Question about Epic Exercise & Fitness
Just bought a new Epic a30t treadmill. It was already together at Dunham's. Brought it home pluged it in and it won't do anything but show a loading bar going across the screen. I need help please!
    Genius:
  • 1,168 Answers
5 Suggested Answers
SOURCE: new free spirit treadmill - L5 code what does it mean?
Yeah - the sensor is the problem... It is magnetic... You can find it next to the wheel on the belt - It is fairly small.... There is a metal disc in the wheell on the belt that is a magnet.. As it passes by the sensor - the sensor registers the magnet and can simply calculate speed based on the frequency of the passes... Sometimes the sensor slides too far back and ergo can`t register the magnet passing by - Then you get the L5 error...
Follow this link to a picture!
http://www.angelfire.com/nm/nickm/freespiritl5.html
Posted on Jan 18, 2011
  • 44 Answers
SOURCE: treadmill won't run the screen is showing E7
You probably need a technician to look at it. I would say the motor that runs the treadmill is faulty due to a fuse that has blown you would have to locate where this is first replace it and proceed to the nxt step. I say you may need a technician cos often you are dealing with mains power or small dc voltage in any case one should carry this out in a safe way.If you are not confident ring a professional Tech.
Posted on Dec 13, 2011
  • 1212 Answers
SOURCE: healthrider s300i treadmill does not turn on
Check the fuses under the lower hood. One should be a 10 amp fues, the other should be 15 amp fuse.
Replace them if blown. If they should blow again, move the treadmil to an outlet closer to the fuse box/breaker box of the house. the house wiring where you have the treadmill may not be adequate for the treadmill.
Posted on Jan 24, 2012
Testimonial: "Thank you! That was exactly the problem... lol. "
ercupa190
  • 12223 Answers
SOURCE: where can I have a new balance 1500 treadmill repaired. I need to have wires replaced or spliced together.
you must have from www.fitnessrepairparts.com and buy it.or www. treadmillpartszone.com
God bless
Posted on Jul 03, 2012
EPIC 400 tread mill starts but slows down &blows breaker moter run fine with no load belt backed off re set speed sensor changed power cord pluged .in to circit board ran fine for 2 hrs then stoped
motor brushes are bad. when they wear out, the motor loses torque and draws more amps. they can be replaced fairly easily once you get the motors out.
Oct 03, 2015 | Epic 400 Mx Treadmill
My treadmill wont re-boot
follow this steps and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 11, 2013 | Epic A30T Treadmill
SPEED OF TREADMILL ACCELERATES
please RUN the software calibration go under the HOOD motor and see the instruction, for easy diagnostic and fix it.
God bless you
Jul 10, 2013 | Epic A30T Treadmill
HELP! MY TREADMILL WILL AUTOMATICALLY CHANGE SPEEDS TO THE HIGHEST SPEED EVER. ITS INCREDIBLY TERRIFYING!
please RUN the software calibration inmediately, for easy diagnose and fix it. However adjust the speed sensor, clean it, test for open or fraulty, tight the connector very well.
Jun 06, 2013 | Epic Exercise & Fitness
My treadmill will not connect to wifi.
go to https://www.ifit.com/install
install that update and try again, this will be fix it.you will need adobe go
http://get.adobe.com/air
God bless you
Jan 14, 2013 | Epic A30T Treadmill
How to connect Epic A30T to Ifit
Dear Sir: Will be a Great idea that you connect with the next LINK and contact them.
http://support.ifit.com/home
or You can download FREE your instr. manual and follow the steps very easy. go to www. fitness.manualsonline.com
God bless you
Dec 07, 2012 | Epic Exercise & Fitness
Just brought 2Tb iomega hard drive, got home, pluged in, status light stays flashing and windows doesn't pick it up... Roy
> just brought ...
Just take it back to where you bought it, and get them to show you that it works.
If it does not work, they will replace it.
Dec 14, 2010 | Iomega 2TB Prestige External Hard Drive
Freespirit Treadmill
Did you try it before you bought it and it was working. when you move the unit and pluged it into the wall outlet was it on? if yes then you may have damaged the lower board. If you can not get that part then the treadmill has died. Is it a Bowflex or a Free spirit.
Nov 21, 2008 | Bowflex Treadmill Series 7
Exercise & Fitness Logo
142 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
