Question about Samsung R Galaxy Tab 3 8. 16gb Android Tablet
The tablet is only holding a full charge for about 1 hour,how can I fix that?
    New Friend:
  • 130 Answers
Have the batery replaced
Posted on Aug 02, 2015
I have a NextBook Ares 8 Tablet. Why does it take 12+ hours to recharge?
(this is all i could find on the internet so this is not to say it will help you but try it and see what happens).........PRess the power button and the volume down button at the same time and hold until the unit restarts... it resets the charging cycle and the note will charge reasonably quick from then on... I do this on occasion when my battery seems to charge slow.
plus some people are saying get a new charger.
Dec 12, 2016 | Nextbook Tablets & eReaders
Does this unit typically have an issue with the battery holding a charge? It is approx. a year old.
It loses the charge because your device consumes a lot of power to keep the screen lit up. There is no problem with the battery other than the battery size is limited due to the size of your device.
Nov 01, 2015 | Tablets & eReaders
After fully charged battery power lasted about 20 minutes.
Since it's brand new, return it. You didn't say what type of tablet it is, but they should last for many hours on a charge.
Oct 02, 2015 | Tablets & eReaders
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
How do I boot up my Kindle tablet?
Charge Unit for 2 hours then hold start button down for up to two minutes and then release start button. Keep Kindle plugged into charger while doing this. Rich
Jan 05, 2015 | Amazon Sealed Kindle Fire, Full Color 7"...
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
Nov 17, 2014 | Tablets & eReaders
My tablet will not turn on after chargeing i have warranty on it until december 2014 how do i get it fixed?
Nov 11, 2014 | ASUS Google Nexus 7 Tablet
Why won't my new Proscan tablet charge properly?
The battery can't hold the charge. Defective.
Or the charger is defective and not outputting enough voltage.
This can be tested with a voltage tester. The charger should be outputting 5 volts.
A good purchase is an inexpensive voltage tester. Can be used for so many things.
Oct 11, 2014 | Proscan 10.1-Inch Internet Tablet,...
Once i charge the kurio the screen comes on with the smiley face and thats it
Sounds like the "frozen screen" issue. Hold the on/off button of the tablet well also pressing the Volume+. This should FIX it and unfreeze the screen.
LindaSView
Apr 04, 2014 | Techno Source Kurio Kids Tablet With...
Tablet slow to charge, won't hold charge
Hi Michelle Y, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
what is the make and OS it is running..and how long have u been having issuses..like it just started or has it been acting up over some time..
Ill follow this
Chadman
Dec 27, 2013 | Tablets & eReaders
Samsung R Galaxy Tab 3 8. 16gb Android Tablet Logo
49 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
