Question about Poulan Garden
I have a poulan pp125 e and I'm trying to remove the housing to check the pull rope assembly I took all the screws out but the yellow and black housing won't budge what's left to do ?
  • Poulan Master
  • 1,169 Answers
Did you remove clutch assembly?
Posted on Apr 01, 2015
3 Suggested Answers
bbreton
  • 437 Answers
SOURCE: Need to change pull rope on Poulan Pro Weedeater
sounds like you are trying to remove the drum assembly; try a torx driver or a phillips screwdriver. There is a srew that hold that drum on and the bolt is in that black hole.
Posted on Sep 29, 2009
Testimonial: "read suggetions & took another look. Found a small flat blade screw driver would work. Appreciate the help"
  • 3 Answers
SOURCE: Trying to fix my poulan 446t rope return. I have
how to remove the starter pull cord on a palen 100 weed wacker
Posted on Jun 27, 2011
Helllo, I need your help with my trimmer...are you familiar with the poulan pro pp125...I need to change the muffler, but can't get to one of the screws because the housing is in the way...I took all...
You need to remove the starter cover, to do this you need to remove the 3 screws holding the tube housing on, pull the housing and tube to one side , be carful not to stretch the throttle cable, behind here is the clutc, remove the securing nut and pull the clutch off, once of the starter housing will come away allowing acess to the muffler screws. When you re assemble do not forget the big washer behind the clutch, also make sure the clutc nut is tight as this also holds the flywheel on.
Jun 08, 2011 | Garden
My wiper sniper pull cord is broken, how do u change the pull cord?
Hi vanzedo, I will try to help you out. Because you don't specify the brand and model I will try to give you the Weed Eater brand that is manufactured by Poulan because it is the best known in my area and I hope it is well known in your area, but it is pretty well the same procedure for other brands.
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eye wear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation. Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to you even if a little bit. Regards and good luck. Denis.
Apr 02, 2011 | Garden
How to change the pull cord?
Hi b calm,
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eyewear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation . Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to even if a little bit. Regards and good luck.
Mar 07, 2011 | Ryobi Garden
Im trying to change the primer bulb on a ppb200e
They usually just snap in place if they are a remote type bulb (on the side of the intake housing) and if it is a carburetor mounted bulb, removal of a couple of screws usually does the trick. I would try and press the old bulb assembly out of its housing (from back (where nipples are)pushing towards the front (where the bulb itself is). Careful, not to crack the housing around where the bulb assembly is snapped in.
Nov 14, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Weedeater pull cord won't pull out on a leaf blower
Suggest to remove recoil housing/assembly and try to rotate the flywheel. Remove the spark plug & check for a silver or aluminum color or coating.
If the flywheel will not turn by hand, the piston/cylinder is seezed. No further repair is affordable.
If the flywheel turns by hand and the spark plug is a dark brown color, then focus your attention to the recoil assembly to see if rope is bound or wound around the rope rotor.
Nov 10, 2009 | Poulan Garden
Hi, I have a Poulan gas blower, the rope will not pull out
remove spark plug for inspection
1) silver or aluminum color
STOP the piston is seezed. TOO costly to repair
2) plug dark brown or black (pretty much normal)
remove recoil housing for tangled rope or broken rope rotor
Nov 08, 2009 | Poulan Garden
Sep 29, 2009 | Poulan Garden
How do you change pull rope on Poulan pole trimmer pp446? I can't find parts mnaual.
Hello theframptons:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog Poulan/Weed Eater.
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan pro elec blower/vacuum
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Sep 06, 2008 | Poulan 12a Elec Blower/Vacuum
Garden Logo
111 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
