Question about Bissell Brushroll Proheat 2X 8920 9200 9400
What is wrong with the top where the water goes will not set back into the cleaner
  • Kay Benjamin Mar 29, 2015
    it is a carpet shampooer
Part fell off and I don't know where it goes, red square
It covers the inlet to the vacuum motor so then the dirty water tank fills it blocks the port so water doesn't get in. It goes in the top cover where the lint screen is.
Oct 13, 2016 | Bissell ProHeat 2X Select Upright Deep...
Please assist. i have not use my cleaner in awhile not sure if the clean water goes in the top or bottom.
The clean water goes in the upper tank mixed with shampoo, and after the water is extracted from the carpet, it will go into the lower tank. Clean water top tank, dirty water lower tank.
Hope this helped you!
Chris Jones
GoVacuum.com
May 13, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Can not attach top back to bottom
Water pump on vacuum? steam cleaner / carpet cleaner? You have gotten something out of alignment. Check seal and make sure to have everything else in place before trying to screw back together
Mar 07, 2010 | Bissell Vacuums
How does the red thing fit back into water tank
if that doesn't come up, type in bissell water tank into google & then select 'images' from the results. The large rectangular block of plastic is inside the tank between the clear plastic tabs. The long red plastic stick with the 2 tabs goes on top of the lid
Dec 12, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a billell Pro Heat 2X without a manual. How do I fill it and what ratio water to cleaner?
The cleaner goes into the small bottom at the very rear of the machine. It is uses full strenght (don't add any water to it). You add clean water into the bottom clear plastic section on the front of the machine. The clean water bladder is soft plastic and it is filled from the top. When you start using the machine, the dirty water will get suctioned into the section surrounding this bladder. The machine will stop working when either the bladder is empty or the dirty water section is full. Remove the entire plastic section to dump out the dirty water.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Where do you put the soap cleaner, does this go
The cleaning solution goes in the top tank. Fill top tank with hot water first, then add the cleaning solution. That way it doesn't foam up. The tank lid is also a cup to measure how much solution you put in. Usually fill to top line. Make sure when you put tank on machine it snaps in place. if you have a manual, refer to it for instructions if you need to.
Hope this helps.
Sep 14, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have the 8920 bissell proheat steam cleaner. i
You must have a suction problem. Try checking the lint filter, which is located in the top clear plastic section (the section that goes on top of the bladder section - it has the dial to switch from floor to tool use). There is a small plastic lint filter (about 1 inch square) with a little door on it (on my model it is red plastic) . Open the door, remove the hair or whatever is clogging it and hopefully your problem will be solved. And the lady you got it from is correct, the dirty water is stored in the area that surrounds the clean water bladder.
Sep 07, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not sucking up water
Hi.  I had the same problem.  After looking at the manual I went back and made sure the canister was making a proper seal.  That fixed the problem.  Make sure when you put the top back on the canister (that holds the dirty water), that you place the two front hinges in  place first and then snap the center clap on the back of the top.  This will give you a proper seal for suction. (My two front hinges weren't fitting correctly.)
Oct 25, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Does the cleaner solution go in small tank. Should the little tube be down in solution?
http://www.bissell.com/Product_Search.aspx?Criteria=1699
Above is a link to bissell.com where you can get the full user manual. But to answer your questions, the cleaning solution does go into the small tank with the tube, the tube should be arched and go to the bottom corner of the small tank. Clean hot (not boiling) tap water goes into the inner bladder of the big tank. Fill it till you can see the water near the top.
Oct 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Bissell Brushroll Proheat 2X 8920 9200 9400 Logo
37 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
