Question about Makita 9403 11 Amp 4-Inch-by-24-Inch Belt Sander with Cloth Dust B
Why won't my Makita 9403 sand the whole 4 inch path?
It only sands about an inch path...
2 Suggested Answers
  • 885 Answers
SOURCE: New 4" angle grinder does not come with sanding disc pad
You need the 4" rubber pad, Makita Part #743009-6. It can be found on websites like www.ereplacementparts.com.
Posted on Aug 23, 2010
How to clean a clogged belt sander
I assume you mean you want to clean the belt itself? You can use a rubber stick made for this. It looks and smells like a giant pencil eraser, about 1 inch square and about 10 inches long. However, if the belt is clogged with melted paint, that won't do much - but a stiff wire brush works OK. If the wire brush doesn't work, get a new belt. You can avoid the melted paint buildup (or at least reduce it) if you keep the sander moving rapidly over the surface, and use a good quality scraper to remove as much paint as possible before sanding.
Sep 19, 2012 | Makita 9404 4'' x 24'' Belt Sander
The sanding belt on my Makita 9403 keeps breaking at the glued joint after only 5 minutes of use. Have fitted a new graphite pad, but this has not resolved the problem. Am using genuine Makita sanding...
They will do that if you install the belt in the wrong direction...
Check the arrows on the inside of the belt and make sure you are turning the belt in the right direction...
Otherwise check a different brand of belt...some of them out there are ****....
heatman101
Nov 22, 2010 | Garden
The sanding belt has broken and jammed in behind the rear driving wheel. It won't budge. How do I remove it ???. Brand new sander to. Thanks for your help,Fraser
UNPLUG tool and with a pair of needle nose plliers and patience pull the belt loose it might take some time but that isabout the only way to do it.
Oct 22, 2010 | Makita 4" x 24" Belt Sander 9403
I need a new pad ours is worn out. makita 0125mm B05010 120 volts 532117A 8 wholes.
Buy from one of the many on-line parts sellers. Or do a Google search and you'll find hundreds.
Aug 06, 2010 | Makita BO5010 5" Random Orbit Sander
1/4 palm Sander is not "collecting" dust even with a new sanding bag, what could be the problem?
Are you using the punch plate to put holes in the sand paper after you put on a new sheet?
If you are it could have an obstruction in the fan guide or the fan has broken fins. Both the punch plate and fan can be purchased by clicking on the below link.
http://www.ereplacementparts.com/makita-bo4552-finishing-sander-parts-c-97_103_482.html?osCsid=s71te2ssm60u2ga80vaqah9f85
Jun 23, 2010 | Makita 1/4 Sheet Finishing Sander with...
May 23, 2010 | Makita 9553NB 4" Angle Grinder
Belt will not tighten small round spring come loose do not no where it goes
Usually there is a knob with a screw imbedded with a spring around it that screws in and adjusts the "tracking" of the belt so it doesn't run off the side of the rollers. If you lose that screw, then teh belt will come off quickly.
At this site, look at part # 68, 69, and 70
http://www.ereplacementparts.com/makita-9403-belt-sander-parts-c-97_103_113.html?osCsid=l052ctaa4vsu2817buk99qpop2
Jan 15, 2010 | Makita 9404 4'' x 24'' Belt Sander
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
My 5 inch random orbital Sander: the self stick sanding disk will not stay on it. Can you tell me the trick to making them stay on sander? Thank you!
If your disks have a "furry" bottom you have to have something like velco stuck on the base of the sander. The velco is slf sticking and you get it at the hardware store. Good luck.
Jun 10, 2009 | Makita Tools & Hardware - Others
Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
May 02, 2009 | Makita 9404 4'' x 24'' Belt Sander
Makita 9403 11 Amp 4-Inch-by-24-Inch Belt Sander with Cloth Dust B Logo
318 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
