How do I fix,my tv has no sound
The sound went out just all of a sudden. The picture is okay just no Sound.
SOURCE: Vizio 42" LCD HDTV - sound went out
Same thing just happened to me contacted Vizio had me unplug the TV from the wall for about a minute and then replug and cut the TV back on and everything was fine. I have the television hooked into HDMI1.
Posted on Dec 24, 2008
stonephoenix
  • 563 Answers
SOURCE: Samsung Plasma TV have sound but no picture
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Posted on Jul 22, 2009
tvservice306
  • 458 Answers
SOURCE: lcd LG television...sound suddenly stopped. no
replaced main board
Posted on Aug 18, 2009
premtech
  • 934 Answers
SOURCE: no picture on flat panel tv. has sound
Sounds like the digital control board, 6871qch038a Lg Digital Control Module subs to 6871qch038c. But that's just a first something I would check in this unit. Replace also capacitor C19, 630V big blue square cap very common failure for no video. You might want to shop this one thee are a host of problems with this unit that would certainly get some needed attention if a qualified tech were testing it and looked up the bulletins.
Good Luck!
William Rayburn, CET
Premium Technologies
Posted on Oct 05, 2009
  • 8457 Answers
SOURCE: Sound on tv but no picture.
Replaced the LCD inverter it dead.Replaced that board u will get picture back.It usally a long board..
Posted on Jan 19, 2010
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
How do I fix a tv that turns on but has no picture or sound?
if it has no sound or picture then it must be the power supply .
Nov 22, 2015 | Televison & Video
No picture
It's obvious that the power supply failed. The most common parts in a power supply are a thermistor or a voltage rectifier, possibly even a voltage regulator. diodes or resistors can act as fuses too. A ringing sound can come from a fixed coil that isn't kept still with enough epoxy. Hope this helps.
Nov 26, 2013 | LG 50PS60 50 in. Plasma HDTV
After few minutes LCD picture went black but sound works ok
most likely the power inverter, also suspect the p/s. best to have a trained tech check it. Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Memorex MLT3221 32 in. LCD TV
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
How do I fix the sound on my Television?
what is the first problem it had or all of a sudden no sound you went in the menu and tried every thing to be set okay i'll tell ya take to tv shop sure the cost would be pretty fair okay shad
May 03, 2009 | Televison & Video
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
CAN IT BE FIX?
Sounds like a bad horizontal transistor and flyback transformer . Do you know how to unsolder and or solder ? If so you might have a chance . If no the avg. to get repaired is around $90.00 to $130.00 so shop around as some shops will charge more . The parts you could buy your self for around $30.00 to 40.00 . Good luck and if you think you could fix let me know and see if i can get you part numbers .
Mar 15, 2008 | RCA 32V524T TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Aug 04, 2007 | RCA 32V550T 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
