My son took the pump of my washing machine to see if it was working as the water wouldn't pump out, since putting in back my machine is now not doing anything at all, even the lights are very dull instead of being bright, any ideas please?
  • Washing Mach... Master
  • 5,323 Answers
Did he connect the hoses right? theres really not much u can do wrong in taking out and putting back in? did the propellers move on the pump freely
Posted on Mar 30, 2015
SOURCE: Hotpoint WMA 48, tripped house rcd, no lights on and water heating noise.
If you are not sure what you are doing, call out an engineer and have the job carried out properly with safety testing at the end of the job!
Posted on Dec 09, 2007
yalmer
  • 549 Answers
SOURCE: Fisher Paykel Wash Machine GWL11US
You may have to disassemble the pump from the line and the diverter valve and physically look to see what is happening.
It seems like you have a stuck valve or plugged one.
Posted on May 27, 2008
IB4G2008
  • 3587 Answers
hot drain pump? suggests that the pump is not being lubricated properly...
Posted on May 28, 2008
rickzilla
  • 706 Answers
SOURCE: Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Dec 06, 2008
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Fisher paykel gwl15 won't pump out water
My F & P Model GWL15 did the same thing. I purchased a new pump but that was not the problem. Tip the machine back and look under. There is a valve diverter that I removed and checked. There was a dime and lots of lint stuck in the valve so it wouldn't move back and forth anymore. I downloaded a parts manual, page 10 and item # 23 is the valve diverter. Once I unclogged it and put it back together, it worked great. I noticed it works better than it has for a long time. I'm a 60 yr old woman so anyone can do this. Good luck.
Oct 19, 2011 | Fisher Paykel EcoSmart GWL15
Hi I have a problem with my laundry machine.Its flooded and the water stays in the laundry machine and the water wouldn`t go away.We washed our clothes with three programs in a roll.And maybe thats the...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Aug 08, 2011 | Washing Machines
I have a Roper Washer Model # AL4132VW1 while doing a load of laundry yesterday my washer wouldn't remove the water. I tried all the cycles but it still wouldn't work. Do you have a idea what is...
Jul 25, 2011 | Roper Washing Machines
Kenmore model # 110.23832100 Washer would drain but wouldn't spin or aggitate. Replaced coupler. Now will spin and agitate, but will not drain.
sounds like it's in the re-assembly since the water pump is directly connected to what you just did. take it apart once again and make sure all is put back right and water pump is properly seated on motor shaft.
Jul 15, 2011 | Kenmore 23822 Top Load Washer
Water pump and ignitor do not work
took coleman away for weekend wouldn't work. Very dissapointed, was cold would have loved a hot shower. Had charged battery, when I went to start it. It wouldn't go, light come up as battery low tried it on car charger still no luck. Got home and looked up this site told me to try taking filter off pump and putting a long nail inside to turn pump to make sure it wasn't seized. And guess what every thing works well thank god, water temp was dodgy as well but now all good. Thanks to people that do reply to these sites, it has saved me a lot of money and frustration.
May 23, 2011 | Coleman Hot Water On Demand
It has FL on the machine
I've had this issue three times. On the first case, I found my external drain hose ( the hose from your washing machine to the drain in your wall) was clogged with a penny. The original external drain hose has a valve that keeps water from coming back into the washing machine. The penny had lodged in the vlave. On the second occassion, a piece of a hankerchief was caught in the drain pump. This pump has a "propeller" that pulls the water out of the washing machine and pushes it out to the external drain hose. I took it off the drain pump motor and tried to clean it. The original pump is solid and you can't take it apart to clean it. I did the best I could, then put it back on. It made a loud noise when draining. Whirlpool no longer sales just the drain pump, you have to buy a complete new pump and motor combo. It costs about $70 on e-bay (new). It is fairly easy to install (30 min). The good thing about the new pump is that you can take the cover of the pump off without taking the pump motor off. The third time I took the pumpef cover off and found a penny lodged in the pump. After taking it out, the machine ran well.
Note 1: A good way to drain your washing machine is to take a hose pipe and put it in the top of the machine and then use a manual air mattress pump (in reverse mode) on the opposite end of the hose that you put outside. After several pumps on the air mattress pump sucking the water through the hose, you will create a suction that will keep flowing until much of the water is out of your tub. Be ready with several containers to catch the rest of the water when you take the hoses off the pump.
Note 2: Check pockets well to keep things from getting into the drain system. Use a delicate wash bag (a mesh bag) to wash undergarmets, hose, hankerchiefs, and other thin items that might get sucked into the drain system.
Mar 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
