How do I change the username and password? - Computers & Internet
How do I change my facebook username and password on my insignia 8" tablet?
Click at the top right of any Facebook page and select Settings
Click Username
Enter your new username and your password, then click Save Changes
How to change facebook username after limit 2016 100 working updated
How To Set Or Change Your Facebook Username URL
Dec 14, 2016 | Facebook Computers & Internet
How do I change the "Pass code" on my wireless Motorola surfboard modem ???
If you mean the wireless pass code or Passphrase you need to log onto your modems web page which normally sits at IP address: 192.168.100.1. In the wireless section there is the pass code update field.
Dec 30, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How do you change your wifi password
Follow the steps one by one:
1.Open a browser window.
2.Type in the IP address for the modem 192.168.0.1.
3.Type in the default Username: admin.
4.Type in the default Password: motorola.
5.Type in your new username in the Password Change Username field.
6.Type in your new password in the New Password field.
7.Re-enter your new password.
8.Retype your new username in the Current Username Password field.
9.Click Apply.
10.Write down your new password and default password for future reference.
Jan 21, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How do I remove log in username
for which operating system ????
Windows XP users
Change password
  1. Open Control Panel
  2. Double-click the Users Accounts icon
  3. Select the account you wish to change.
  4. Select the option "Change my name" to change your username or "Create a password" or "Change my password" to change your password.
Note: Windows XP Home users can only change the Administrator password through Safe Mode
Windows Vista and 7 users
Change password
  2. Click Add or remove user accounts.
  3. Click the account you wish to change.
  4. Click Change the password
Change username
  4. Click Change the account name
Windows 2000 users
Change password
Microsoft Windows 2000 users can change their username by pressing CTRL + ALT + DEL while in Windows to open the Windows Security window. From this window click the "Change Password" button
Enter your old password and the new password you wish to use.
Change username
In order to change the username of an account on Windows XP you will need to have an account with Administrator rights. If you're logged in as Administrator or have an account with Administrator rights, follow the below steps.
  2. Double-click the Users and Password icon
  3. Make sure "Users must enter a user and password to use this computer" is checked.
  4. Highlight the account you wish to change the username for and click the Properties button.
  5. Within the Properties you'll be able to change the User name.
hope this helps
Sep 25, 2011 | Computers & Internet
I want to change the username and password for afaq shamel modem. do i have to restart the modem after changing username and password. moreover, do i have to keep the modem connected with my laptop while...
You should not have to restart your modem after changing the password. Once you change that password you might be promt to enter your new password in to establish an internet connection following the password change. The preferred method to to access your modem is through your computer with the modems IP address.By default most of the afaq shamels passwords are as follows:
Default IP: 192.168.1.1
Username: Afaq_shamel
Password: stccpe_2007
Type in that IP address in any internet browser (Fire Fox, IE, etc) You should be prompt to enter in a user name and password. If the one mentioned above does not work try:
Username: admin
Password: password
I hope that this helps you along the way. let me know if there is anything else I can do to assist you.
Thank you
Jul 05, 2011 | Computers & Internet
Change user name
Please indicate the Model of the router you are referring to.
If its Cisco, first do a no username xxx password nnn command on the existing configuration. Then on the global configuration mode insert a new command with the new username and password. See example below:
#configure terminal
(config)# no username old-username password old-password
(config)# username new-username privilege 15 password new-password
(config)# exit
# wr memory
May 05, 2011 | Computers & Internet
How do I change my password
Hi to reset your password, please follow these steps --
1.  Open the internet browser of your choice.
2.  Enter 192.168.0.1 into the address bar.
3.  In the username field select admin
4.  By default the passsword is blank.  If you changed it when you previously setup your router, enter the changed password.
5.  To change the password used to login to  your router, click on Tools in the menu bar at the top of the browser screen.
6.  Under the Admin Password section, you can change the username and the password to login as an administrator.  It is suggested that you change the username and password of your router.
7.  Under the User Password section, you can change the username and password to login as a user.  Logging in as a user allows you to see the settings, however, you are not able to change any of them.
If you would like additional information, please ask.  Also, if you would like information on setting up your wireless, please post that question.
Apr 03, 2011 | D-Link DIR-615 Wireless Router
Hello where can i know my user name for DSL-2640T ? I NEED IT !! PLEASE CAN U HELP ME
Hi
There is 2 Usernames when it comes to Routers.
1st is the USERNAME and Password you use to get into the Router configurations which is the following.
Username: admin
Password: admin
The above username and password is the Factory setting and only the password can be changed by an user. SO if it was not changed the password will still be admin or you can reset the modem to reset the password back to admin.
2nd is the Username and Passsword you get from your Internet Service Provider which usually is the email address and whatever password you gave them to set your internet up
Feb 04, 2011 | D-Link AirPlus DI-524 Wireless Router
Where can I find my DI-524 Username and Password?
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Jan 03, 2011 | D-Link AirPlus DI-524 Wireless Router
Can't login to 192.168.1.1
Hi the username and password for the router has been changed while the previous configuration.If you can call your service providor they should be able to provide the same.There are other some common usernames and passwords which you can try.
username:admin
password:epicrouter
*OR*
username:admin
password:password
*OR*
username:password
password:password
*OR*
username:snowflake
password:password
*******Alternatively you can also try to reset the router to its default settings by pressing the reset button at the back of the router(however this should be the last step of action).
Apr 13, 2009 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
