Question about Miscellaneous
I have a storm door on my front door. I am able to change the glass insert to a screen insert. There are two long thin plastic strips that clip in to hold the glass and screen inserts in place. Mine have broken and I can't find them online anywhere? Any suggestions?
    Genius:
  • 1,167 Answers
Who makes the door?
Posted on Mar 29, 2015
Testimonial: "It's an older house, 1973, I don't know who made it. That would make it easier though if I did know."
  • D. E. Hev Mar 29, 2015
    If you can take a pic of part and post it ,that would be helpfull
How to remove the retainer strips in a Larson full-view storm door. I want to switch out the screen for the glass.
Use a thin blade like a small spackle knife to get between the door frame and the retaining strip and GENTLY pry it out at the top or bottom and then carefully work the rest of the strip out. This may also help.
https://www.larsondoors.com/support/questions-and-answers
W1DL410
Dec 10, 2016 | Cars & Trucks
It is possible to take apart a Whirlpool wine cooler door to replace the tempered thermal glass unit inside. Door is stainless steel with plastic insert on inside with gasket in the plastic insert. I
It is likely a double glassed unit, You can try and slide a thin bladed knife like the snap blades between the glass and the rubber and cut it away., You may be better to take it to a glass company that make DGU (double glazed unit) and they will be able to produce another piece o glass for it and put it back through the machine to make it a new unit.
Aug 28, 2014 | Whirlpool 38-Bottle Wine Cooler
Cable system on passenger door power window, 1999 dodge Caravan, has slipped off track. Need exploded diagram to restore to original.
REMOVAL
1. Remove the watershield. (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD - REMOVAL)
2. Remove door glass retaining clips and secure the window in the up position using masking tape or equivalent(FRONT DOOR GLASS CLIPS).
3. Disconnect wire connector from power window motor, if equipped.
4. Loosen screws attaching front and rear window guide rails to inner door panel (FRONT DOOR MANUAL WINDOW REGULATOR - TYPICAL).
5. Remove screw heads on guide rails from key hole slots in inner door panel.
6. Loosen screws attaching regulator to inner door panel.
7. Remove regulator from inner door panel.
8. Extract rear guide rail through inner door panel rear access hole (FRONT DOOR POWER WINDOW - TYPICAL).
9. Extract front guide rail through front access hole.
INSTALLATION
1. Insert front guide rail through front access hole.
2. Insert rear guide rail through rear access hole.
3. Place window regulator in position on inner door panel.
4. Place screw heads on guide rails in position through key hole slots in inner door panel.
5. Tighten screws to attach front and rear guide rails to inner door panel.
6. Connect wire connector into power window motor, if equipped.
7. Install door glass.
8. Verify door glass alignment and operation.
9. Install sound shield and door trim panel
DIAGRAMS CAN BE FOUND ON JUSTANSWER,COM
Sep 02, 2012 | 1997 Dodge Grand Caravan
How to take out the thin line in my photocopy
If the line only happens when using the auto document feeder, clean the strip of glass to the right of the main table glass. If it is happening from both the document feeder and the table glass, you need to clean the main charge unit. Open the front door and remove the toner cartridge. There will be one blue screw holding the developing unit the toner cartridge slid out of. Remove the developing unit, and keep it level. Now open the side door and slide the drum unit out from the front of the machine. You will see the black plastic charge unit mounted to the top of the drum unit. Remove 2 screws and remove the charge unit. You will see a metal grid and underneath that a piece of metal with teeth running the length of the charge unit. Use a tooth brush and alcohol to clean the teeth and wipe the metal grid.
Jul 24, 2012 | Sharp AR-207 Copier
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I cannot find a way to open the compartment to change battery in mouse. Have pressed button and pushed and pulled - nothing
This help?? >>>>>>>>>>>>>>>
Where do I change the batteries for my mouse? I can't find where the batteries go.
Answer
This article applies to the following products:
All Logitech cordless mice
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, replace the battery door.
Mar 28, 2010 | Logitech Cordless Mouse
How do I remove the bezel from my hp l1955 monitor
There usually screws hidden behind stick-on plastic covers on the front and or edges of the screen. Use a sharp point to lift off these covers to reveal the screws.
The bezel will also have plastic catches/clips that secures the bezel to the lid as well as double sided tape. Slip a thin blade between the glass screen and bezel and gently lift the bezel free. Start at a corner and gradually work along each side.
Be careful not the apply too much pressure on the glass (it is easily cracked) and be careful not to scratch the screen.
Nov 15, 2009 | HP L1955 19" LCD Monitor
My lcd screen on my nokia n95 is cracked i know i need a new lcd screen but do i need anything else as well like flexi cables?
no puedo seguir colocando los drive del disco para que funcione mi telefono con las descarga de fotos al computador
Sep 17, 2009 | Nokia N95 Cellular Phone
HPcolor laserjet 2840 clicking with message "scanner bulb warming
Removal instructions:
1) unplug everything and move the unit to where you can work on it.
2) Remove the paper, and remove the hinged lid (tilt the lid to the up position and lift directly up and off).
3) Remove the push button cover which lifts directly off - straight up.
4) At the top of the button control module is a recessed release clip. Use a flat blade screwdriver and push down on the clip. While pushing down, slide the control button assembly down. lift the outside edge up (there are straight clips on the inside edge). Lift up slowly as the connection cable needs to be unplugged. the cable itself unplugs. Just pull down evenly grasping the top blue laminated section. The blue goes to the outside (contacts go to contacts on the inside). Set the button control unit aside.
5) Using a #10 Torx screwdriver, loosen the two screws in the back corners of the glass cover assembly. Lift the glass assembly up (like changing an ink cartridge), and pull the front lip left and right forward - there are two clips at these locations. Pull forward and lift up. Remove the glass cover assembly off and set aside. Note, tip over and remove the scews (best to remove and put back in after the cover is back fully in place). In reassembly, be sure to feed the control button cable back through the hole, and that it goes back into place the way it came out (including folding back into the slot under the button control assmebly).
6) The black plastic cover has two metal clips visible. These are not the release clips (they hold a glass piece in place under the black plastic cover). The release clips are outboard of these metal clips and are two slots. Insert a small flat blade screw driver, and push the handle toward the center. While prying, lift the cover at that end up, pry the other end and lift the black plastic cover off.
7)While you're in there, you might as well clean the mirrors (THERE ARE FIVE OF THEM)and glass. At the front of the lamp on the botton, the lamp wires lead to a white two piece plastic connector. Unplug the lamp wires. Where the lamp is, toward the front is a black philips screw in the clear plastic piece that holds the front end of the lamp. Remove this screw, and lift the clear plastic piece with the front end of the lamp up slightly, and then pull the full lamp assembly forward and out. This will open the space to the mirrors and glass. Use a Q-Tip and small pieces of paper towell and glass cleaner to clean the mirrors and glass strips. I tried to remove these to clean them, but the metal clips were too tight.. better to clean it all in place. BE SURE TO CLEAN THE EYE!!!!!
8) Clean the bottom of the glass top assembly.
9) Reverse the above to reassemble. Be sure to plug the lamp back in, and the button control assembly. Leave the black plastic cover off.
10) Place the glass top assembly back in place, and snap it down before dropping the screws in the back holes.
Don't know why, but you should be good to go.
After doing the above if in a few weeks you get the same msg again go back in there and take the black top off the housing that the mirrors are in and leave it off!!!! sound crazy but it has been working on a lot of the machines that come in here.
Jul 13, 2009 | HP LaserJet 2840 All-In-One Printer
Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Apr 16, 2007 | Neff H7871A2GB 800 Watts Convection /...
Miscellaneous Logo
98 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
