Question about LG Washing Machines
What may be the causes of a leak in the front left corner of my LG washer model WM2050CW
I'm thinking that it's the bellow/hose part # 4738ER1002A which leads to the small drain hose at the front of the washer. Looking for a answer before I take the whole washer apart
  • LG Master
  • 2,160 Answers
The lint filter is fully screwed in?
Posted on Mar 30, 2015
My LG front load washer won't drain model#WM2050CW how can I fix that?
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Mar 14, 2015 | LG Washing Machines
I would like to know how do i stop the water from leaking at the bottom i have a LG WM2050CW 40 cu ft washer
wow more specific please. Sure its not leaking from the top and running down the sides inside the cover panels? If not hose leaking and or pump.
Dec 17, 2013 | LG WM2050CW 40 cu. ft. Washer
Water is coming out from the bottom
Water leaking out from the machine can be caused by a number of problems:
Check the drain pump hoses for condition and security, check the tub seals and also door seal.
We have a LG WM2050CW and today after it went the rinse cycle it drained all over the basement floor, underneath the washer and then came out of the door.
sounds like you might have a broken hose or a loose hose. remove the back panel from the unit and inspect the plumbing. also -- while you are doing the inspection - pull the pump screen/drain plug and clean out any debris that might be in there ( you will need to do this sometime anyway ).
if you are still having troubles -- please feel free to write me back here and I will do my best to walk you through it.
c...
Feb 16, 2011 | LG WM2050C Front Load Washer
My wash machine has a bellows part (4738ER1002A) that is leaking and I took it out. Sure enough it has a tiny hole in one of those accordeon style grooves. If I use silicone sealant will it hold up (at...
Ok, well as long as you get a "Glue" that actually "Melts" into, the existing material, much like a water bed glue/sealer, you will be OK, for a bit. IF you can get inside, then do the repair inside that way the water is pressing it harder against the wall, Just do a couple of "Layers" with the last, patch, bigger than the one underneath, and glue all round the margins, let set, and do the other layer(s) Use really good solvent waterproof glue...sealer silicone...
May 02, 2010 | LG WM-0532HW Front Load Washer
Water leaking at time the washer is being filled, not during wash cycle. Leak appears to be starting a bottom left side of the machine toward the front from the middle of the side. Observation does not...
you say water only leaks when it fills correct? am wondering if its the hose that feeds in to the washer
this would be from the inlet solenoids check the clamps in the machine.
Dec 02, 2009 | Kenmore HE2 Plus Front Load Washer
LG WM2355C water leaking under machine after washing finished.
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Jul 23, 2009 | LG WM2277H Front Load Washer
Duet washer leaking
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
Sep 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
Washing Machines Logo
57 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
