Question about Dryers
What is the difference in the 600,1500 & 900? Which one should i have it on for most heat to be put out?
  • 2,039 Answers
Your taking 600 watt 900 w 1500w the more watt the higher the temp
Posted on Mar 29, 2015
Ok i have a new conex 3300 in a box never used now im try the radio and go over heat and reseive put no trams
first of all ,remove what you put into it and install the original parts back into it. Now see if it still heats up.If it does what is it thats heating up? Check it out,maybe install a different transistor with higher voltage to keep heat down.Could be a transformer in there heating up .Do the logical first then procede to the next step.
Jan 26, 2013 | Connex 3300 240-Channels Base CB Radio
I'm thinking of buying a heated cat bed for my cat, are there different types?
There arelots of different types of heated cat beds. I\'ve seen lots of different shapes,colors, materials etc. You can even personalize your cat bed.
Jul 23, 2012 | Cats
OD model#, CKL36- 1F and the indoor model#, AR36-1. The indoor does not have the electric heat strip in it but has the place for it. I want to convert it to a heat pump. Is it a 3 ton system? How many KW...
You can use the existing air handler for a heat pump condenser unit up to 3 tons. The line set, evap coil are fine for a heat pump.
The electric heat strip issue can be another problem, you can put several different size strips in depending on what may be needed where you live, the power requirements will differ with each heat strip, for example a 5KW (5000 watt) heat strip requires a 2 pole 30 amp circuit for heat strip and air handler combination.
Aug 22, 2011 | Goodman CKL36AR36 Air Conditioner
My amana dryer wont put out heat. I've taken the heating element off but it doesnt look broken anywhere. I changed the fuse on the element 2 months ago because it wasn't putting out heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 21, 2010 | Kenmore 62602 Electric Dryer
The difference between the flame bowl and water bowl
You want the wood chips above the heat source and then the liquid above that. The heat source smolders the wood whilst the liquid keeps the meat moist. Remember you want a very low heat.
Dec 31, 2009 | Masterbuilt 20050106 Propane Smoker
Dryer got very hot when shut off,wouldn't heat up when running.
We took apart the dryer. the heating coil was broken in two. When the dryer was stopped it was not in off mode therefore the electricity was going through and the ends off the coil where it was broken was touching the metal and eating the dryer which made it hot to touch. We tested the 3 different fuses? the ohms were good. Ordered the part waiting to put it back together to be sure. Rule to remember even when dryer is stopped it should always be put in off mode.
Jun 02, 2009 | Frigidaire FSE748GF Dryer
Where & how to get to heating element
different for different dryers but follow the guideline of"first unscrewed last to be put back and lay parts out in that order"hope this helps
May 27, 2009 | Dryers
Engry problem
HI
Its true you are using power to heat the water....
BUT
all the time its heating through different temperatures, different stains are removed. Also its agitating for all this time. If you put hot water in only it wont wash as long. Also the incoming temperature could be too hot for some fabrics. Also you wil be using your hot water to do all the rinses.
Its up to you, but, zanussi know what they are doing
Feb 17, 2009 | Zanussi IZ12 Front Load Washer
Heat strips not heating
Check your sequencers on your elements. If you don't have the equipment, then all you can do is check your filters and ensure they are clean. Also see if you can set the heat pump at a lower temp, you can do this at the defrost board, the therm or sensor. Get (the heat pump) to heat the house more than the electric before you have a tech come and diagnose your problem.
Dec 07, 2008 | Amana PTH123B25AJ Heat Pump Air...
Intermittent heat
It sounds like the unit has lost its first stage of Heat (It uses the outside unit to bring heat in with freon) When the thermostat is put 3deg higher than room temp it uses Heat Pump and heat strips, this is probably the only time yours heats. Have it checked as you will pay a lot on next month's electric bill.
Jan 19, 2008 | Heating & Cooling
Dryers Logo
48 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
