Question about Deck Monitoring DECK CM5YE111 All-in-One Solar Monitoring Package - UL Listed - 5
Where to buy new rubber seals for soltam 6L pressure cookers
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
I need a rubber seal for my pressure cooker model 99700 ELECTRIC PRESSURE COOKER
4 quart cooks essentials pressure cooker - YouTube
? 7:04
www.youtube.com/watch?v=JIGVz1HcDlc
Jan 6, 2012 - Uploaded by wtbm123 My magic pot. ... Electric pressure cooker that has a timer so u set it and... ... without some kind of water ,it would not make enough pressure to seal the pot . .... I cant find one online anywhere, is there another model that fits?
Cook's Essentials PRESSURE COOKER - Fixya
www.fixya.com/support/t318063-cooks_essentials_pressure_cooker
Cook's Essentials PRESSURE COOKER WOULD YOU KNOW WHERE TO GET A NEW GASKET FOR CEPC600S PRESSURE COOKER? ... part,, pressure regulator knob cooks essentials electric pressure cooker model # 99700 5 qt. ..... Looking for a replacement gasket for my 10 qt Innova model 42010 pressure cooker.
Oct 27, 2015 | Kitchen Appliances - Others
Jamie oliver Tefal 6L Clipso: The lid does not fit and the mechanism for the lid is not functioning any more. Any help before i have to buy a new one?
If they are that good? l would buy another brand.
But you could google it and phone or mail them telling
how disappointed you are.Never know might get new
anyway.
LUCK
Jul 30, 2014 | Home
How often do I need to change the rubber gasket on my pressure cooker?
That really depends on how often you use your pressure cooker and what kind of foods you cook in it. You might start to notice steam escaping between the lid and the pan after a while. You can try stretching the rubber and making sure it's sealed properly and cleaning the valve etc. If after you've done all that it still is leaking steam, it's a sign you probably need a new rubber gasket.
Feb 14, 2013 | Home
I can't get my 17quart pressure cooker to seal. I was looking for an online manuel so i could find out why.
Take the rubber ring out of the lid.
Wash it with warm soapy water.
Dry it.
Oil it with vegetable oil.
Now do you see how the rubber ring has a groove around it on the inside? Push your thumb into the groove and work it around the ring, you're trying to spread the rubber V out.
Put it back in the lid and take it for a test run.
In the future store your cooker with the lid upside down on top, keeping it closed will ruin the seal.
If it still won't seal replace the rubber parts, you can get a kit for your cooker from presto.
Regards
TickMagnet.
Aug 08, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
I can not open my pressure cooker,the lock is still on and all of the steam is out. What can I do to get it open?
Problem is probably that the rubber seal is old and swollen. It will probably take brute force to open the lid. What is the brand name of the cooker? If it's an old Presto or Mirro, it probably has two handles, upper and lower. You may need a person with more strength to force it open.
Once you have it open, do NOT reuse this seal. New ones can be ordered on line at various sites. Do a search on "Pressure Cooker repair parts".
Nov 24, 2009 | Manttra 8QT Stainless Steel Pressure...
Need a new rubber seal for the lid of my pressure cooker 6qt
Need to have new rubber installed on my pressure cooker lid, but cannot find anyone to do it. Presto says they do not do the labor but will send me the rubber???? Any suggestions?
Nov 10, 2009 | Wolfgang Puck Electric Pressure Cooker...
Deck Monitoring DECK CM5YE111 All-in-One Solar Monitoring Package - UL Listed - 5 Logo
326 people viewed this question
Top Deck Monitoring Home Experts
Donni Steen
Tom Chichester
Are you a Deck Monitoring Home Expert? Answer questions, earn points and help others
