Question about Cell Phones
The port on my phone has a "prone" bent upwards and in. How do I fix it I can not get a charger to connect to my phone..help!
  • Cell Phones Master
  • 7,733 Answers
Need a repair shop.
Posted on Mar 29, 2015
4 Suggested Answers
timthorne911
  • 464 Answers
SOURCE: Internal charge port is bent
No, you need to take it to a tech, or get a replacement phone. Kinda sucks, but that's the only way to do it. If you have insurance you may be in luck to get a replacement for free.
Posted on Mar 18, 2009
INTERLOGIC
  • 326 Answers
SOURCE: Charger do not fix well with Cellphone Charging Port
the bottom connectors gone bad replace it
Posted on Jul 07, 2009
leorcid
  • 281 Answers
SOURCE: I need a new charging port. The wires are bent
You can buy one chargin port from your local vendor. Fixing it is easy as it does not involve any soldering. Just open the phone, remove the old one and put the new port in place. Make sure you do not shear any flexi prints.
Posted on Dec 28, 2009
Testimonial: "I went to ebay and found the part right away! Thanks!"
Charging port not working on my samsung e370
port metal is bent so bend it to original shape so it makes contact with charger cord.
Jul 14, 2014 | Samsung Cell Phones
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
My mobile nokia model 1209 is not charging
Mostly nokia chargers doesn't make problems...
just try the following..
1.connect ur mobile with a system (usb cable)...if it charges then replace your charger fault is in their,
2.if problum not solved then,power off mobile,romove the back flip and remove the bettry,check the phone,s connecting metel terminals,
if they r slightly bent,bend them slightly upward whith the help of a pin,check metal terminals of the battry if they r ok then good othervise replace bettry with new one.
3.check the bettry in another cell phone if it charges theno problum is in ur cell phone or power jack(socket)...
IF Charging Problem not Solved So then contect a qualified repair.
Aug 29, 2013 | Nokia Lands Phones
The charging port was lose to begin with whenever i would plug my batt. charger in it. then one day I was jiggling around to get the phone to charge pulled it out and pushed it in and one of the metal tabs...
Hello
If one of the metal is bent up and your phone is not charging then you would need to replace the charging port of your phone.Before replacing the charging port you could use a desktop charger for the main time while you get your charging port replaced.
GOODLUCK
Jul 02, 2010 | Motorola Mobility W385 Cellular Phone
Blackberry curve 8310. My charger port will not charge I can see one of the conectors looks like it got bent and am not able to correct it is this replaceable? Where can I get it repaired at a low cost?
Your problem is the charge port on your phone needs replacement. We fix them through our ebay repair listings for $38.95. Just type "blackberry charge port repair" for your ebay search and look for the listings with "PORT REPAIR" around a charge port in big red writing. Our ebay username is "its-a-pheo" We have fixed hundreds of them and complete the fix the day we receive the phone from you. Feel free to email me with any questions at all... blackberryrepairshop@gmail.com
May 14, 2010 | AT&T BlackBerry Curve 8310 Cell Phone -...
Won't Charge! :-(
Hi. these situations are mostly caused by a bent or broken copper prong that is located within the input charger port that is inside the phone housing.
When you insert the charge cord into the input port, there are copper prongs that will have to connect to each other and , this contact point will transfer the necessary current to the cell for a proper charge.
If the prongs are damage in any way due to broken copper or, bent copper prongs, this will prevent the necessary current from flowing to the cell.
Most remedies are crude like using a tooth pick or paper clip to straighten out the prongs inside the port. these methods do more harm than good and i recommend sending this phone in for a input port transplant. the manufacture or local repair depot is the best repair solution for this situation.
There is one thing that i would do before sending it to the repair depot. try using a completely different battery cell. if you purchase a new battery and the charger continues to not charge, this will confirm the input port failure.
Please rate and god bless:)
Apr 22, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Mar 18, 2009 | Samsung SCH-u340 Cellular Phone
"Unauthorized Charger"
you can try to clean the charger port (but first make sure its not bent, or broken - the pins are really tiny and hard to see, so make sure)
But try cleaning the charge port on the phone and the charger with denatured (rubbing) alcohol, and a toothbrush -
Just make sure not to plug it in when you do this!
and clean both the charger and phone, make sure neither are bent
lastly, try a new charger!
NGK
Dec 22, 2008 | Motorola Mobility RAZR V3
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
