My washer has power. The drain filter is clean. No error code. I have to manually unlock the door via the pull tab. Shut breaker swith off and then proceed to turn washer drain rinse cycle on. All seems normal while selecting green indicator light on my selection and the sound as if it's going to work is heard when I select the start button . Then no water fills .it seems all cycles will allow me to select them . But then will not fill .
  • Washing Mach... Master
  • 5,323 Answers
Check water inlet valve and house water inlet lines
Posted on Mar 30, 2015
4 Suggested Answers
  • 274 Answers
SOURCE: After selecting water level and cycle type water
Is the water valve turned on.The selenoid may need to be replaced
Posted on Jul 26, 2010
  • 1010 Answers
SOURCE: The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Posted on Mar 09, 2013
rpbuice
  • 161 Answers
SOURCE: Where do I troubleshot? Kenmore 80 Series Hvy Dty Washer. Water will not shut off filling drum on any water level. Also no selection of wash cycle will work. Only rinse and spin. It continues to fi
Ok, there is a tube running from the fill switch to the tub, as water fills the tub the air in this tube will activate the switch. If there is a hole in this tube the switch will not stop the water. I fill the tub about 1/4 full, take the tube off the switch and blow through the tube, If you hear air escaping patch the hole or replace the tube.
Posted on Oct 25, 2014
Whirlpool code F02
The F02 error code on a Whirlpool washer indicates that the control detects a long drain time. This can be caused by excessive suds in the tub, a restriction or clog in the drain system or by a number of other component failures.
If the Whirlpool washer did not drain, check for excessive suds in the tub. After the suds dissipate, you can normally run a rinse/drain and spin cycle. Causes for excessive suds include not using HE (High Efficiency) detergent or using too much detergent (even if it is HE type).
If the washer will not drain and you do not detect excessive suds, you could have a clog in the drain system. Check the drain hose and the washer drain. You may need to manually unlock the washer door and then pull the large item filter on the pump to check for a clog. To manually unlock the washer door, Always saftey
unplug the washer ,to disconnect electrical power and remove the bottom front service panel as shown in the top of the image below. Carefully reach up along the inside of the front panel and pull down on the tab that is under the door lock mechanism until it clicks. This will unlock the washer door. Open the door and manually drain the water out of the washer with a wet/dry shop vacuum. Once the washer is drained, arrange some towels to catch residual water that will drain out and remove the large item filter as shown in the image below. Check for a clog or restriction that could be preventing the washer from draining properly.
If you find no clog or restriction in the drain system, you may have a bad drain pump that needs to be replaced. A problem with the electronic control board could also prevent the washer from draining.
If the washer is draining properly but you are getting this code, you likely have a problem with the water level pressure switch or the control board.
Aug 15, 2016 | Whirlpool Washing Machines
I attched the photo below. Please tell me what's the problem with the washing machine BalayTw860
fault code indicates a problem with the washer's drain system, and you must troubleshoot the problem to determine how to fix the washer and clear the code.
F/02 error code potential causes
Check the drain hose and make sure it is not plugged or kinked
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
If the above does not correct the problem replace the pump
The F02 error code on a washer indicates that the control detects a long drain time. This can be caused by excessive suds in the tub, a restriction or clog in the drain system or by a number of other component failures.
If the washer did not drain, check for excessive suds in the tub. After the suds dissipate, you can normally run a rinse/drain and spin cycle. Causes for excessive suds include not using HE (High Efficiency) detergent or using too much detergent (even if it is HE type).
unplug the washer
If you need more help, resubmit your question with additional details and the full model number of your HE3 washer.
May 18, 2015 | Washing Machines
Why is my Kenmore Elite HE 2 flashing F 02?
The F02 error code on a Kenmore HE3 washer indicates that the control detects a long drain time. This can be caused by excessive suds in the tub, a restriction or clog in the drain system or by a number of other component failures. If the washer did not drain, check for excessive suds in the tub. After the suds dissipate, you can normally run a rinse/drain and spin cycle. Causes for excessive suds include not using HE (High Efficiency) detergent or using too much detergent (even if it is HE type). If the washer will not drain and you do not detect excessive suds, you could have a clog in the drain system. Check the drain hose and the washer drain. You may need to manually unlock the washer door and then pull the large item filter on the pump to check for a clog. To manually unlock the washer door, unplug the washer to disconnect electrical power and remove the bottom front service panel as shown in the top of the image below. Carefully reach up along the inside of the front panel and pull down on the tab that is under the door lock mechanism until it clicks. This will unlock the washer door. Open the door and manually drain the water out of the washer with a wet/dry shop vacuum. Once the washer is drained, arrange some towels to catch residual water that will drain out and remove the large item filter. Check for a clog or restriction that could be preventing the washer from draining properly. If you find no clog or restriction in the drain system, you may have a bad drain pump that needs to be replaced. A problem with the electronic control board could also prevent the washer from draining. If the washer is draining properly but you are getting this code, you likely have a problem with the water level pressure switch or the control board.
Jul 04, 2014 | Kenmore Elite 45986 Front Load Washer
Error code F 9
Hi below is the meaning of the error code and corrective actions needed. To open the door manually take the panel out from under the door and reach up to the door lock mechanism. On the door lock there is a tab, pull the tab and this will release the door. If you have any questions please feel free to ask. Mike
F/09
Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
  • Check the drain hose and make sure it is not plugged or inked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check for Drain Pump Failure
  • Check the Inlet Valve for proper shut off
  • Check the Pressure switch for proper operation
Oct 20, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Washer, Duet, 3 years old. I have had the washer stop withour being finished with the cycle. None of the controls would start it, the door was locked, and the error showed an F 21...
The F21 error code indicates a long drain time on this type of washer. The door will not unlock if the washer control detects that water is still in the tub. To manually unlock the washer door, take these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
  3. Carefully reach up through the bottom opening and pull the release tab on the bottom of the door lock assembly until it clicks. NOTE: Internal metal edges in the washer can be sharp. Protective gloves are recommended for this procedure.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open.
After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the filter out and clean it You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Here is a video to show you how it is done.
Oct 19, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Maytag maxima codes F06 and E02: Tried doing a spin/rinse/drain on an empty machine. Timer seems tpo be working but cannot hear water filling or barell spin. tried to shut off and door is now locked.
see this causes and fix it. God bless you
POWER/CANCEL press for to cancel the error codes.
First to unlock depending on model. There will be a pull tab either under the lower kick panel, behind the filter cover, or under the top panel. Pull this tab to unlock the door. Now you can remove the clothes and water. Refer to the owners manual for the location of your emergency door pull tab.
Door Switch
You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.+fuse thermal +c.breaker
Oct 16, 2012 | Maytag Maxima EcoConserve Series MHW6000X...
My Kemore washer stopped working and had a fault code of F 21 I check the large object filter and cleared it out still coming up with F21. What else do I check??
After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the large item filter out of the drain pump assembly as shown in the second image below. You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Other issues that can cause this problem include:
  • Not using HE (High Efficiency) detergent
  • Using too much regular or HE detergent
These issues can cause oversudsing in the washer. The drain pump will not able to pump out suds. Make sure that you are only using the appropriate amount of HE detergent in the washer. If you have a water softener, you may need as little as a tablespoon of HE detergent.
Apr 17, 2012 | Kenmore Washing Machines
Why does my machine blink f 21 when it starts to fill then it stops and does nothing
Feb 06, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F21 Error code flashing
Plug off the wall first. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
To manually unlock the door lock system, perform the following steps.
1. Unplug the power cord from the outlet.
2. Remove the lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately quarter inch, or until a click is heard.
5. The door may now be manually opened.
Apr 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer locks up and the door is LOCKED
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
To manually unlock the door lock system:
2. Remove the front lower kick panel.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
Apr 11, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
