Question about Irons
I have an iron that u iron your clothes its an self auto series number is A2931DX and the model is 17202 I can't get it to come on.
greenspan
  • 1734 Answers
SOURCE: White deposits on soleplate and clothes
You can get it here:
Sunbeam 4211 4212 4213 4214 4215 4216 4219 4220 manual (english - espanol)
It is commercial, but better than nothing.
Posted on Sep 01, 2009
SOURCE: iron with auto shut off will not restart, why?
how can i fix an iron that comes on but won't heat
Posted on Jun 06, 2010
heatman101
  • 43501 Answers
SOURCE: Iron Shuts off Automatically when using iron.
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: I've misplaced my user manuel for my Shark iron
Here is a tip that will help you see why you are getting dirty water from your steam iron...
Cleaning a Steam Iron White Scale and Brown Water
http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown
heatman101
heatman101
  • 43501 Answers
SOURCE: Re: cleaning the iron
Here is a tip that will help you with cleaning the bottom of your iron...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
How do I clean a not self clean ,quick press s506a , not self cleaning black and decker steam iron
Most steam irons can be cleaned deposits by emptying the water and replacing with white vinegar. Let it heat up and use the iron as normal - but on cloth rags instead of clothing. The vinegar breaks down and dissolves the mineral deposits inside that are responsible for sputtering and stains. You can reduce or even eliminate these deposits from forming by using distilled water instead of tap water in the iron - otherwise - run vinegar thru it when it starts acting up. The vinegar "trick" works great on coffee makers, too.
Dec 03, 2014 | Applica Black And Decker Steam Advantage...
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
How do i stop water dripping onto my clothes
ensure that your iron temprature is high enough to generate steam. if ironing delicate cloth ensure your steam option is switched off. if your iron has a filler cap or water container ensure they are fitted securely. water dripping usually when the iron is too cold to turn it to steam or you have a leak somwhere.
May 21, 2014 | Irons
Manual for ge 169133 iron
Many GE household product manuals are available here: http://www.gehousewares.com/Product_Search.aspx . Either search by the model number or select Household and Irons in the two drop down menu and click Search. If you use the second option, look for the Auto-shut off iron. The direct link to the English version of the 169133 iron is http://www.gehousewares.com/products/200879151416862.pdf .
I hope this helps.
Jul 26, 2012 | Irons
heatman101
Mar 07, 2010 | Tefal UltraGlide Easycord FV4256 Iron
How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
opening.
TO CLEAN THE OUTSIDE SURFACES
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
ABOUT THE SELF-CLEANING SYSTEM
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
month.
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
normal.
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 03, 2009 | Black & Decker D2030 Iron
How do i use the self cleaner
Care and Cleaning
opening.
month.
normal.
to empty it.
Jun 26, 2009 | Black & Decker D2010 Iron with Auto...
Rowenta iron model 871 series b shows rust while ironing
My iron spits rust spots on my cloths and need cleaning. I lost the manual in a move. I need help.
Thanks
Shirley
Mar 18, 2008 | Black & Decker D2030 Iron
Irons Logo
60 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
