Question about Toshiba 65H84 65" Rear Projection HDTV
I have verticle lines in the image more pronounced on left of screen also multiple line reflections on moving objects.
Switched to convergence screen no vertical lines - tried to switch to HDMI got momentary image then green screen -
  • 18 Answers
SOURCE: Green Convergence problem
O.K. This is a CRT Projection TV see http://www.tacp.toshiba.com/televisions/product.asp?model=50H82 The Manual is available from http://www.tacp.toshiba.com/tacpassets-images/models/50H82/docs/50H82_om_e.pdf , and this describes the Manual Convergence process, I doubt this will help, but it's step #1. The problem you are describing sound to me like a deflection problem. The electron beam in the green projection 'tube' (a super bright CRT) is probably not being controlled correctly. This can be caused by several things, from least likely to most :) I do not recommend that someone untrained in electronics attempt to service a CRT based television due to the potential for extreme shock or electrocution. That caveat said, here are the possibilities. #1 Physical Trauma: The TV has been shifted moved or bumped hard, and one or more of the fixed permanent magnets used to help convergence has come loose, or the CRT projection tube was damaged. I don't think these TVs use convergence magnets anymore, but it's possible. The green CRT tube failing would be more likely if all four corners were affected, but I've seen a failing CRT affect a single corner/edge before. I believe that this model has projection tubes that are separate from the colored filters, so swapping the tubes around may be possible. I do not have a service manual for this set, and this may be a hazardous operation due to high voltages. #2 Stray magnetic field: Someone dropped a magnet into the TV, and it landed close enough to the green tube to effect it only, or perhaps some other piece of equipment is effecting JUST the Green CRT (clock radio, speaker, badly designed wall wart, etc.). Removing the offending magnetic field may cure the problem. Perhaps the offending magnetic field has been removed, but it's presence is still felt. Try using the degauss function built into the TV set (I can't find one in the manual, but it may be present). You may want to try using a degaussing coil, and see if that helps the problem. Just be careful not to get the coil too close to the base of the projector tubes. #3 Deflection drive electronics: A CRT works by using an electron beam to excite fluorescent compounds on the face of the CRT. To move the electron beam about, a process called deflection is employed. Magnetic coils (the choke) are used to steer the electron beam up, down, left or right. These coils are driven by transistors, and as one fails, you will get an image that starts collapsing in the affected section. On a standard CRT TV, that would mean the entire image is affected, but a CRT projection display uses separate red, green, and blue CRT projection tubes to build the image, so you have three times the deflection, three times the possible transistor failures, and in your case, the odd result of just the green part of the image displaying incorrectly. This problem will probably require a service call, and a electronic board swap, but the problem could be the choke (the magnetic coils) on the green CRT projection tube. Swapping the green tube for another tube could prove if it's the tube or if the deflection electronics that are going out. Again, my feeling is that this is a deflection issue requiring a board swap (I doubt anyone actually does component level repair anymore) Sorry, I don't have a better answer, peace. Paul.
Posted on Jan 13, 2007
MikeNJ1964
  • 398 Answers
SOURCE: 43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
Posted on Jul 15, 2007
  • 111 Answers
SOURCE: slight convergence problem after changing convergence circuits
My experience has been that the resistors have fallen out of range. These aren't expensive and neither are the caps that surround this area. If you're pulling the board out to change the resistors, might as well change the caps, too. If you're strapped for cash, but have a multi-meter, you can test the caps and the resistors after they've been taken out of circuit to save a little green. Let me know if you need any help testing them; I'd be glad to help.
Posted on May 22, 2009
SD Tech
  • 14553 Answers
SOURCE: I have vertical lines on my screen. They appear to
This a common problem in many of the Toshiba sets----set has a "HYPER" circuit board that processes all the signal for the set--surface mounted caps all start to dry out--always starts out where it will have the problem and then when on for a while it gets better and goes away--eventually when enough of the caps are gone--it never gets better.
Board is now only available by removing it and sending it out for rebuild/repair---company doining this is Pts electronics--part number is:
23148103Cost is about 180 dollars plus shipping and this may mean considering the labor to get the board out that the set is not worth repairing.
Sorry to give you bad news but I am certain this is what your trouble is.
I do this here for free so if this information helped you to decide what to do--take a minute and give me a vote here.
If you have questions or need advice reply to this posting here.
SD TECH
Posted on Sep 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Posted on Dec 02, 2009
Testimonial: "Thanks! I'll give it a try!"
Verticle lines/streaks down screen
The Display panel could be bad/damaged or the main board that controls every thing could be bad---parts for Dell equipment are known to be hard and sometimes impossible to find.
Dec 07, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
How i adjust horizontal size and vertical size
To answer your concern, all you have to do is to change the setting of your aspect ratio on your TV.
Here is my suggested way to procede:
1. Apply 1080i signal, which should produce an oversized HD image on ColorStream1or 2.
2. Select an HD channel that is broadcasting standard 4:3 image, not wide screen.
3. Switch to the Service Mode ( Please refer to the above links). In the Service mode, press channel up/down to find the Adjustment parameters needed for the following steps.
4. Adjust HIT with volume up/down control for the image height to 22.5 inches.
6. Adjust WID for image width of 30 inches, (22.5*4/3)
7. Adjust HPOS to center the image.
8. Adjust PARA and TRAP to minimize geometric distortion.
9. Switch into Convergence mode and Adjust VLIN to get equally spaced horizontal grid lines.
10. Measure the length of the central grid lines and note the number of horizontal and vertical grid lines. This information is used to create an overlay grid.
11. Create the overlay grid on 40x25 x0.003 inch clear Acetate sheet, which you can get at the Art Supply store for under $2. Draw the grid with a fine line erasable pen. Draw vertical and horizontal lines through the center of the sheet so that the lengths are the same as the central grid lines. Now draw the grid so that it has the same number of lines as the convergence grid but are equally spaced, with the outer ones at the ends of the central lines.
12. Cut off about 1/4 inch from the right side of the sheet so that the sheet can lay flat against the screen, which is slightly less than 40 inches.
13. Put a reference mark on the TV frame 2.5 inches down from the upper left side of the screen.
14. Place the overlay on the screen so that the upper edge lines up with the reference mark. The overlay sticks by electrostatic attraction.
15. Use convergence controls to remove grid distortion and converge grid colors. Refer to the Anamorphic link for details.
16. Enjoy 1080i.
Other Comments:
I didn't realize I could create the overlay grid before placing the Acetate sheet on the TV screen, until I finished drawing the grid with the sheet placed on the screen. I added grid lines as called for in the procedure. I'm sure this method took much longer no only to draw the lines but some of them were difficult to see.
Part way through the convergence procedure, I became concerned that the image width was off since I did my screen adjustment with wide screen image. Thus, I decided to repeat that step with a 4:3 screen.
I confirmed the need to press 7 often to save results since after I adjusted one grid color without it, I accidentally hit a key that switched me out of convergence mode and when I switched back, all settings were gone.
Another mistake I made was not realizing that the cursor color determines which grid gets moved.
May 13, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
The left side of the picture is distorted with a double image. The right side is fine. As things such as the stock symbols on CNBC scroll across from right to left on the screen, they start out looking...
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
Jan 12, 2011 | Hitachi 51GWX20B 51" Rear Projection...
The picture has ghost images, not lining up
This sounds like a convergence problem. Use the menu functions to reset your set's convergence. If this is not enough, you may need to replace the convergence board.
Feb 17, 2010 | Toshiba 57H82 57" Rear Projection...
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Double Image Red and Green
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Have a sony kf-50xbr800 rear projection tv. Has red line definition on many object but particulary on long or far shots. Tried the service menu recommendations d-gm tg v pos and it didn't correct the...
Hi...
I would try the Convergence setup in the service menu ( IF they allow you to do that)
If the internal convergence isnt enough you might have to have the convergence amps replaced
Jan 02, 2009 | Televison & Video
Convergence
You need sevice code to enter convergence.
Mar 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Verticle lines
I am woundering if the repair folks did the proper job and used the right IC's as alot of NON authorized shops will use the cheap aftermarket repalcement ICs and not even use any new heat sink compound. 4 repairs in 5 years is very excessive! I would not have called the same shop(s) to do the repairs. Put on the test scren on the TV set and see if the convergence is off. If it is make the shop replace them again for free or ask for your money back. Man what a rippoff that is. Good Luck and keep us informed of your progress with the shop and the repair.
Mar 26, 2007 | JVC AV-48WP30 48" Rear Projection...
Toshiba 65H84 65" Rear Projection HDTV Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
