Question about Paul Frank Projection Clock Radio Model: PF254
Pf 254 projector stopped working. How do I fix it?
Projector not working
    Top Expert:
  • Paul Frank Master
  • 74,106 Answers
The main power supply regulator section fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Jul 02, 2016
How to fix my ken wood PAC 130 ek, it stopped working and blinking PF code .?
PF will typically mean the unit has suffered a Power Failure necessitating a reset of the control. Turn the unit to the Off position wait a second or two and set it back to the mode you want and see if that helps.
Dec 24, 2014 | Filter Heating & Cooling
Why only 254 computers are connected in one network for ex:172.16.100.1 to 172.16.100.254
If we use class c network (192.168.x.x) we can connect devices up to 254 because in class c network first three are network positions. last one is host position. (network posotions 192.168.x host postion is x last one) In class B network mean 172.16.100 we can connect more than 254 because in this network ips are 1-254 after 254 hundred we can change to 101.
Note: In class B network 2 network and 2 host positions. network positions are fixed. Host positions are changeable. so we can change. like that class a one network position and 3 host positions. (ex: 10.0.0.0 in that 10 is fixed. remaining we can give as we like) but we cannot give 256 ip address to any client. because that calculations support up to 254 only
Jun 20, 2010 | Network Computing Devices (NSH800S/A)...
AVR 254 is not responding. None of its front panel buttons are working (except volume). Same thing with the remote. I noticed that in the front panel area, the speaker icons in the Speaker/Channel Input...
ok
The reason your receiver is causing you issues is cause of a 2 time Delay fuse's on the transformer board all you have to do is to by pass them.
Check the connector on the top front of the HDMI board. at the bottom of the connector it tells you the voltage of each wire the middle one is GND. should read 1.8v and 5.6v if the 5.6v line is dead. you key's in the front panel and sometimes video and audio as well.. will also stop working. all you have to do is to by pass them.
I will be posting a video later today on how to fix this issue. Regards,
Search for AVR 254/354 fix
Mar 16, 2010 | Harman Kardon AVR 325 Receiver
Need Bell & Howard projector owners manual , model # 254 R,
You need to call a camera shop that's been around for at least 30 years (they may have the lamp) or go on E-bay. There are lampsuppliers that specialize in these rare items but you will pay dearly for it; try to avoid them . goodluck, Macgivor
Oct 11, 2009 | Office Equipment & Supplies
Harmon AVR 254 No Video, No Sound.
ok
Mar 25, 2009 | Harman Multimedia AVR-254
Flashing pf
pf indicates power failure, even a slight glitch in the power can cause this. If stop/clear does not clear the fault, unplug the unit for a few mins. and plug back in. pf may reappear, again press stop/clear, this should clear the error at this point if it had reappeared. if not then further investigation will need to be done.
Thanks for using Fix Ya, please take the time to rate this solution
Feb 01, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Whirpool duet dryer stopped working PF signal
PF MEEN PAWER FAUILER SOME HOW YOU LAST POWER TRY TO UNPLUG AND PLUG BACK IN AND PUSH CUNCEL . IT WILL RESET THE BORD IF IT DOSEN;T YOU MAY HAVE A BAD BORD AND IS NOT TAKING COMAND
Jan 20, 2009 | Dryers
LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Jan 29, 2008 | LG WM1814CW Front Load Washer
Projector lamps for a eiki lc-5000
I say if the part fits into place identically as the original lamp.Go ahead and use it. An extra 10w will not hurt the DLP light engine.You might need to turn the brightness down a little. Let me know - edcarson
Sep 22, 2007 | Samsung TXM3281HF 32" TV
Paul Frank Projection Clock Radio Model: PF254 Logo
185 people viewed this question
Top Paul Frank Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Paul Frank Audio Player and Recorder Expert? Answer questions, earn points and help others
