Question about Pioneer Car Audio & Video
I have a Pioneer AVIC-7000NEX. When the reverse camera comes on the image is backwards and I get "Caution The video may appear reversed" is there a setting I have wrong or is something wired wrong? Any advice is welcomed.
shawnsz
  • 64 Answers
SOURCE: Pioneer AVH P6500DVD/AVIC 80DVD Installed.Pink Purple Green Wire?
can you take the black cage off or maybe you can take a screw driver and bend it back up
Hope this helps
install manual
owners manual
Posted on Feb 19, 2009
SOURCE: To fix the pitch black screen
just take the positive cable off your battery and that will reset in to the factory settings and that should fix it
Posted on May 13, 2009
SOURCE: caution screen image may appear reversed
hello, when i turn on the cd.player, in just few seconds this text comes: caution screen image may appear reversed(and the screen is black)....when i touch the screen with my finger, it disapperes for a few sec. what is this??
Posted on Dec 08, 2009
SOURCE: Hi, In my Pioneer Avh-P3100Dvd' s screens appear
hi boss my nokia 3230 do restsrt & hanging problam
Posted on Mar 01, 2010
SOURCE: pioneer avh-p5000 dvd'
try going to the menue screen. bottom left hit rearviewcamera. then just hit radio or dvd ect. this is a feature that is designed to view something you may be towing while driving.
Posted on Apr 08, 2010
Caution: screen image may appear reversed
Keep the mute button pressed for 10-15 seconds. It will return to normal. Then go to the settings, find camera polarity and turn it off.
Apr 24, 2012 | Pioneer AVHP4200DVD Car Video Player
Pioneer system says caution: screen may appear reversed? was working all day i went to walmart and it was fine then as i started my car when i was leaving this appeared with a black screen
That is the message you get when you are connected to a backup camera. When you put the car in reverse it will switch automatically if you have the reverse trigger hooked up. you can also switch to the camera while driving and use it as a rear view cam. Some backup cameras actually reverse the image while some do not. If you don't have a backup camera you need to turn that source off and it will stop appearing. I had the same unit in my car with the camera and it was great. Pioneer makes a nice camera but you can find a number of them from other makers that are just as good.
Mar 14, 2011 | Pioneer AVIC-D3 Car DVD Player
My Pioneer car DVD player shows Caution: Imiage on screen may appear reversed. What does this mean will not play movie DVD's. Can you help.
That message has everything to do with a back-up camera. Ensure you have not connected the reverse wire to a source if you aren't using a camera. Some cameras are reversed so that's why you are getting that message. As far as the DVD goes, the emergency brake wire (lt. green) needs to go to the e-brake wire on the vehicle. You cannot just ground the brake wire because most Pioneer video units have another method of preventing you from watching a movie while in motion. Maybe you have confused the reverse wire for the brake wire? Youtube has videos on how to do a video bypass...
Jun 06, 2010 | Pioneer AVIC-D3 Car DVD Player
My pioneer double din screen says ''Caution, screen image may appear reversed''...how can i solve this problem?
As you know, you can use this DVD AV Receiver with a rear view camera. And also it can be installed to switch automatically from the video to rear view image when the gear shift of the car is moved to Reverse position.
But it is important to use a camera which outputs mirror reversed images.
Otherwise the screen image may appear reversed. And this means that you will see the rear view reversed in the monitor. And that may cause accicent and injury.
To solve this problem, first check your rear camera whether it has the capability to output mirror reversed images.
If it is, then check the wire connections of the rear camera using the operation manual or ask a technician.
Also check the settings of camera polarity if it is set properly or not in the system menu when connecting the rear view camera.
You can download the operation manual (pdf file) by clicking here.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 11, 2010 | Pioneer AVH-P4000DVD Monitor
Mar 01, 2010 | Pioneer AVIC-D3 Car DVD Player
Caution screen image may appear reversed
Sep 27, 2009 | Pioneer AVH-P5000DVD Car DVD Player
No video screen
If you can touch the screen and get the menu, then after 15 seconds or so, it goes back to the 'images may appear reversed' message, here is what you need to do....
1) Touch the screen to get menu
2) Touch the "Rear View" button (lower left of screen)
3) It should beep, but not change from menu view.
IF it changes instantly to the 'images may appear reversed' screen, repeat steps 1, 2, 3.
This should fix your issue.
Mar 12, 2009 | Pioneer AVH-P4000DVD Monitor
Car Audio & Video Logo
176 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
