Question about Jensen Audio Players & Recorders
How can I connect my Jensen over head player to headphones.I am not getting any sound
3 Suggested Answers
  • 21 Answers
SOURCE: Missing headphones
there should be a set of rca cables going to the stereo make sure they are plugged in
Posted on May 10, 2010
SOURCE: Need Replacement rubber band for wireless headphones JW160R
I received a pair of JW160s headphones from my uncle which suffered from a broken band. I replaced the band using two silicone "Livestrong"-type wristbands that picked up at the dollar store. The wristbands make ideal replacement parts as they are roughly the same width as the headband at its widest point. The headband tapers down to about 13/32" width the last 2 inches on either side. If you have an X-Acto knife, you can trim the wristbands down. Make sure to add a hole down the middle of the ends (from 1/8" to 1 1/4" from the base). After fitting the two wristbands to the respective springs inside each headphone, I stapled the two wristbands together (staples upside-down) and used some electrical tape to secure it in place and cover up any staple protrusions. Worked like a charm. This information will probably come a little too late for OP, but hopefully someone else will find this information handy.
Posted on Sep 17, 2013
How can I get sound from my radio
If a cable speaker is shorted to ground or (in your case) the short was on the casing the radio mutes the output to save the amp. So
remove all cables and put them back to the radio & connect the speakers one by one to see if it works or mutes again
Sep 30, 2016 | Jensen Jta-475 Cd Player /turntable...
Can't get headphones to work on this unit
Aux-in jack is used to play another device such as an Ipod or other sources through your Jensen player, using it as some sort of an amplifier. Look for another port on your Jensen player that says "audio out" or "Spkr" (means speakers) to plug in her headphones. If you can't find any of these ports then you might have purchased a n actual boom box, which does not have the capability to play through headphones, sorry about that.
Dec 28, 2013 | Jensen cd-472-bk am/fm cd boom box
Want to add boom box speakers to my pc
You could use a fm sender to go from the computer headphones and tune in the boombox radio to play the sound..
Apr 25, 2012 | Jensen Portable Stereo Compact Disk Cd...
How do I get GPS & bluetooth stufff to go with this system ?
You need the Jenson BTM15 (bluetooth module) and the Jensen NAV105 (gps) in order to have navigation and bluetooth connectivity thru this head unit.
http://www.mobile.jensen.com/accessories/?sku=NAV102
http://mobile.jensen.com/bluetoothcarkits/?sku=BTM15
These units sell for around $50 (btm15) and $200 (nav102) on amazon.com
Jan 28, 2011 | Jensen Vm9214 Car Video Player
Jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
Jan 27, 2009 | Jensen CD2610 CD Player
Rear zone sound not working
Do you have the manual? Here is the link
http://mobile.jensen.com/jensen/docs/man/VM9512_DOC_OM.PDF
And is no IR transmitters in the unit. Let nme know if you still have audio issues aftr reading the manual.
Peace,
Larry T
Winona Lake, IN
Jan 23, 2009 | Audiovox VM9512 Car DVD Player
Ipod video problems
I have the Jensen head unit. I found out a while ago that the 6th Gen Ipod Classic does not send video through the multi-pin connection. Only out of the headphone/A/V out. This is the reason it does not work via the JLink cable into the Jensen VM9312
Jan 03, 2009 | Jensen's VM9312 Car DVD Player
Lock up
Sounds like the ground connection (-ve) to the earphone socket is broken.
When you plug in the earphones, they ground through the control section on the board. Poor sound is another sympton of this problem.
If you have any soldering experience, dismantle the player, and re-solder the 4 connections to the headphone socket.
May 18, 2007 | Philips PSA232 (512 MB) MP3 Player
Memory
It sounds like the "memory" power wire is not connected. This is a separate wire coming into the stereo that is always connected to the car's battery. It is not affected by whether the keys are in the car or not. You will need to locate this wire, and ensure it is connected to an "always on" circuit in the car.
Apr 05, 2007 | Jensen VM9510 Car DVD Player
52 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
