Question about GE Cooktops
Ge cooktop One of my burners no longer clicks to ingrate the gas. The other 3 work fine. Is this something I can fix or do I need a new cooktop. It's a pain to have to light the burner with a match.
  • GE Master
  • 2,963 Answers
Usually, any burner makes the same system "click". I'd try to light the one that does work, leave it clicking then turn on the one that doesn't click. This should be just a tempory fix. The switch that turns on the "click" is bad, possibly dirty or the wire to the clicker is bad.
Posted on Apr 11, 2015
  • 110 Answers
SOURCE: Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
Posted on May 30, 2008
SRF518
  • 232 Answers
SOURCE: The igniter on the right front burner of my GE Gas Cooktop
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Posted on Oct 17, 2009
Testimonial: "Thank you so much I followed your instructions...I think the problem was in the knob as you said...Thanks again!1"
milten1
  • 1304 Answers
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
TheMobilian
  • 8220 Answers
SOURCE: Sealed gas cooktop. Igniter keeps clicking.
I have 2 videos for you:
Burner replacement
Burner switches
Posted on Dec 19, 2009
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
How to remove glass top from GE Gas Cooktop
You are correct. You have to remove the screws. If you break them off then you will most likely have to replace the burner inlets and get new screws. I would not worry about getting underneath quite yet. You mentioned that you hear clicking which means that at least one of your burners has a working igniter. Do you have gas at the burners, and do any of them light normally?
Jan 05, 2014 | Cooktops
My GE Monogram 5-burner gas cooktop has a constant buzzing sound. The cooktop is working properly, but the buzzing is annoying.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 23, 2010 | GE Profile JGP636 Gas Cooktop
I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
Jun 15, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
30 in. JGP336 Gas Cooktop: We have a GE model # JGP933SEK2SS gas cooktop. ...
heatman101
May 18, 2010 | GE 30 in. JGP336 Gas Cooktop
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
One burner requires a match to light
had same problem. Used fine sandpaper on the little head (just above the white ceramic) that creates the spark. over the years the edges of the littel metal ring had gummed up but a 1 min sanding got it down to shinny metal and it sparked nicely.
Nov 30, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
NOT WORKING BURNER ON MY VIKING 6 BURNER COOKTOP VGSU 36IN
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
Aug 18, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Cooktops Logo
176 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
