Question about Garden
Where can I get a diagram or switch contacts wiring only?
  • Kprime
    Kprime Mar 29, 2015
    Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one. A short description of the events preceding the beginning of the problem is also helpful.
  • 9,587 Answers
Try the manufacturers web site. They usually have downloadable diagrams
Posted on Mar 29, 2015
I need a wiring diagram for the indicator arm switch of a 1972 Beetle.
Here is a link to the wiring diagram you need:
Diagram
Match the colours of the wires to the numbers on the switch.
Mar 04, 2012 | Cars & Trucks
When my head lights comes on in my 1997 lincoln town car the radio do a constant scan, just keeps scanning i have changed the light switch
The headlight wiring and radio wiring is getting in contact and causing the short.Both the grounds needs to be checked.Because when headlight is off,the radio work's fine.As soon as the headlights are turned on,the radio goes in scan mode.Its clear indication of radio and headlight wiring issue.The wiring's are getting in contact with ant metal surface or both the radio and headlight wire are coming in contact,where they should not.I suggest you to check the headlight and radio wiring diagrams for your lincoln town car.Here is the direct link.Click the link below :---Check out all the 3 links one by one.Radio wiring diagram for 1997 LincolnTown Car?http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
----------------Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
---------Headlight wiring diagram for 1997 Lincoln Town Car?http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
----------This will help.Thanks.
Feb 13, 2012 | 1997 Lincoln Town Car
I need to replace the power switch on a Lifestep 9500hr and I need the wiring diagram
1) you do not need any wiring diagram for to this.
2) Since you will not find any wiring diagram for your treadmills, only if you pay for service manual at your company dealer.
3) I can recommend you very easy: the following.a)buy the switch to radio schack.
b) Put in your machine c) desolder one wire and put in the same place in the new one swithc and go on, and ready.
Anyway see the block diagram for your information.
sincerely.
ernesto cuadra
Dec 17, 2011 | Exercise & Fitness
Wiring diagram for time clock with photocell contacter and bypass switch
Copy following link for possible wiring diagrams showing photo eye and contactor:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#photo-eye
Dec 15, 2011 | Home
I have a 3 speed fan switch with 4 wires. The wire colors are grey,black,yellow,and brown. Where do they go such as L,1,2,3 on the switch?
Did you get a wiring diagram with the switch/fan? This should tell you which is which.
Each manufacturer has different color coding. If you didn't get a diagram, contact the manufacturer for instructions.
Good luck,
Handie Andie
Mar 25, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
Motor will not stop.
The wiring for the limit switch assembly is:
Yellow wire to the up limit contact
Gray wire to the center contact
Brown wire to the down limit contact
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Ignition wire came lose inside my stihl 210c chainsaw .
28866.png This is the only diagram that is offered for this model but on the multifuntion switch (#33) The wire is layed through the upper part of it with the metal connector sticking out of the left side and once there you will pull the wire to the right until the metal connector is seated in the switch. After this reinstall the switch into the handle houseing and make sure that the contact spring (#24) is sitting on top of the switch and when in the off possition making contact with the metal conector of the wire on the switch.
Mar 15, 2009 | Oregon Scientific Oregon Chainsaw chain...
Wiring diagram
ok, try purchasing a Chilton Manual (NOT a Haynes- it's junk). In it you'll find the complete wiring diagram.
Aug 03, 2008 | 1998 Ford Escort
Switch diagram
Be careful with your wiring as some models have a reset switch. Your best bet is to mount new external metal boxes to the frame and obtain industrial switches capable of carring the amperage load that the motors are drawing. Then you'l have identical controls on all units so future control problems will be esasy to solve. In your wiring, always remember that the black is the hot side and always routes through the switch and then to the motor while the white bypasses the switch and goes direct to the motor. In event you have a reset switch,, your black will go in as well as out of the reset and then through the switch to the motor.
Hope this helps.
Apr 06, 2008 | Dewalt DW746X 10" woodworker's table saw...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
