Question about Hoover Vacuums
Turbo head on hoover mode won't turn on....help it's my mums new vacuum I borrowed. Was some initial surging of power prior to it not working and if you wiggle it just right you can get an intermittent power surge for maybe a second.
  • Hoover Master
  • 1,468 Answers
If it comes on when wiggling the wires or connections that indicates a short in the circuit.
Posted on Mar 30, 2015
The turbo tool for pet hair on my Hoover power vac doesn't rotate. I removed the brush and cleaned but still doesn't work. Suction is fine without the tool attached.
Have you checked the drive belt on the pet head? Mine comes apart and a thin belt is driven by the propellers which in turn drive the brush head via the drive belt. To check turn propeller and see if brush head rotates if not belt missing broken / jammed
Oct 21, 2017 | Hoover Vacuums
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
Aug 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I have a new Hoover vacuum the one designed for pets...and it constantly is throwing dust out when I vacuum...I can't seem to get the hose unplugged...how do I do this?
First, complete detach the hose from the machine. Drop a small coin through the hose to ensure that's where the clog is. If the coin doesn't go through, connect wrong end of hose to the intake and turn vacuum on. This should loosen the clog and possibly clear it completely. If not use an air hose or shop vacuum exhaust to blow the clog out. Borrow one if necessary.
Check inside intake for a clog between hole and filter. If it's clear, check the tube in the power head. Because of the bend there, it's a good (bad?) spot for clogs. This can usually be cleared by using the hose with a nozzle to vacuum it out. Or try needle nose pliers to grasp and pull out.
Dec 03, 2010 | Hoover Vacuums
Hoover hu 4207/1 pet hair removal turbo brush wont revolve
Try Larryclare1's solution for a Kenmore and see if it helps. Worked wonders for both my turbo brush attachments. http://www.fixya.com/support/t1095798-kenmore_model_116_powermate_jr_stopped
Feb 27, 2010 | Vacuums
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
I have a Hoover Turbo EmPower 4600 and the roller will not turn when we turn on the vacuum. The vacuum is fairly new, and hasn't seen too much use, but now the roller won't turn, so it's not picking...
The beater belt is broken. There are 4 phillips head screws on the outside (2 on top of the base on either side of the upright, and 2 on the front edge on the underside of the base near front edge). and 4 phillips head screws on the inside (holding the guard cover over the beater bar). The belt is about $3 (part number 38528040). Take out the beater bar and put the new belt around it. Then put the other end around the metal bar and stretch the belt taut as you position the beater bar back into its channel slots. Replace the guard and top cover and you should be good to go...
Jan 23, 2010 | Hoover Vacuums
Replace belt for Hoover Windtunnel Turbo Power U4645-930 Vacuum
Great Video Repair on the Replacement of the Hoover Windtunnel Self-Propelled Upright vacuum cleaners below. If you find the video helpful please be sure to rate it by clicking on the thumbs up icon below.
Thanks for watching my video, if you have any questions about this repair is done, please feel free to request clarification below.
Chris
Dec 26, 2009 | Hoover Windtunnel Turbo Power U4645-930...
My Hoover Turbo has the power and motor works well but there is no suction power. I have taken all steps to ensure that there is no blockage in the pipes. I live in the Benoni area and would like someone...
remove the screws from the funny looking thing on the back (about 10 philips head screws) and remove the blockage from the big hose. Don;t stop working on it until you are absolutely certain there is no blockage. You may need a long screw driver and maybe another smaller vacum to help get the stuff out. I have the same machine and had the same trouble.
If you want to prove or disprove blockage as the trouble, remove the handle and listen to the motor.
Sep 21, 2009 | Hoover U5396-900 Turbo Power Vacuum
Leaking
My machine leaked badly BUT it was my own fault. There is a one-time only setup procedure where you squeeze the trigger and push the Clean-Surge button to lock a rod into place. Push the Clean-Surge button VERY HARD. There will be a loud SNAP which sounds like you broke something, but you didn't. I didn't push hard enough initially, all I got was a click which I thought was enough. My machine leaked so I called the help line. They told me to push the button harder, and sure enough, they were right. Until you get that snap, the Clean-Surge (which releases a little extra water-cleaner solution) is on all the time, hence the leaking
Sep 22, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
82 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
