Question about Dryers
What part provides power to coils to ignite gas, and what would cause the igniter to suddenly shut off after five minutes?
Drum turns upon hitting start button, but get no coil heating on most of the positions on heater control: automatic or timed dry
  • 4 more comments
  • Jay Wartell Mar 29, 2015
    Please see my comments below, both coils seem to be OK
  • D. E. Hev Mar 29, 2015
    The test is do they have power to them when they shut down if so it is a coil and they are usualy in series so when one goes open it shuts down both What Make and model is it?
  • Jay Wartell Mar 30, 2015
    Follow-on to above D.E. Hev answer: Kenmore 110.74972300.(10 yrs old)
    I have the parts diagram. Is schematic on inside of back panel. Will running it with missing lwr frt panel cause it to shut off? If I wait ~ 30 m +, it will start up OK, but shut off in 3-4 minutes. "Coils tested OK for low resistance
    Don't know how to get VOM test leads on the "coils" while connector is plugged in. Do I have to open up upper rear panel to get to Timer control output jacks?ed it
  • D. E. Hev Apr 02, 2015
    That would be easiest and there is usualy a wiring diagram in the machine
  • Dryers Master
  • 5,323 Answers
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Posted on Apr 03, 2015
Testimonial: "Jhonny Rendon, Wow! Your comments were terifi!. It turned out my problem was confined to the coils. What surprised me was that when I applied AC directly to the coils, my analysis was that the three terminal coil was bad, and the two terminal coil OK, based on the sound of the response: 2 terminal- could hear the clank of the gas valve opening or closing 3 terminal-just a buzzing sound, thinking it was bad. The new parts gave exactly the same response to direct AC, I thought I had a bad gas valve assembly. WRONG! Everything worked great when I turned on the unit. I never had to take off the rear cover of the dryer, which probably had the schematic and some of the active thermostats. The air flow out of outside exhaust vent was very strong, so I was sure I didn't have any lint build up blocking the flow. My ancient VOM only gave a rough estimate of resistance of coils, around 800 to 1K ohms. Being able to see the igniter glow red, and then see the gas flame up helped my understanding of the functioning of the igniter, fire sensor, and gas valves. My summer house has a gas dryer that doesn't work in auto mode, only timed dry. I'll spend some time looking for the sensor that controls it and buy a replacement. Thanks for all the info in your reply. Retired-lucky"
  • 1 more comment
  • Jorge Rendon
    Jorge Rendon Apr 06, 2015
    yOUR WELCOME HAPPY TO HAVE BEEN ABLE TO HELP U. AS FOR UR AUTO MODE VS TIMED MODE DRYING? n timed dry power is usually directly from the line. In auto modes it often gets power through the heating element when the element is turned off. There is usually a resistor in the circuit that reduces the 240 heater volts down to 120 volts for the timer motor.
  • Jorge Rendon
    In the above type dryer if the element is grounded it never shuts off so the auto cycle does not advance.
  • Jorge Rendon
    Also could be your temperature selector switch has a set of contacts welded together.
    Genius:
  • 1,179 Answers
Coil is probably bad, they get a crack in them and will not work. If you have a an ohm meter you can disconnect power and check it
Posted on Mar 29, 2015
Testimonial: "D.E. Hev, Thanks for the quick reply! Do I have to open up one of the power leads and then measure resistance? Also parts diagram says I have a dual coil setup: 2 terminal main, and 3 terminal pilot. Buy the $20 Coil Kit?"
  • 4 more comments
    I checked both coils after removing connectors and get continuity( very low ohms) on both. What next?
    But if they ignite and then go out the coil could still have a crack tha opens up only when it gets hot or you could have a faulty heat sensor that is turning it off
    Check to se if you are getting power to the coil when you turn it on, if it is then shutting off after it heats up
    You say that in your original post it shuts off after heat up if so I would lean towards a cracked heater and if it is only 20 for both as a kit your getting off cheap, mine was 48 for one
    D.E. Hev, pls read my follow-on new question. What is called a "coil" seems to me a solenoid, which turns on current to a glow coil at the tip of the burner assembly.
    D. E. Hev, u wrote me "But if they ignite and then go out the coil could still have a crack tha opens up only when it gets hot or you could have a faulty heat sensor that is turning it off"
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Maytag DG482 Dryer Won't Heat
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor
a%20igniter.jpg Ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils
part# 279834
The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks. SOURCE
Jul 07, 2009 | Maytag Dryers
Gas shuts off/flame off w/in minutes of starting maytag gas dryer
If you did all the things listed, there are only 2 left that will cause the problem. The cycle thermostat located on the exhaust vent and possibly poor airflow. Remove the connecting vent from the rear and try a timed load. If it works repair the vent exhaust problem. Most cycle thermostats include a thermister that could also be defective causing the short cycle. The flame sensor and gas valve coils would have been the number 1 diagnosis. I would need a model number to more specific.
Jun 14, 2009 | Maytag Dryers
No heat it starts but the igniter doesnt light the gas
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jun 02, 2009 | Dryers
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Maytag Gas Dryer SDG515DAWW - heating stopped
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
Jan 03, 2009 | Dryers
My Kenmore series 80 dryer quit heating. It was intermitent for a few days then quit. I checked the inspection window and didn't see any light. The gas it on and it seems like there is a "click" after I...
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.6aed02c.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
Dec 22, 2008 | Kenmore 659 Electric Dryer
Kenmore gas dryer model 110.76814690 will not heat up
The bottom panel is held on by spring clips. Use a putty knife to access the bottom. The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.8f17134.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils NOTE: The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
Dec 21, 2008 | Kenmore 63942 Dryer
Gas dryer don't heat, pilot ok
The ignitor is coming on so that means you have power to the gas assembly. Next the flame sensor should shut down the ignitor when the bi-metal inside it bends from the heat. This kills power to the ignitor, which allows for the power to activate the coils. The coils snatch open the gas valve and allow for ignition. The raw gas hits that screaming hot ignitor and ignites into a glorious flame, raising the temperature inside the drum. While that flame is on, the control thermostat is monitoring the heat within the drum. When the temperature gets to a round 140 F then the power gets killed to the gas assembly by the control thermostat. If all of that seems to be happening for say, the first time, then suddenly the ignitor comes on then shuts down and no flame comes out, then you have weak and intermittant coils. Replace these puppys:
Dec 16, 2008 | Dryers
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
Top Dryers Experts
