Question about Maytag MHW6000XW - MaximaTM High-Efficiency Front Load Washer
Need help fixing the soap dispenser as my husband inserted it not aligned by accident. anyone had this issue. E2f6 code is also occurring.
Whirlpool Duet with precision dispenser. My soap dispenser is not dispensing. Any ideas on what would cause this?
This could fix the problem but take the dispenser out and clean it . Slot of times it gets built up with soap and stops working
Oct 08, 2015 | Washing Machines
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
Soap tablet dispenser not opening
Depending on your type of dishwasher --------plastic parts break and you need to get into the door to see if the mechanism for the soap latch is broke. Sometimes you can see the parts that need to be fixed and --- it may be just a screw that you can insert into the plastic stem to make it work. You can find your diagram for parts online - maybe and get the parts you need or call a repairman to help.
Mar 03, 2014 | Dishwashers
Blinking light
The issue is the dispensing unit you have is a sanitizer dispenser, not a soap dispenser. The adapter collar on the bottle is the issue. Soap dispensers use a GRY collar, sannitizers use an LBL collar. There should be a sticker on the dispensing unit that says "LBL" or "GRY". Try removing the collar from a sanitizer bottle and place it on your soap bottle......should work fine. In short, make sure your letter code on the bottle mathces the letter code on the dispenser.
Jan 30, 2014 | GoJo Purell 2720-12: TFX ? Touch Free...
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Leaves detergent in despencer tray
Most of the time this is a dispenser housing issue. Remove the dispenser tray from washer and make sure it is cleaned very well. In the more serious clogs, you may need to clean the hose from the dispenser to the drum.
  1. Make sure the detergent dispenser drawer is opening. This issue occurs due to jammed soap dispenser. Dispenser Distribution System is located in the top left corner of the washer. The system consists of a motor that turns a cam gear. The Detergent Dispenser Assembly is located under the washer top. Begin by removing the washer top, console and front panel.
  2. Separate the water inlet and window washer tube from the boot. Pull the water inlet tube from the outlet connector of the detergent dispenser. NOTE: When reinstalling the water inlet tube, wet the water inlet gasket on the detergent dispenser with water only. Do not use any other lubricant. Align the tab on the water inlet tube with the indentation on the dispenser connector and slide the tube onto the detergent dispenser assembly.
  3. Remove the screw securing the front of the detergent dispenser assembly to the top front frame member.
  4. Disconnect the vent tube from the detergent dispenser assembly. Remove the screw securing the detergent dispenser assembly to the top left frame member. Slide the assembly back slightly and lift the assembly out.
  5. To remove the detergent dispenser motor assembly,disconnect the cam follower spring and lift the cam follower from the diverter cam and rotate the diverter cam clockwise to access the motor mounting screws. Check for all the connections to the dispenser motor or anything obstructing the dispenser drawer functioning.
  6. Pull the diverter out and clean it, including the shaft, spring, etc.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Soap dispenser door pops open
Try cleaning the compartment. If the latching is not OK, it could be a latch problem, or alignment, or total dispenser. Contact service provider for assistance.
May 26, 2010 | Maytag MDC4650AW Built-in Dishwasher
I have a Simple Human 14 oz sensor Soap Dispenser
This is what I found in the Simplehuman FAQ's. I had to wait about 30 minutes for the light to stop blinking, but it seemed to work for me.
If the pump is unresponsive or the blue light is flashing, fresh batteries should resolve this issue. Please power off the pump completely. Once the pump is turned off, remove the old batteries. Please wait for the pump to reset (until the flashing light stops and preferably letting it rest overnight) before you install the new ones.
Aug 05, 2009 | Kitchen Appliances - Others
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
Cannon powershot a570
THERE HAS BEEN SOME LUCK WITH THE FOLLOWING SOLUTION. YOU SAY THE LENS COMES IN AND OUT. DOES IT COME ALL THE WAY OUT AND STOP? DOES IT GO ALL THE WAY IN? THE SOLUTION THAT HAS BEEN MENTIONED FOR THIS TYPE OF PROBLEM IS TO APPLY GENTLE PRESSURE ON THE LENS WITH THE CAMERA ON TO TRY TO HELP THE LENS
ALIGN ITSELF AGAIN. THAT IS TO GENTLY PULL ON THE LENS ON THE WAY OUT AND GENTLY PUSH ON IT WHEN IT GOES IN. THIS MAY HELP ALIGN THE LENS WITH THE GEAR TRACKS. THIS IS NO SURE THING, BUT A POSSIBLE FIX THAT HAS WORKED ON SOME CAMERAS. DROPS ARE ******* DIGITAL CAMERAS. I REALLY HOPE THAT THIS HELPS AND IF I CAN BE OR MORE HELP REPLY TO:ARCLIGHT1217! IF THIS IS HELPFUL, PLEASE VOTE! THANKS! REMEMBER,IF THIS HELPS EVEN SOME, REPLY AND I'LL SEE IF I CAN HELP YOU MORE! OK?
Nov 15, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Maytag MHW6000XW - MaximaTM High-Efficiency Front Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
