How do I change the drum bearings and seal? - Washing Machines
  • Washing Mach... Master
  • 5,323 Answers
Remove the agitator and then use a spanner wrench to remove the nut and seal
Posted on Mar 30, 2015
Inside drum of front loader loose bearing in back is ok but drum must have bushing gone how can i change this bushing the drum looks like its sealed
If the inner drum moves or is loose the the inner drum needs to be replaced .At the same time you should replace the rear of the outer drum as this contains the seal and bearings.
Nov 04, 2010 | Kenmore 43142 Front Load Washer
How to replace rear wheel bearings
If it has drum brakes, you'll need to take off the center dust cap, remove the cotter pin, remove the nut and washer holding the drum on. The outer bearing should fall out, the inner bearing usually stays in the drum, due to the grease seal. With the front bearing and washer off, put the drum back on and install the nut, then pull the drum, allowing to the nut to catch the inner bearing as you pull off the drum, and that should leave the inner bearing and seal on the spindle. Pack the new bearings with grease, install the inner one in the drum and tap in the grease seal in place, but the drum back on and install the outer bearing on the spindle, the wash, nut, cotter pin and dust cover. Tighten the nut snug and turn the drum a few times and snug up the nut. Don't overtighten it.
Apr 29, 2010 | 1991 Volkswagen Jetta
Bad bearing
if the bearings are rusted or seized u need to change main seal near bearings. was it noisy b4 you looked at bearings?could be broken spider that holds bowl.please reply if u need more help
Mar 31, 2010 | LG WM1814CW Front Load Washer
Hi, I need to change the drum bearings on a Hotpoint WM64N washing machine - anything to be wary of?
it is very tedious to change drum bearing but if you are technically sound than you can do it. but you won't find the water seal any where other than the sevice center, in case seal is damaged.
Oct 24, 2009 | Washing Machines
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Easiest way to change drum bearings
    I have changed the drum bearings on our Creda Excel 1200 V120VW. Not a simple job by any means.
    The machine had to be just about totally stripped to get at the drum.
    Before starting beware of sharp edges on just about any part of the machine
    Remove all panels, top, rear, front facia, front panel including door, motor, powder draw
    The secret is to remember to take photos or make drawings of the position of all the electrical wiring, hoses, covers and any other components you may be removing for access. Keep all you components together, it saves hunting for them later or worse still not refitting them.
    Once the drum is out of the washer the drive pulley has to be removed. It is secured by means of a 30mm af nut which has also been fastened with thread locking fluid. Fortunately I have an electric ratchet gun, otherwise it would have required heat on the nut to defeat the locking fluid. The pulley is also threaded and was unscrewed with the aid of an application of WD40.
    The front of the outer drum is unclipped and removed, the inner drum can then be removed by replacing the nut flush with the end of the thread, to prevent damage, and tappinng the drum out with a soft faced mallet.
    This done you then have to remove the old bearings and seal. This is done be means of a drift and hammer, taking care not to bruise the area where the new bearings will be fitted.
    The old seal may have to be destroyed by a sharp screwdiver or a proper seal removal tool.
    When the bearings are out clean all areas with fine emery, lightly grease the bearing recesses and fit the new bearings and seal. Take care when refitting the stainless drum back into the outer drum not to turn the lip on the seal.
    Now it's just a simple matter of re-assembly, make sure all parts remove are re-fitted in the correct sequence.
    Another tip is not to put machine and all panels, ie; top cover and rear panels, back in place until the washer has been run and tested and inspected, to make sure there are no leaks and the machine goes through the cycles as it should.
    Finally good luck!!!!
    May 27, 2009 | Creda W120VW Front Load Washer
    Noisy bearing on drum
    This is not an easy job on any washing machine. The AEG is probably the same as most washing machines in that it has two bearings on the shaft at the rear of the drum but it also has a carbon water seal on the inside and usually you will need to change this too as if you disturb the bearings it will surely leak. If you have never done this before it can be dreadfull. If your drum has bolts and a seal at the back to withdraw the inner drum and back plate out the back of the machine then you are lucky and you should be able to do the job in about two hours. If you dont have a removeable back on the drum you will have to strip the whole machine and remove the drum supports and hydraulic pistons at the bottom. All hoses and pipes and wiring attached to devices on the drum will have to come out as well as the door seal and soap dish rubber connector. Good luck.
    Apr 03, 2009 | LG Washing Machines
    Replacing rear wheel bearings on 1999 hyundai sonata
    1. for drum brakes with sealed hub(all one piece) remove lug nuts and wheel.
    2. spray penetrating oil around studs if there is a big phillips head screw visible remove it with impact driver/if not use big ballpeen hammer ,tap on flat of drum near studs(becareful not to hit them) until drum loosens(your creating a shockwave to loosen rust)
    3. once drum is off there are 4-bolts coming in from behind backing plate, remove them then hub should be able to be removed w/a little persuation from hammer.
    with out sealed hub ,
    1. remove wheel
    2. remove dust cap,cotterpin,star washer(if equipped) do not re use cotter pin
    3. remove nut then washer, wiggle brake drum and front bearing will come out.
    4. put nut on shaft tighten 2-3 turns grab drum by sides and pull towards you this should remove drum leaving inner bearing/seal on shaft
    5. to replace reverse procedure making sure to pack new bearings w/grease(take drum and use long punch to remove bearing races, use race/seal installer to install new races
    with disk brakes
    1. remove wheel
    2. remove caliper/bracket
    3. remove rotor
    4. remove 4-bolts from behind,tap old hub out
    5. reverse procedure
    Jul 19, 2008 | 1999 Hyundai Sonata
    Suspect drum bearings
    most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
    Aug 14, 2007 | LG WM-1480FHD Front Load Washer
    Washing Machines Logo
    23 people viewed this question
    Top Washing Machines Experts
