Hifi keeps switching off - Audio Players & Recorders
Why is my LG mcd503 mini hifi displaying protection when turned on?
caps in the switch mode power supply replace the swollen caps and good to go.
Jan 04, 2017 | LG Audio Players & Recorders
Sony DHC FLX5D hifi system shows a red light near power on switch but won't start
You opened the case to check the fuses, do that again and look at the devices that resemble small cans. See if the are bulging, leaking or exploded.
Jan 06, 2014 | Sony Audio Players & Recorders
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
Crackling sound on my amplifier
If you have good clean, loud sound with your LP player and not with your PC, your PC is causing the noise. Most PC sound cards are not very HiFi in their sound and it is quite evident when listening to a PC via a HIFI sound. Now, you can not use the headphone outputs to your Pioneer, you must use the LINE OUT jack, set as line out in your computer. There is a signal level mismatch if you use your headphone outs, distorting your Pioneer. Try LINE OUTs or buy a HiFi rated sound card.
Feb 23, 2010 | Audio Players & Recorders
Sony midi Hifi switching itself off
These digital amps are very prone to blow if the speaker wires are shorted so Sony appear to have put in a protection system that mutes the amp when this happens. You have to unplug the amp for a minute till the light goes off, make sure no speaker wires are touching each other and then it should work ok. I found the same problem with one I bought 2nd hand.
Feb 03, 2010 | Sony Audio Players & Recorders
Error
The audio amplifier IC are damaged.
Aug 20, 2008 | Panasonic SC-AK17 Shelf System
Difficulty with recording
It sounds like you have connected the two correctly. I can only imagine that you need to check that the hifi source selector is switched to that line-in, it may be referred to as AUX. Check that the recording level control is not at zero on the hifi and if there is a volume control for line-out on the tascam. If you are able to listen to the recording on via the hifi then you are halfway there even if it doesn't get to the hifi recorder. If your hifi is a seperates system then you could try plugging the tascam in to the CD input on the amplifier.
Oct 09, 2007 | Tascam Starter Pack for 4-Track Cassette...
71 people viewed this question
 Grubhead
Grubhead
