Step 1 Tap the "Quick Settings" icon in the upper right corner of your Kindle screen. The icon looks like a gear.
step 2
Select "Brightness" from the Settings menu. If you don't see it immediately, tap the "More" icon to access all of your settings options.
step 3
Use your finger to toggle the slider from left to right to increase or decrease the brightness of your screen.
Kindle Fire HD and HDX Step 1 Slide your finger downwards from the top of the screen to display the Quick Settings menu.
step 2
step 3
Toggle the slider to the left or the right to fix the screen brightness.
Kindle Paperwhite Step 1 Select the lightbulb icon on your Kindle screen. This icon is present when you're reading a book.
step 2
Move the vertical slider with your finger to achieve the ideal screen brightness.
step 3
Tap and hold the "+" sign to achieve maximum brightness. To achieve the lowest brightness possible, tap and hold the "-" sign.
Jan 05, 2014 | Samsung Galaxy Tab 8.9 WiFi 16GB Tablet
I have a L46FHD37 lcd tv how can i reset it
The Sound menu lets you adjust audio output. To access the Sound menu, press MENU on the remote, and then select Sound from the Main Menu. The following audio items can be adjusted:
Equalizer The five-band graphic equalizer lets you adjust the audio frequency settings. You can select one of the five-band Equalizer Presets or create your own personal preset.
Sound Preset Allows you to choose a specific Sound Preset. Press the right arrow to cycle through the options: Standard, Movie, Voice, Music and Personal.
Frequency Range Displays the different graphic equalizer bands set for each Sound Preset option. Choose a band and make adjustments. When you make adjustments, the Sound Preset option automatically changes to Personal. Press the left or right arrow button to select the frequency (100Hz, 300Hz, 1KHz, 3KHz, 10KHz) you want to adjust. Then use the up or down arrow button to adjust the level. When you're done adjusting the levels, press the MENU button to exit.
To view the frequency range of another Sound Preset option, press the right or left arrow until no band is selected and Frequency Range is highlighted. Then press the up arrow to highlight Sound Preset.
Sound Type Controls the way the sound comes through your speakers. The options available vary according to the input selected.
Mono (available for regular TV viewing only) Plays the sound in mono only. Use this setting when receiving broadcasts with weak stereo signals.
Stereo Splits the incoming stereo audio signal into left and right channels. Most TV programs and recorded materials have stereo audio. The word Stereo appears in the channel banner when you tune to a program that is broadcast in stereo.
Sound Mode Provides special processing through your speakers (depending on the setting you chose as your Sound Type). The available sound modes are:
Off Does not give any special sound processing.
SRS WOW Gives a surround effect with more bass. (available for models L42FHD37, L46FHD37, and L46FHD35) SRS TurSurround XT (available for models L42FHD38, L46FHD38, L52FHD38, and
L40FHD380) Dynamic Bass Improves bass output. Displays a choice list of available settings you can adjust: Off and On.
Balance Press the right or left arrow buttons to adjust how much audio is sent to the left and right speakers.
Auto Volume Level Reduces the annoying blasts in volume during commercial breaks, and also amplifies softer sounds in program material. Eliminates the need to constantly adjust the volume.
Internal Speakers Turn on or off the internal speakers. If you have a device connected to the AUDIO OUTPUT jacks on the back of the TV and you want to control the sound by the device instead, uncheck the box.
If you would like for me to send you the user manual, please send me an email to LBrown18062@hotmail.com. Put "RCA L46" as the subject and I will send it to you.
Mar 30, 2012 | RCA L46FHD2X48 46 in HDTV TV
What niles power amplifer would work effortlessly with my bose 901 speakers? i am trying to achieve a deeper bass and tonal level treble for my speakers even at a low volume levle thanks.
The 901 Active Equalizer comes with some bass and midrange adjustment for tayloring them to your environment and taste.
Your question is about personal preference, which none of us could possibly answer.
Since any amplifier worth its salt should just make the sound BIGGER without coloring it, your question is moot. What you want is NOT a quality amp. Maybe an equalizer?
Mar 21, 2010 | Bose 901 VI Main / Stereo Speaker
Samsung LN32A550 32-Inch 1080p LCD HDTV
Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!]
Samsung LE32B650T2 32-inch Widescreen Full HD 1080p
Save On "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Dec 10, 2008 | Samsung TXJ2879 28" TV
Televison & Video Logo
79 people viewed this question
Henry  Thomas
Henry Thomas
