I have a baxi 5117391 thermostat which when it flashes yellow says low battery therefore I've went to replace the battery with numerous other batteries which are the same AA alkaline LR6/AA even bough
I have a baxi 5117391 thermostat which when it flashes yellow says low battery therefore I've went to replace the battery with numerous other batteries which are the same AA alkaline LR6/AA even bought the exact same battery and still no joy, if I put one new battery in with one old it works but then flashes yellow again but when I go to put the 2 new batteries in, the ticker goes very fast and it doesn't work (clock nor heating) ive tried resetting and pressing the reset button along with the button on the boiler to connect but still no joy when there are 2 brand new batteries inserted therefore I currently have a low battery with one new battery how do I go about changing both so it's not low and so it works?
5 Suggested Answers
  • 11967 Answers
SOURCE: The camera(Fujifilm Finepix AX 250) says that the
A search of the Fujifilm website provided no answers. Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol. Also, I would switch to 3 or 4 sets of rechargeable batteries. That way, you always have a fresh set ready and you'll save money in the long run.
Posted on Dec 15, 2010
SOURCE: Drayton LP522 Heating & Hot Water Programmer
Mine is a different brand but looks similar if yours has a drop down panel which you open to set the times and to alter for winter summer in this panel you will see a very small hole Take a ballpoint and insert in the hole and press this is a reset button that the electrician told me about when mine went wrong it is not marked but it is a tiny button inset in the hole
Posted on Apr 12, 2014
Testimonial: "Hi Heather....I have just checked and unfortunately this one doesn't have a reset like that which is annoying as that may just have done the trick!"
  • 4128 Answers
SOURCE: How do I change the battery on Honeywell Thermostat T8001C?
According to the manual for the model series (see link), only the T8002 Model has batteries. They are accessed from the right side of the thermostat. See page 14.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1431.pdf
Posted on Jan 10, 2015
  • 34186 Answers
SOURCE: how do i reset my honeywell cm67 thermostat the screen is blank
The replacement batteries may be defective or installed incorrectly.
Posted on Feb 07, 2015
Home Thermostat reads low batt
I have ran into this problem before. I have actually had low batteries I thought were good too ha! I have had to actually reset the stat to get the low battery to stop flashing. There are multiple ways to reset the thermostats, depending on model, but removing the batteries and waiting has worked, along with actually having a reset button somewhere on the stat. Hope this helps!
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
Baxi boiler
Make sure the gas inlet & outlet pressures are correct (manometer) & that the primary air mixture is adjusted correctly. Check to make sure you have 1 square inch of outside air for combustion per 2000 BTU's rating on the boiler.
Nov 24, 2013 | Heating & Cooling
I have added new batteries to my pronto m51 when i went to charge i am getting a flashing green i think it should be yellow?
recheck your polarity on the batteries carefully, i've done it for 15 years and the factory makes it complex sometime i connect backwards initially
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
Baxi solo340p overheating no control
the gas valve is just a valve that open and shuts which lets the gas in,
the cylinber stat controls the hotwater
there must be a thermsat on the boilet that controls the water temp and a overheatstat thats controls the boile which should shut dow in the event of overheating if you go to the baxi wedsite you can down load the info for your boiler
Jan 15, 2010 | Heating & Cooling
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Hunter Fan Model 44260 eats batteries
you have to replace the thermostat . problems like this are common with latest electronic thermostats from china . most are going bad in less than 4 years . it so bad ,i am telling anyone who asks , to please keep there old regular thermostat , or if you have one of the old electronic ones (made over 10 years ago) hold on to it , it will last forever.... somehow when we moved the factory to china they forgot how to make thermostats that last ........ if you plan to rate this answer , please rate it 3 or 4 stars . this will help me stay in the paid answer department
Apr 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Jan 31, 2009 | Honeywell Programmable Thermostat Heater
PROGRAMMABLE ROOM THERMOSTAT
I found this on a search:
"I have the full set of instructions, contact me at gjb@eggconnect.net
Not a very reliable system, transmitter keeps resetting to 17:25; locks up. Whole system then requires setting up from scratch. Had a replacement transmitter, no change, and same faults.
GJB"
Perhaps this can help.
Mar 15, 2008 | Computers & Internet
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
