Question about Garden
Has 5 prong switch which color wire goes to which prong?
  • 1 more comment
  • D. E. Hev Mar 29, 2015
    Hi Robert Kilby, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is it?
  • Kprime
    Kprime Mar 29, 2015
    Besides know which switch (ie Key switch, Seat switch, we would Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one. A short description of the events preceding the beginning of the problem is also helpful.
  • Brenda C Stroud
    Brenda C Stroud Apr 15, 2015
    2009 bolens riding lawnmower (hood model #) 13ac762f/13wc762f ignition switch wire colors are: red, yellow, green, orange and (2 wires on one clip) red with white stripe
    Genius:
  • 1,181 Answers
What make and model is the mower?
Posted on Mar 29, 2015
    Sergeant:
  • Garden Expert
  • 187 Answers
This is a general, Sabre (by John Deere), lawn tractor Ignition switch (Key switch) wiring explanation. This switch was use primarily in the 1990's, on many different models. It may or may not be specific to your model. Included is an unmarked picture of the terminal layout.
Orient your switch so the row of three terminals is on the bottom. Those are the output terminals.
The row of two terminals should be on top and aligned to the right hand side. These are the input terminals. See picture below.
Top row left: This terminal has a red wire. This wire carries voltage/current from the battery (and from the stator; charging system). If the battery is charged and connected this red wire will show 12+ volts; whether the key is on or off.
Top row right: This terminal has a white wire. It's tied to the ground system. It is connected to both the Brake switch and the Blade switch. Its function is to ground the coil when you turn the key off. That kills the engine.
Bottom row left: This is a purple wire. Current goes through this wire, to the Blade Switch, then the Brake switch, and finally to the Starter Solenoid. When you turn the key to the start position, the PTO switch (blade switch) must be off, the brake must be on, the starter solenoid must be in good shape, and then the engine will crank.
Bottom row center: This is a yellow wire; it provides voltage/current to the fuel shut off solenoid on the bottom of the carburetor. It will show zero volts when the key is off and 12 volts when the key is on; provided of course that the red wire is connected to the top left terminal.
Bottom row right: This is a black wire. This wire goes to the ground system and connects to the negative post on the battery. This terminal connects inside to the top row, right, white wire and kills the engine when the key is turned to off. A continuity meter will show this connection cycling on and off as you turn the switch on and off. A DC volt meter could be connected to the positive post of the battery and then to the top right terminal, with the black wire attached to the bottom right terminal, the meter will cycle between zero and 12 volts as the key is turned on and off.
Has 5 prong switch which color wire goes to which  - 25616303-iyou3bimhegr4nsjthcwbqvn-4-0.jpg
Posted on Mar 31, 2015
Testimonial: "This did not work. Had to go to John Dealer to get the correct conections. Thanks anyway."
  • 1,169 Answers
Being Sabre sold by John Deere you need to contact your local JD dealer for a wiring diagram. They should should be able problem a copy from their service manual on your Sabre but you need to give the model number instead of the serial number.
    Top Expert:
  • 2,907 Answers
Doesn't sound like you're talking about a power cord, but just in-case.
The small flat pin has a black wire.
The wide flat pin has a white wire.
The small round pin has a green wire.
Hope this is it.
Testimonial: "This a Lawn Mower Called Sabre sold by John Deere. It is a 1996 and model number is GXSABRA022956."
  • 2 more comments
  • danoyachtcap
    danoyachtcap Mar 29, 2015
    Wrong again, sorry.
  • Robert Kilby Mar 30, 2015
    This is on a Lawn Tractor called SABRE sold by John Deere It is a 1996 model and serial
    Serial number is: GXSABRA022956
  • Kprime
    Kprime Mar 31, 2015
    Need a Machine Model number, like 1842GV. I have schematics for a number of models, but need the exact model number.
I am hardwire fulepump useing 4 prong relay on 2002 Chevy Malibu I need to know what color wires on harness goes to each prongs on relay
Dk Green/white goes to Pin 86
Black to Pin 85
Gray to Pin 87
Hot wire coming from fuse 48 to Pin 30. My info doesn't show the color of that wire. The wire will get hot in the run and start positions
May 31, 2018 | Chevrolet Cars & Trucks
It is the switch in the 2006 cavalierfema trailer above the sink I need to put the switch in but dont know what color wire goes where there is 4 prongs on the switch itself but has 2 red wires 2 purple...
With todays phones, it is always best to take a pic of the actual wiring hookup... Go to google, maybe they have a wiring diagram for it.
Aug 13, 2017 | RVs
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
Need to switch 3 pronged plug for 4 pronged but not sure which color wire gets connected where.  Other wires were not color coded.
the red and black wires go to L1 and L2 terms doesnt matter which color on which term, white wire goes to"N" neutral terminal and green wire is safety ground that can be grounded to the steel housing of unit if your feed line comes directly from your main panel,not a sub panel,some localities will allow you to tie the white neutral and green grnd wire together in the unit chk your local ordinance first
Jul 11, 2009 | Dryers
4 prong to a 3
The forth is just a cabinet ground hold the cord flat the one in the middle goes on the white ( the middle terminal in the back the other two do not matter they are both live wires the middle one is the only one that is different
Mar 30, 2009 | Roper REX4634KQ Electric Dryer
Amana Dryer
there should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Mar 18, 2008 | Amana DLE330RAW Electric Dryer
Garden Logo
249 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
