How do I change the input to tv from cable with out a remote
cTech1
  • 66 Answers
SOURCE: cable/antenna
To change between cable and antenna on your TV,
Press Home to display the "XMB" menu.
pick "settings" on the menu
then pick "channel" on the next menu
under channel settings, select "on" for cable and "off" for antenna TV.
Your user manual is available for download and option printing at the following link :
http://129.33.22.12/release/KDL40XBR4.pdf
Posted on May 16, 2008
SOURCE: Lost TV remote while on alternate INPUT
Another expert site answered my question. Since there was no INPUT button on the TV, I need to buy an original remote.
Posted on Jul 19, 2009
SOURCE: changing channel from cable to input
Your control TV switches at the front are bad, need to replace
Posted on May 09, 2010
Baker Audio
  • 29 Answers
SOURCE: I have a Sony FWD-40LX2F tv and I cannot change
This is Something you'll have to talk to the Manufacturer about. Sounds Like it may just be plain Broken
http://esupport.sony.com/US/perl/contact-land.pl
Posted on Jan 15, 2011
gopakumarg43
  • 74482 Answers
SOURCE: inputs will not change with remote with my Harmont reomte
Hello
It will be difficult to match any other universal remote with this model Hitachi set. You have to get the original remote control to select all the functions with this TV. If your original remote control doesn't work at all, just buy a new one. You can get it from the authorised service center for Hitachi at your town. OK.
Posted on Nov 04, 2011
Remote frequency for my cable receiver seems to be the same as the remote frequency for my TV
Hi Thor!
You have to select "Cable" on the universal remote on the cable to change the channels on the cable box.
And press "TV" on that remote to change or access TV Functions.
Or use only the TV remote only to change Inputs on the TV.
Good Luck,
JP
Oct 25, 2015 | Televison & Video
Wheni push input, i get the options but no arrow i push will move down to option to play vhs
not enough info , if your trying to change the tv input , make sure you select tv on the universal remote first , you either need to keep pushing input til it moves down to your desired input , or use the arrow key to move it down to the input. some require you to hit enter or ok to select , others just wait a second , it should change. if your getting the options menu when your hitting input , then the remote is not compatible with your TV / VHS / DVD...
If you get the input to change and your successful , make sure you hit VHS in order to call a command , if its still in tv mode , your only going backwards , make sure whatever your trying to control , the remote is selected to that device ... Good Luck ..
The Cable Guy .... hope that helps !!!
Mar 12, 2015 | RCA RCR314WR Universal Remote Control For...
I cant get any of my inputs to change my kids hooked up the Xbox and now none of the inputs work for cable or DVD its just a blue screen with a no signal can anyone help me tonight please
Kindly check first if the batteries of your TV remote ( medium to change input ) are fresh. After that please check again the button on your TV remote for INPUT, SOURCE, or TV/VIDEO and it should give you input lists.
May 12, 2014 | Televison & Video
Can't get General Instruments cable box to search
if you have a cable box then you will not need to search for channels. Depending on the cables you are using to connect your TV and cable box, the input channel the TV needs to be on changes. Cycle through your available inputs by using the Input or Video Source button on your remote. Check each one for audio/video. Once you are on the right input, use your CABLE remote to change the channels. DO NOT USE THE TV REMOTE.
Jul 18, 2011 | LG Televison & Video
Techwood 42in tv model 42832 hd digtal it turned itself of,cant get no picture,but blue stand by switch still turns on and off
It sounds like your TV's display has been routed to a different INPUT than the Cable/TV input jack, like a VCR in put or an RCA input. You need to change the input back to TV from VCR or LINE1 or RCA, so on. How to do this without the original remote, you are going to have to look up the program code for the universal remote and program that remote correctly, once done, change the TV Input until you're back on cable.
Mar 29, 2011 | Televison & Video
Jul 18, 2009 | Directed 434MHZ Remote Control
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Jan 20, 2009 | LG Televison & Video
I set the INPUT to INPUT 2 but when I change channels it will not stay there. How do I lock it into place? Also, how do I set the clock on the TV? I used the menu, went to D.S.T and SET CLOCK, but at that...
your not saposed to use your tv remote to change chanels if you put it on input 2, im assuming you have a cable box, that is plugged into input 2, and if you are using the cable remote, after you put the tv on input 2, make sure you push the little cable buttom at the top of the remote befor you change the chanel
Jan 07, 2009 | Televison & Video
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
