Question about Spartan Technologies Spartan Sports Magnetic Rower
I'm missing the knob tightener that stabilizes the rower during operation. It wobbles. Can't find spare parts anywhere for this rower.
I bought a Bajaj discover 100 cc last month.Right from the day of purchase, the handle bar started wobbling during travelling.Also the rear part (Pillion seat) wobbles during riding of single or both...
Just bought it ... take it back. Bought if from a individual ... take it back. Wobbling is NOT good ... take it back make em fix it or get your $ back.
Dec 12, 2012 | Motorcycles
How do I take the rear view mirror off a 2005 ford territory? it has seems to have a metal pad that the mirror slides onto. my current mirror wobbles while I drive - apparently it is a common fault?? I...
There should be a small set screw on the side of the metal pad that tightens against the mirror to keep it from wobbling. It may be loose or missing. It takes a very small allen wrench to tighten the set screw. If tightening the screw doesn't stop the wobbling, you can loosen it far enough to slide the mirror up and out of the bracket. Slide the other mirror into the bracket and tighten the set screw.
Dec 22, 2010 | 2005 Ford Explorer
Where can I get the following part: Stamina 1205 Precision Rower-shock absorber
CALL US:
Call a Stamina Customer Service Representative
at 1-800-375-7520 during office hours:
Monday - Thursday
8 a.m. until 5 p.m.
Friday
8 a.m. until 3 p.m.
E-MAIL:
Send your e-mail questions and comments to:
customerservice@staminaproducts.com
Apr 24, 2010 | Life Fitness Stamina 1205 Precision Rower
Volume knob on 29 ltd classic is loose and wobbly such that the sound now cuts in and out. How can I tighten?
pull off the knob and take a look see. There is a nut in there to tighten it down. try a 3/8 deep well socket to tighten it . that should do the trick.
Sep 22, 2009 | Cobra 29 LTD CB Radio
I bought a used meade polaris 60az-m telescope and it is wobbly on the tripod. There is one screw coming from underneath the tripod into the telescope. I tightened the screw but when I move the telescope...
Here is the Meade manual web site. Find your telescope and see if a part is missing.
http://www.meade.com/manuals/index.html
and here is their customer service phone number:
http://www.meade.com/support/index.html
Aug 17, 2009 | Meade ETX-125PE (500 x 127mm) Telescope
The door knob (lever door knob to exterior fancy door) came off.
When you first tightened the screws, the mechanism may have been loose enough to allow the actuator bar the connects the inside knob to the outside lever to work loose. When you tightened it you may have jambed that tight so things didn't work. When you disassembled everything, you may have lost that part. The springs are usually integrated into the catch part and are not removeable. Sometimes it helps to take everything completely off the door including the catch that goes in the edge of the door. Then reassemble it on a table to see what works and what doesn't. If that doesn't help, take all the pieces into Lowes at the key desk and they will be glad to help you.
Jun 18, 2009 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Tank has slight wobble after installation
you need to tighten the nuts under the tank. the tank is not even.
The best method is hand tight the nuts to approximately same pressure on all 3 nuts. then use socket ratchet, one turn each,one at a time, till the tank stop rocking. stop right there. flush the toilet, check for leak. tighten as needed.
make sure all 3 nuts have even pressure.
May 20, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Spartan Technologies Spartan Sports Magnetic Rower Logo
395 people viewed this question
Top Spartan Technologies Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Spartan Technologies Exercise and Fitnes Expert? Answer questions, earn points and help others
