Question about Samsung Centura - Straight Talk Wireless
My volume is on high but the phone doesn't ring
MY S4 HAS A CONSTANT HIGH PITCH RINGING HOW DO I STOP IT?
try lowering your ringer volume or reset your phone.
Jan 08, 2015 | Samsung Galaxy Cell Phones
Does the Siemens Euroset 805 have a high low volume switch ?
Thanks M.Qasim for the solution!
Just a small correction you have to set the phone while is ringing. I did the following sequence call to the pone then press "Set" "#" "4" "#"
Oct 28, 2012 | Siemens Euroset 2005 Corded Phone
I am using a new siemens desk telephone. I dont know the model number & they dint give me the manual. I just could not reduce the ring tone volume. Any help on this is highly appreciated. I am...
Just look at the bottom of the phone, you will find ringer tone volume marked with low & high. Put it to low. For the manual, see the bottom-side of the phone to locate the model number & search the Siemens website for the manual.
sonunny
Jun 30, 2011 | Cell Phones
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
My phone doesn't ring to maximum volume, its too low.
Welcome to FixYa
Dear User,
You can Adjust your Ringer Level to High...If your Ringer is in Full Volume and No Sound/Bad Sound-the Problem is with Buzzer or Board Complaint[Board complaint in Rare Case]
Ringer Option in 6300:
  • Settings
  • Profile
  • General
  • 'Personalise'
  • 'Incoming Call alert'[Must be in RINGING]
  • Move to Bottom 'RINGING VOLUME'[move to Right side-now you can Hear Sound-Set to High Level or as you Like
  • It may ask for Confirm Selection of high Ring Vol
  • Alert For 'ALL CALLS'[at Bottom]
  • 'Save' Click
  • Then Activate GENERAL
You are Done[In this way -you can Select any Profile]
Hope this Helped -Dont forget to Rate ME......Thanks for Contacting FixYa...
Jul 09, 2010 | Nokia 6300 Cellular Phone
I cannot hear my phone ring. It is set to high
Look for a setting that changes the ring from vibrate to ring. It's a setting different from that of ring volume.
Dec 11, 2009 | Cars & Trucks
My sony erricssion k800i ring volume is very low
the peoblem is with the battery.
pls change the battery
thank u
May 14, 2009 | Sony Ericsson K800i Cellular Phone
When a call comes in the ringer doesn"t ring
you need to have the phone programmed to ring. ldtsnj.com can help
Jun 16, 2008 | NEC DTU 8D-2 Corded Phone
My Sony ericsson k800i is not ringing in full volume
I had exactly the same problem and came to a conclusion.
When you are playing in your music player at the same time it's playing use the volume keys on the top of the phone.
I hope this helps
Jul 24, 2007 | Sony Ericsson K800i Cellular Phone
Samsung Centura - Straight Talk Wireless Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
