Question about Sharp Office Equipment & Supplies
THE NAME AND MODEL OF MY COPIER IS SHARP AR-M236 MULTIFUNCTION. NOW AFTER CLEANING THE OPTICAL PARTS AND DEVELOPER SIMULATION, THE COPIER PRINT PLANE COPIER. PLS HELP. THANKS
  • Sharp Master
  • 6,161 Answers
Check the transfer and sep assy directly below the drum and or the transfer roller normally sponge looking. replace or replace the drum
Posted on Jan 30, 2016
tehnik_bdg
  • 91 Answers
SOURCE: I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Posted on Apr 16, 2009
  • 7 Answers
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Posted on Jun 10, 2009
  • 257 Answers
SOURCE: I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Posted on Dec 01, 2009
xptareq2000
  • 1447 Answers
SOURCE: sharp reset developer on ar-122en
I do not understand What is step by step help?
Focus me clearly.This machine setup code is: # interrupt C interrupt.
Posted on Dec 10, 2009
  • 35 Answers
SOURCE: sharp copier ar-m236 error h4-21
try to reset by programming...here u just do ..p * c * (p star c star ) u will go in simulation mode .then press 14 ,start .mechine will ask you yes or no ? u just press 1 for yes .and press start ...your mechine will work..if same problem prsist try to check fusing unit...dont forget to thanks to me
Posted on Feb 10, 2010
HOW CAN I IMPROVE THE QUALITY OF MY COPIER PRINT OUT? IS IT POSSIBLE TO RESET THE MACHINE IS SO HOW?
Hello Sir,
Try to clean the optical parts of your copier( scanner,mirrors,laser) and then repeat dev. adjust simulation.
PS: Please specify what type of copier you have. I can help you more than that.
Best Regards,
Mar 27, 2015 | Office Equipment & Supplies
Call for service error code u2-40 on sharp copier AR-M236
That means there is a bad CRUM chip or the developer unit isn't connecting properly.
Aug 20, 2011 | Sharp AR-235 Copier
AR M236 U9-99
U8-99 error of the target of the operation panel
requiring the intervention of the technician.
Apr 21, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have Sharp copier AR-M236 with error code:f2-04, how can i remove this error?
That error is a bad CRUM. Replace developer unit use only Sharp supplies. The chip on the developer unit doesnt match with the machine.
Aug 22, 2010 | Sharp AR-M237 Copier
Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
Mar 26, 2010 | Sharp Office Equipment & Supplies
Sharp copier ar-m236 error h4-21
Dec 28, 2009 | Sharp AR-M237 Copier
How do I print (not copy) a test page from my sharp arm160 copier to see that I dont have a scratch on my glass?
Perform the following procedure to enter the simulation mode.
"#" key, Interrupt key, "C" key, Interrupt key
enter 64 press [START] key
enter 02 and select a cassette with the cassette select key and press
the [START] key
The optical system status is ignored and a self print is made.
Nov 30, 2009 | Sharp AR-M160 Black and White Copier
I have changed a developer and so i want to run a sim of developer in the copier sharp ar-5316
Hello sir; This model machine not require developer to replace, it come with toner cartridge therefor no such simulation code.
Jun 11, 2009 | Sharp Office Equipment & Supplies
Apr 15, 2009 | Sharp AR-235 Copier
SF1118
You need to clear the developer counter. Simulation 24-6.
Jan 25, 2008 | Sharp AR-207 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
