Question about Cobra Radio Communications
I have a cobra 29 Ltd classic Night Watch with the pot r4 turned all the way up, my question is I have no swing and a high deadkey. how do i turn the dead key down? why don't I have any swing any help would be greatlyappreciated
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 119 Answers
If you need a swing, sea Sears or Lowes. I am sure either of them can help you out.
Posted on Apr 02, 2015
4 Suggested Answers
SOURCE: 29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Posted on Mar 16, 2008
Dodgem250
  • 68 Answers
SOURCE: Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
Posted on May 10, 2008
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
Wow. That's not at all a solution to what this guy is asking. And why all the caps??
The one point jm77437 has that is correct is that you do not set the radio, you set the antenna. The rest is blah blah.
Here is how you tune your antenna for you radio. First off it depends on what kind of antenna you have. most fiberglass antennas have a tunable tip to adjust the height of the antenna. Metal whips either have a collar at the base that the whip will either slide up or down in to adjust the height. The other type of metal whip's you have to physically clip to shorten the antenna, you must be careful with this type because once its clipped, that's it. You cannot add what you cut off.
I am going to give this example using a metal whip with an adjustable collar.
First after your radio is hooked up in the vehicle, drive to an open lot. Buildings and other structures can cause extra reflection. turn to channel 1. Flip the meter to CAL. Key the mic without talking. Now turn the CAL knob up until the needle reaches the little upside down triangle all the way to the right marked CAL. Now you have just celebrated your radio for your setup to measure you SWR. Now while still holding the key, flip the meter switch to SWR. The needle will move, and where it stops is your SWR reading. The lower the better. Anything under 1.5 is considered really good. But still, the lower the better.
Make note of what your SWR was on ch 1.
Now flip to channel 40. Repeat the SWR process. You must recalabrate each time you take a reading.
Now like jm77437 said. If your SWR reading is higher on 40 then 1, then your antenna is too long, and you must make it shorter. Loosen the collar and lower the antenna in the collar 1/4 inch at a time. check the swr each time you adjust the antenna.
If your SWR reading is higher on channel 1, then your antenna is too short. You must make your antenna longer. Do this by loossening the collar and pulling the antenna upward in the collar 1/4 inch at a time, again checking the swr each time you adjust the antenna.
What you want to achieve is having the same SWR reading on channel 1 and 40. then you have the best match you are going to get with that antenna.
If your swr is under 1.5 on all channels, you don't need to fuss unless you are a perfectionist. then by all means go ahead.
If your reading is higher then 3, or your ant light comes on, something is really wrong. Make sure your antenna is connected all the way, and the coax is not damaged.
Its important to have an appropriate SWR because if you do not, you are reflecting too much signal back into the radio, and eventually you will burn out your final transistor, and your radio will be toast.
Some tips: make sure you check the swr with the doors and windows shut. Make sure you are in an open lot. Remember to calabrate ecah time you take a reading. If you have had your radio peaked by a radio shop, and they have lowered your dead key, or have done a swing modification, then the meter in your radio will not work when taking an SWR reading and you will have to use an external meter.
Posted on Apr 24, 2009
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
Why is the swing on my cobra 29 ltd with bt swinging backwards with i talk
because when you tried to modify the radio for more power and audio you turned the wrong coil and can.
Aug 01, 2012 | Cobra 29 LTD CB Radio
How to match a antenna to a cobra 29 LTD Classic
You are actually tuning the antenna to the vehicle it is mounted on here are some very good resources. http://www.rightchannelradios.com/pages/cb-antenna-tuning-guide-pv-c0-61.htmlhttp://www.wilsonantenna.com/swr.php
Be aware that if your radio has been modified it may produce a dirt signal that an swr meter may read as reflected power. In this case it may be more accurate set with a unmodified radio also if your radio is setup for a linear it may have a deadkey to low for the swr meter to calibrate correctly.
Hope this was of help.
Nov 26, 2011 | Cobra 29 LTD CB Radio
I LIKE TO MAKE MY COBRA 29 HIGH POWER TALK A LONG WAYS HELP ME
Get a "swing kit" installed for about $20
Buy a power mic
Have the audio maxed out (simple turn of the VR4)
Have money to spend???
http://cbradio.auctivacommerce.com/IN-STOCK-EKL-POWER-BAND-RFX-75-P429725.aspx
Go there and for about $100 your Cobra will do 100 watts or a little more
"WILDCAT" IN LAURELVILLE OHIO
35 YEARS IN THE CB WORLD!!!
Dec 28, 2010 | Cobra 29 LTD CB Radio
I just purchased a Cobra 29 ltd classic. Trying to find the potentiometer vr4 but all pots are labeled r1, r2 ect. Which one is it on the newer radios. thanks
Some time ago I had need for info. for a 149GTL Cora and went to this Email ad..............http//www.superior.net/~haggis/smods1html. Good luck with you're research.
Oct 03, 2010 | Cobra 29 LTD CB Radio
Cobra 29 LTD Bluetooth
You got your radio peaked? Most likely, however, the pot for the antenna warning indicator is VR6. I always check that after peaking a radio.
Jul 28, 2009 | Cobra 29 LTD CB Radio
Cobra 29 Ltd Classic
In most cases just turning up VR4 is more then enough. Replacing the final, tr14 with another transistor requires changing many more parts to get it to work.
With a new 29, there is no need to change the final. Just turn vr4 all the way up and you will see around 20 - 25 watts. L13 won't gain you a single watt. L12 will raise the dead key, and usually you want a lower dead key for good swing. L14 will gain you a few watts, but don't adjust this unless you have a watt meter. You turn it out to increase wattage, but too much will over bias the final and shorten its life.
You hook it to a watt meter with a dummy load. Then say a steady AHHHH into the mic while keyed. Turn the slug out until the needle stops going up, then back it down to where it stopped.
The easy thing to do, and you will be pleased is just to turn VR4 up. Now, Up is counter clockwise. Its a variable resistor, so the less resistance, the more modulation. So you want to turn the VR down.
that will be more then enough.
Sep 06, 2008 | Cobra 29 LTD CB Radio
Cobra 29 ltd night watch with sound tracker i want to convert it
Go to a CB shop and have them put in an "A" board. Then have them tweak & peak. Got mine done for $80.00.
Jun 04, 2007 | Cobra 29 LTD CB Radio
Radio Communications Logo
147 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
