Question about Air Tools & Compressors
I need the drain screw at the base of the tanks
    New Friend:
  • 29 Answers
Andy...
What tank? You didn't provide any pertinent info such as manufacturer or model!
See the link below. I don't know if it will fit your model... cock-p-432052.html">Thumb Screw Drain Cock
I personally used fittings and brass tubing and routed mine to a handy location not so close to the ground... but then I'm getting old.
Posted on Mar 31, 2015
What is the best way to refill a sealed radiator unit for 1998 ford f150
When engine cold, Unscrew the radiator cap on the expansion bottle and top up the coolant level to the minimum level marker, then replace the radiator cap.
Nov 22, 2015 | 1998 Ford Contour
Can't locate fresh water tank drain valve on 29X
Should be at base of tank. Crawl under and look for small 1/2 hose pointing straight down. This should be the drain line. Follow it back to the tank. Valve will be there somewhere.
Apr 20, 2013 | Thor Motor Coach 2013 Hurricane 29X
My oil reservoir is leaking
The grey plug in the base of the oil tank is the oil filter it will twist 1/4 turn and pull out, to replace push back in and turn 1/4 turn there is a leg on it that locks into the orange tank, there is a screw driver slot in it to assist this, they can be really tight try not to force too much or you will break it.
Jan 14, 2013 | Husqvarna 450 e-series 18" Chain Saw
1988 hurricane wont start cold
Instructions
    • 1 Lift the CBR onto its center stand. Unlock the seat latch with the ignition key and remove the seat. Remove the clip screws from the top portion of both seat rail covers, positioned below the fuel tank and the seat, using a Phillips screwdriver. Pull the seat rail covers away from the motorcycle's frame.
    • 2 Remove both bolts from the front of the fuel tank, using a socket wrench and a 10 mm socket. Lift the tank up and prop it open using the support rod on the motorcycle's frame. Reach under the tank and unplug the fuel pump's wiring connector and all three hoses from the bottom of the tank. Take note of hoses' locations before removing them for reinstallation purposes. Pull the hairpin clip out from the support rod's base. Unscrew the pivot bolt from the base of the fuel tank, using a 10 mm socket. Lift the fuel tank off of the motorcycle.
    • 3 Unscrew the air box's mounting bolt from the frame's right seat rail, using a 10 mm socket. Loosen the clamps securing the air box's flanges to the carburetors' inlets, using a Phillips screwdriver. Pull the air box towards the rear of the motorcycle to separate its flanges from the carburetors.
    • 4 Loosen the clamps securing the carburetors to the motor's intake manifolds, using a Phillips screwdriver. Pull the carburetors off of the motor and out through the left side of the motorcycle's frame. The carburetors will still be attached to the motorcycle by its throttle and choke cables. Loosen the choke and throttle cables' lock nuts, using a 10 mm wrench. Remove the cables.
    • 5 Hold the carburetors over a large container. Unscrew the drain screws on the side of each carburetor's float bowl, positioned at the very bottom of the carburetor, using a flat-head screwdriver. Allow the fuel trapped within the float bowl to drain completely, then tighten the drain screws.
    • 6 Flip the carburetor over, with the float bowls up, and place it on a clear work space. Unscrew the bolts from the float bowls, using a Phillips screwdriver, then pull the float bowls and their gaskets away from the carburetors.
    • 7 Unscrew the pilot jet from each carburetor, using a flat-head screwdriver. The pilot jet is placed to the left (with the carburetor facing you) of the main jet in the center of the carburetor. Screw a new pilot jet into place with a flat-head screwdriver.
    • 8 Reinstall the float bowls and their gaskets onto the carburetors. Tighten the float bowls' screws with a Phillips screwdriver. Reattach the throttle and clutch cables to the carburetors and tighten the cables' lock nuts with a 10 mm wrench. Slide the carburetors through the left side of the frame. Push the carburetors into the motor's intake manifolds. Tighten the intake manifolds' clamps with a Phillips screwdriver.
    • 9 Pull the air box against the carburetors and push the air box's flanges over the carburetors' inlets. Tighten the flanges' clamps with a Phillips screwdriver. Screw the air box's mounting bolt onto the frame's right seat rail, using a 10 mm socket.
    • 10 Lay the fuel tank onto the motorcycle's frame. Insert the tank's pivot bolt through the hinge at the base of the tank. Screw the pivot bolt's nut into place, using a 10 mm socket. Lift the tank up and reattach the tank support rod to the motorcycle's frame. Insert the hairpin clip into the support rod's base. Prop the tank up on the support rod. Plug the wiring connector into the fuel pump and reconnect all three hoses onto the bottom of the tank. Screw both mounting bolts onto the front of the fuel tank, using a 10 mm socket.
    • 11 Mount the seat rail covers onto the motorcycle's frame. Insert and tighten the covers' clip screws, using a Phillips screwdriver. Lay the seat onto the seat rails, then press the rear of the seat down until the seat latch locks into place.
Jan 14, 2013 | 1988 Honda CBR 1000 F
How do I change the oil on my push mower?
HI,just open the tap screw at the base of the oil tank and drain the oil.
Jun 22, 2011 | Garden
I NEED TO DRAIN FUEL TANK MYSELF, HOW CAN I DO THIS BEST
To drain fuel tank:
plan your safety have fuel tank almost empty un-attach the fuel lines and strangle them remove all screws holding fuel tank slowly bring fuel tank down drain contents by flipping the tank over if you wash it make sure it is completely dried before putting the tank back
Thanks
Jun 02, 2011 | Ford Transit Connect Cars & Trucks
Will not drain
Sounds like you drain pump as blocked. first remove the water from inside by hand, then look and see if you can remove a cover over the drain pump will be 1 screw. If not then you will need to remove the front kick plate should be just 2 screws then remove the inner panel to access the drain pump. It either has 1 screw and then twists out or has 3 screws and pulls off. but they can still be awkward to remove either way. Or if you want you can pull the machine out and lay it on its side and remove the bottom panel, this will allow you complete access into the base of the machine. The base should come off with 2 screws at the front and then clips of. Hope this helps
Mar 21, 2011 | Whirlpool Dishwashers
I need to drain my Honda Activa petrol tank as I need to transport it to Bangalore. How do I do this.
Shut off valve at the bottom of tank. remove fuel line from carburetor and point it into an approved fuel container. Open fuel valve and drain tank. If you have a reserve setting on your valve, turn it to that to get all the fuel out. Then, look the the bowl of your carburetor. At the bottom there is a small drain line. Above that drain line is a slotted screw. Point that drain line into a container and turn the screw left to drain the fuel out of the carburetor bowl. Retighten the screw after it drains. Place your fuel tank valve to off.
Nov 23, 2010 | 2005 Honda Activa
Air Tools & Compressors Logo
63 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
