Question about Smeg Washing Machines
How do I change the drum bearings and seal on a Smeg WMI12C7 Washer Dryer
  • Smeg Master
  • 5,323 Answers
Tub bearing or tranny bearings
Posted on Mar 30, 2015
SOURCE: KENMORE H3T WASHER GREY TWISTED FRONT SEAL
I am currently replacing this bellow because of holes and five years of wear and tear. The bellow is attached to the front door assembly via a spring loaded clamp. This clamp is a solid large wire ring with loops on each end where the spring attaches. You do not have to remove the spring, just place a screwdriver between the bellow and the ring or spring to remove. This will allow you to take off the bellow from the lip of the front door assembly to reposition. The spring clamp goes on starting first from opposite of the spring and working in both directions a little at a time. ALL DONE.
Posted on Dec 30, 2006
Boola-Boola
  • 8 Answers
SOURCE: Drum Bearing Replacement
With a plastic tub (outer drum as you describe it) removal of the old bearings can deform or bruise out the plastic housing a little - you will need to check that the new bearings will be really good fit. You may need to use a retaining compound if not, to ensure that the outer journals of the bearings don't creeping round in the plastic housing and wear it looser.
I did my Hoover Electron 800 bearings (metal tub). As i recall it was fairly straightforward - needed a gasket for the tub backplate on that.
Unbolted tub backplate from tub and withdrew it through rear of chassis along with drum/drum-shaft/bearings assembly, removed pulley, tapped shaft through bearings with softfaced mallet (or hammer & wood), drifted bearings out gently, working evenly around circumference.
For plastic tub some kind of suitable extractor may reduce chances of deforming bearing housing during bearing removal, compared to drifting them out. If it'd serve to ease the new ones in too then that'd be even better.
Don't forget to check/clean the water level pressure sensor path while you're at it - stave off any problems in that area for a while while you have the machine apart. ;o)
Posted on Jan 04, 2008
SOURCE: drying operation on WD16BA on smeg dryer
I think all you have to do (that's how I do it anyway), is turn the program knob so that the line is at the beginning of the drying stage (the little 'sun'), having first of course chosen the desired amount of drying time with the knob on the far left...
Hope this helps, good luck...
Posted on Oct 03, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore washer dryer combo leaks water under drum from shaft
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
livewire874
  • 618 Answers
SOURCE: inside drum of front loader
If the inner drum moves or is loose the the inner drum needs to be replaced .At the same time you should replace the rear of the outer drum as this contains the seal and bearings.
Posted on Nov 04, 2010
Smeg washer dryer not draining
Sounds tricky you may want to try this site, there's loads of help, advice and videos to help diagnose faults.
Give them a try. Hope you get this sorted. How to diagnose draining problems
Jan 31, 2014 | Smeg WDI12 Front Load Washer / Dryer
We have an Ignis awf 595 washer dryer. The machine is now beyond economical repair due to the drum shearing off its bearings. What would cause this to happen.
It would be caused by a corroded and then seized up drum bearing from a water seal leak, detergent is very corrosive and very quickly ruins the drum bearings.
Feb 06, 2012 | Maytag Washing Machines
I have a frigidaire stackable washer/dryer model number FEx831cs0. The washer is working just find but the dryer for a few weeks has been making the worst screeching sounding in the world. I am not sure if...
A loose belt often makes a squeak that pulsates with the clothes hitting the paddles in the drum. It's probably the upper drum glide or rear bearing. If it's a constant screech coming from the front, it's probably the glide. If the noise seems to be in the back, suspect the bearing. You might check for a sock or something small that is stuck somewhere between the drum and the dryer.
Glide: http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/916658?modelNumber=FEX831CS0
Bearing kit: http://www.repairclinic.com/PartDetail/Drum-Bearing-Kit/1851?modelNumber=FEX831CS0
Neither are very difficult to repair.
Other parts for your machine:
http://www.repairclinic.com/Shop-For-Parts?s=t-%20FEX831CS%20-%3d%3d
Good luck.
Feb 28, 2011 | Frigidaire FEX831CS Top Load Stacked...
RATTLING & DRUM NOT SPINNING EVENLY, ALTHOUGH CHANGED BEARINGS TW
Check the belt. it may be broken or, it may have slipped of the pulley or drive motor. if the belt is fine, replace the motor.
Jul 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
SMEG WDI 12 Washer/dryer Unable to fit new belt
Sadly, the answer to your question isno, it's not normal. In fact as soon as I saw the first sentence of your problem, I guessed the rest. The wheel should have no play at all and the drum and wheel move together on a sprung mechanism. The reason that the wheel is loose is because the bearings in the drum (That sit directly behind the centre of the wheel) are worn out. To be sure that this is the problem, open the front of the machine and pinch with your thumb on the outer (static) cylinder of the drum and your forefinger on the drum that spins. There should be no play here whatsoever. I suspect that you will see the best part of a quarter of an inch of play and pinching as I describe will make a nasty little clunk at the same time. The other classic sign (though not always there) is that there is a tiny amount of water leakage from the bearing at the centre spindle of the wheel. The reason the belt comes off is because the wheel is unstable on the worn out bearing.
Some machines can have their bearings replaced by a competent DIY-er, but many require a specila tool to extract the damaged bearing and press the new one into the housing. I imagine that a call to your local supplier will reveal which of these actions is possible for your machine, but either way, this is going to be a real pain. It's a drum out job and that's not fun if you have never done it before (I do occasionally, and I still don't have any fun!).
Sorry to be the bearer of bad news.
Mar 26, 2009 | Smeg WDI12 Front Load Washer / Dryer
Spots on the clothes
IF YOU ARE USING BOUNCE IN THE DRYER ON HIGH HEAT IT WILL CAUSE SPOTS ON THE CLOTHES IT'S NOT THE WASHER.
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bearing fix
That job is for a very skilled person I would not take it on unless you are that person,by the way it comes in a kit TWO bearings and water shaft seal I would replace drum shaft as well Eamonn Ireland
Jun 12, 2008 | Candy CNW156 Front Load Washer / Dryer
Kenmore Washer/Dryer Combo purchased in late 2000
Call a local repair tech. I know one in Milwaukee :)
Seriously, your machine needs some possibly expensive repairs beyond a novice's skills. The dryer has a felt bearing around the front of the drum that is probably worn out. Check on the rear bearing and the belt at the same time. The washer may need a new transmission, belt, tub seal, and spin bearing. That's an involved repair. Expect to pay extra for labor, but the total bill should be less than the $800 - $1400 for a new machine.
Mar 12, 2008 | Kenmore 24032\24036 Top Load Washer
Loud noise coming from machine
i would say its the bearings in the drum rather then the motor,that would be expensive over $200?
Dec 19, 2007 | Smeg WDI12 Front Load Washer / Dryer
Drum Bearings.
I recommend first of all ordering a repair manual. Or at least see if the parts come with detailed instructions on how to take out the old and install the new. You will probably have to replace the entire outer drum assembly. It's much more expensive in parts to do it that way than to just replace the bearings and seals, but much much easier and faster. Personally, I've replaced the entire drum assembly and also tried to replace just the bearings and seals. In the end I wasted the money on the bearings and seals and got an new assembly. I'd recommend just going for the new assembly and saving time.
Oct 01, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Washing Machines Logo
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
