Question about Ovens
After a power failure about 1 hour and some minutes into a pyrolytic number 3 setting my screen read err 7 and my oven door won't open even though several hours have passed
  • Ovens Master
  • 5,323 Answers
You may need to re set ur clock
Posted on Apr 18, 2015
SOURCE: FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Posted on Sep 14, 2007
textonor
  • 130 Answers
SOURCE: Door locked after power surge/failure
The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
Posted on Jan 06, 2008
Master_Tech
  • 770 Answers
SOURCE: Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Posted on Apr 05, 2008
elhomspam
  • 58 Answers
SOURCE: Maytag MER5775QAS
Could be a couple things. If your machine is actually failing either a control board or an oven sensor.
Also measuring the temperature can only be done by a tech unless you have a special tool. Oven thermometers are inaccurate. Plus most ranges should vary temp between 50-75 degrees unless has a feature or the more recent ones keep it between 15-25 degrees.
Try the biscuit test, buy some biscuit, brand not important, i just say pillsbury. Cook exactly as recommended on package. If results are a little overcooked or a bit undercook try a feature called Adjusting the oven temperature or Calibrating the oven. This can be done by following the instructions in your book.
Maytag.com click support click manuals put in model MER5775QA (notice i took off your models S) open the Use guide, page 14
Posted on May 01, 2008
  • 177 Answers
SOURCE: miele pyrolytic oven: error 90
F90 is a faulty oxygen sensor. This fault clears after resetting your circuit breaker for 24hrs only. you will not be able to use any automatic programmes as the oxygen sensor measures the moisture in the air and then decides how long to cook for. You will need a Miele service technician or a registered service agent to replace the oxygen sensor. This should be covered under warranty but check with your local Miele dealer first.
Posted on Mar 19, 2010
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Smeg sca130p. Interlock wont release after running through pyrolytic cycle. Tried running through cycle again but still wont open hours after cycle completed.
Cut the power to it completely, so if its on a breaker, press the test button on that breaker. Wait 3 minutes and put power back on. Has it cleared the problem?
Dec 21, 2013 | Ovens
KITCHENAID OVEN MODEL KEMS 308 SELF CLEANING
Hi David.
The error is F5E1 and means door latch problem detected. This happened in consequence of the power cut while the unit was in self clean.
Try pressing and holding down the cancel button for one minute.
Try disconnecting power from circuit breaker for ten minutes, that will reset the control board.
If that does not work the door latch, wiring and control module must be tested and the defective part replaced.
Here full troubleshooting from Kitchenaid service papers:
1. If the door lock is latched:
  1. Disconnect power.
  2. Check wiring and connectors from control module to door switch, then from door switch to control (do a continuity test). If no damage to wires and all connectors okay, proceed to step 3.
  3. Replace the door switch.
  4. Re-apply power.
  5. Press and hold down any key down for 1 minute to clear the F5 failure code from memory. F2 will appear. Press CANCEL and wait one minute.
2. If door not latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps 1 and 2 for the door switch.
3. Measure door switch (door open =switch open - Ohms infinity/small low voltage terminals depending on test done- Ohms reading is done with power off). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If the problem remains, disconnect power and replace control module.
Regards.
Ginko
Jan 01, 2012 | Ovens
Viking deso175ss ran self clean cycle, tried to stop the cycle early. oven door locked wont reset. tried turning power on/off. was able to get door open by pushing latch to left, however it still will not...
Hello, welcome to FixYa.
I understand you have a Vking oven that is not unlocking after stopping (interupting) a self clean cycle, correct ? (I think the letters in the model should be "DSOE" as opposed to deso, aren't they ?)
Though this can cause issue's with the lock mechanism, it is unlikely anything was damaged...in my opinion of course, thus I don't think you need to start swapping parts.
If this hasn't already been done, I would suggest prepairing your oven as if everything was status quo for a self clean cycle.
Close the door, select self clean and let it go through it's start-up and lock sequence. Your going to stop it again, just as Viking instructs pressing "off" which should allow the lock mechanism to properly lock and then unlock.
During the clean cycle the unit usually has to cool before allowing for the door to open which can take up to 30 minutes, (this is why it counts down from 4 hrs even though the cycle is 3.5 hours) but since it should already be cool I'm hoping the lock will go a full revolution to it's normal position.
Normally these ovens will go through a self check sequence upon a power up (if power was lost and then restored...aka "onboard watchdog") which should include the lock assembly rotating to it's unlock position, but they can get out of sequence at times in my experience.
The other method I've tried and had success with is having a secone person hold the door switch closed while power is turned off and then restored a few minutes later.
Let me know if you have tried that and if not try it and get back to me. Hopefully that will restore it's proper function. Good luck.
Regards,
Macmarkus :)
Sep 07, 2011 | Ovens
F5 E1 error. Oven door won't open after running cleaning cycle
1.
If door latched:
  2. Check wires and connectors from control to door switch, then from door
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
5. If
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes.
F5 - E1
Feb 21, 2011 | Whirlpool RBS275PD Electric Single Oven
F5 error door locked
F5
- E0 Door switches do not agree (condition
exists when door switch is closed indicating an open door, and latch switch is
closed indicating a locked door) 1. If door latched:
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 27, 2010 | Whirlpool RBD275PD Electric Double Oven
I have a Whirlpool stove (model# RF385PXE)and I tried to start the self clean oven cycle the letters "door" appeared along with "E1" and "F5". The door is closed all the way. I even tried pushing it closed...
HI. This code is an indicating that the Self clean latch will not lock. Lock mechanism failure. follow the procedure below to address further.
1. If door latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
6. If failure remains, disconnect power and replace control.
Nov 16, 2009 | Ovens
Kitchenaid gas/convection stove oven door locked & won't open
F5 - E7 Self clean latch will not unlock
Remedy:
1. If door latched:
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
Note: Applies to all F5-E... codes.
Sep 17, 2009 | Ovens
FSE7 appears on kitchenaid built in oven
Here is the fault code for F5:E7...
1. If door latched:
  4. Re-apply power.
Sep 16, 2009 | KitchenAid Ovens
Beeping driving me crazy
Ok, the first issue is the oven temp sensor. it is shorted. you will need to replace this device asap. Now, the second is is concerning the Self clean latch. it is not functioning and it is unable to be locked by the control(shorted). Use the procedure below to test this device.
1. If door latched:
4. Re-apply power.
May 29, 2009 | Whirlpool RBD305PR Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
