Question about Hisense LHDN32V66AUS 32 in. LCD TV
My battery is stuck at 18% and wont charge any farther than that but the battery will decrease. why?
  • Hisense Master
  • 3,462 Answers
Think you need to buy a new one. if it is a few years old it may need replacing. Do not throw it away though, check that a new on charges fully before disposing of it. If the new battery charges to 100 percent you know what the issue is
Posted on Jun 26, 2015
I need to know what the output needs to be on the charger of an 18 volt jobmate cordless drill.
During the initial state of the charge, the charger operates in a fixed-current mode. This means that the current will be held at a constant rate until the battery is charged to a bit over 18 Volts. During this phase, the output of the charger will not be 18 Volts. This is done for safety and battery preservation; forcing 18 Volts on a battery discharged down to 15 Volts or less could cause the battery to overheat. If no battery is connected, the charge controller may hold the output low until a battery insertion is detected.
The exact behavior of the charger depends on the chemistry for which it is designed, whether Nickel-Cadmium, Nickel-Metal Hydride, or Lithium ion. If the output of a known-good battery is 18 Volts after charging, and it has normal capacity, the charger is working properly.
However, a bad cell in the battery changes things. If you run a Ni-Cd battery down too far, the weakest cell in the battery may begin to reverse charge from the current coming from the other cells. This usually causes an internal short circuit, and the cell will be stuck at 0 Volts. A battery pack with one shorted cell will read 16.7 -16.9 Volts when fully charged, and the drill will not have the peak power it should. The charger will give you a battery fault indication if it is equipped to do so.
Jul 08, 2017 | Drills
The lens is stuck
memory card slot/battery cover was opened with power on.
2) test the battery for full charge, and the same type alkaline
and the same direction.
3) Full charge batteries.
4) clean contacts batteries with c. cleaner
God bless you
Oct 17, 2012 | Nikon D70s Digital Camera
Why my acer 4741G battery can't charge until 100% and stuck until 86% charge even I have to wait for 3 hours?it's already 1 year since i buy this laptop. Need more assistance, I hope for next, my...
Typical behavior of a faulty battery, cells are not accepting full charge... If its still under warranty, you can get the battery replaced no charge, otherwise you're in to fork out over 100 USD for a new battery pack.
Aug 20, 2011 | Acer Computers & Internet
The battery wont charge to 100%.. plus, the battery capacity decreases day by day.. i dont understand cause ive charged it for 3nights wont stop.. but it not reach 100%.. the indicatior also wont change...
The battery could be faulty or the charging circuit is faulty. I suggest you return it to the supplier for repair or replacement as this netbook would still be under warranty.
If you try to repair it yourself you may void your warranty.
Jul 03, 2011 | Acer Aspire One AO532H-2527 Netbook
Battery percentage is decreasing...
If your battery is a lithium ion battery then according to the folks at Battery University:
"The worst condition is keeping a fully charged battery at elevated temperatures, which is the case with running laptop batteries. If used on main power, the battery inside a laptop will only last for 12-18 months. I must hasten to explain that the pack does not die suddenly but begins with reduced run-times"
see their website at : http://www.batteryuniversity.com/parttwo-34.htm
Hope that helps.
Lori
Mar 13, 2009 | Dell Inspiron E1505 Notebook
NINTENDO DS LITE WON'T CHARGE OR POWER ON
Each time you charge your battery, the charge capacity is decreased. After a large amount of charges, the capacity is decreased to an amount only enough to turn on a/the screen(s) for a second. Try getting a new battery.
Mar 02, 2009 | Nintendo DS Console
Ryobi 18 volt battery wont charge
no its best just to replace them
Dec 27, 2008 | Hand Tools
Amp and cap wont turn on
check fuses on AMP , fuse from battery under hood , .It should not be farther than 18 inches from battery meaning the fuse..
Dec 06, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Hisense LHDN32V66AUS 32 in. LCD TV Logo
62 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
