What is wiring order on control pin for ba7800 sub woofer
SOURCE: Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Posted on Jan 17, 2008
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
likwidstate
  • 17 Answers
SOURCE: Logitech x-230 speaker system
Ironically enough, I went on here because I have the satellites but no subwoofer! LOL, what are the odds. Anyways, if you happen to receive this information, can you please email me at ben.petrofsky@live.com?
Like I said, I'm searching for the same exact information for a similar problem and this would REALLY help as I can't power the speakers without this.
Posted on Sep 02, 2009
  • 128 Answers
SOURCE: I am looking for a replacement of the volume
y do u opt for a replacment ? y dont u buy the cable its available at computers stores
Posted on May 29, 2010
multilinkent
  • 739 Answers
SOURCE: Picked up the woofer of BA7800 speaker system.
HI larrychaswor
If wired connection using a phone jack. if not, you need a lot of work to do but if you need also only be used woofer, you must reconnect to the controller itself, or you connect the woofer to amplifire then to a computer, that way you can control the audio is out of the woofer.
thnks®ards
Dengar Baca secara fonetik Kamus - Lihat kamus terperinci
    1. can
    2. may
    3. shall
    4. might
  1. kata kerja
    1. be allowed
    2. afford
    3. be permitted
Posted on Dec 10, 2010
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
Sub woofer is not working. it has orange flashing light at the back
Look at the connection of the sub woofer. The orange light indicates either there is some problem with the wire or the connector at the end of the wire.
Also make sure the pin or hole where you insert the sub woofer is working perfectly. You can simply check it by placing another sub woofer at that vary spot and see if it is working fine. If the hole is fine then the problem is either with your cord or your wire pin.
Oct 24, 2012 | Audio Players & Recorders
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Need cable to connect computer to BA7800 speaker system
YES, WHERE CAN I GET THE 3 PRONGED CABLE TO CONNECT MY SOUND CARD TO THE INPUTSON THE BACK OF MY BA7800 SPEAKER SYSTEM, OR JUST MAKE MY OWN WITH 3 GOLD TIPPED 1/8" CONNECTOR WIRES?
Jun 14, 2009 | Boston Acoustics (BA7800) Computer...
Install Boston Acoustic speakers BA7800 to a new Imac?
Partial Solution anyway - I just got a Mac Pro (2.66 Nehalem )and couldn't find the manual from my old Gateway 700XL. This is what I did: Plug the green wire into the analog output, and the pink wire (if you really need an external mic, but you shouldn't since our new computers both have a built-in mic) into the analog input. Just ignore the black wire. You won't have the 2 surround speakers, but I'm still looking for a fix for that. I got tired of the crappy speakers in my new Apple Cinema display (the ONLY crappy thing about my new system). As you know, the sound from the BA7800 is great, even with just the two front speakers and sub-woofer. I'll keep you posted if/when I figure out how to set up the surround speakers! Likewise, if you hear something, please post here and I'll keep checking back.
Apr 10, 2009 | Boston Acoustics (BA7800) Computer...
Sub woofer speaker wire
Probably an RCA Pin plug
Jan 02, 2009 | JVC RX-552V Receiver
Need wiring and 9pin connector diagram
Pin 8 = Power A
Pin 9 = Power B
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
145 people viewed this question
 Grubhead
Grubhead
