Question about Miscellaneous
Why is my 2009 chevy aveo overheating?
I replaced the bottom radiator hose because there was a tear, but still overheated, then the top radiator hose came off and got a new clasp to put on but still overheats. I already added anti freeze 50/50
  • D. E. Hev Mar 29, 2015
    If radiator fan is coming on ,is radiator getting hot or just the engine, if just the engine then your thermostat is probably sticking
  • Anonymous Mar 29, 2015
    the a/c doesnt turn on until about 30 min after the car is on...so that could be the problem?
  • 2,039 Answers
If all the air is off inside the coolant you might a blow head gasket compression leak in the cooland chamber the more you drive more pressure in there and the weakest thing will break one after the other i would start to change the thermostat you said the fan start the air that the fan blow is it warm if its cold you dont have a good circulation so bad thermostat if its warm look like a head gasket job
Posted on Mar 29, 2015
    Genius:
  • 1,168 Answers
Is the radiator fan coming on ? If not vehicle will overheat
Testimonial: "yes the radiator fan turns on."
    the radiator fan does turn on ... but about 10 min after driving it , it overheats
Overheating 97 Lincon Town car
Connie, Were the radiator,water pump and thermostat replaced to try and fix the over heat issue or as maintenance. Engine overheating can be caused by a lot of things, Leak in cooling system, air in system, bad rad. cap, slipping belt, faulty thermostat or installed upside down, faulty water pump, plugged radiator (inside/outside), collapsing rad hose, faulty cooling fan, leaking head gasket, sludge plugging engine water passages, poorly tuned engine, etc..
Take into a good shop for diagnoses and estimate for repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Troubleshoot an Overheating Engine
Steve Litt Overheating Guide
Diagnose Engine Overheating Auto Repair Help
How to Troubleshoot an Overheating Engine DoItYourself com
Jul 21, 2016 | Cars & Trucks
Not cooling,has new impeller and thermostate
Steve, there's many causes of overheating. You say you have a new water pump and thermostat, so it's obviously not those at fault.
Just a question ... you say your car is not cooling, but is it actually overheating? A faulty temperature sender unit (it screws into the engine block, usually..) can give an incorrect reading on your gauge.
If it is overheating - steam/you can feel the excess heat - is your radiator fan kicking in? Is your car overheating as soon as you drive it? Or overheating when stuck in traffic .. and the fan isn't kicking in..?
Other things that cause overheating which spring to mind include a blocked radiator and/or a collapsed radiator hose.
Hot coolant enters your radiator via the TOP hose and cools as it goes down the radiator, then back into the engine via the bottom hose. Check both top and bottom hose after the engine has warmed - sometimes a hose can become 'flat' and blocked.
Another thing that causes overheating is a burnt head gasket/cylinder head problem.
Switch the engine on and look at your coolant bottle - a continuous 'bubbling' indicates that exhaust gases are finding their way (via a burnt head gasket) into the cooling system.
Any oil in the coolant bottle also indicates cylinder head problems. Also check the oil dipstick. If coolant (because of a defective head gasket/head) has found its way into the oil system the oil on your dipstick may appear a creamy/greyish sludge.
May 21, 2016 | Cars & Trucks
My VW POLO 1.6 clasic keeps overheating I have removed the thermostat no improvement I have replaced the thermostat top rad pipe hot bottom rad hose cold water not circulation replaced radiator still no...
Have you changed the water pump - if not, that could be it. Typically cold lower hoses imply water pump impeller not turning.
That would definitely be my next move.
Hope this helps and thanks for using Fixya!!
Nov 28, 2013 | 2000-08 Volkswagen Polo 9w Muranorot Pearl...
1998 Chevy Lumina 3.1 overheating - top radiator hose collapses on throttle, then opens up when you let off.
With the engine cold remove the radiator cap. Start the engine. Watch the coolant. If you see bubbles constantly perkulating out of the coolant than you most likely have a head gasket that has failed. If you don't see a constant perkulation of air bubbles it probably wouldn't hurt to replace the upper hose and see if the problem is resolved.
Jan 13, 2012 | Chevrolet Lumina Cars & Trucks
2006 CHEVY COBALT OVERHEATING HAS NEW RADIATOR WATER PUMP AND THERMOSTAT
That is normal, it will not get hot without the thermostat. The water cools in the radiator and falls to the bottom and the bottom hose is cold. This is what cools the engine and stops it from overheating.
Oct 26, 2011 | Cars & Trucks
Overheating
CAR OVERHEATING FIRST CHECK FOR LOW COOLANT IN THE RADIATOR COOLANT OVERFLOW JUG.IF COOLANT LEVEL IN OVERFLOW JUG LOW REFILL ADD COOLANT BACK TO THE FULL COLD MARK.PUT RADAITOR CAP ON COOLANT OVERFLOW JUG START ENGINE LET IT IDLE UNTIL IT OPERATING TEMPERATURE.MAKE SURE TOP RADIATOR HOSE GETTING HOT WHILE ENGINE WARM UP.IF TOP RADIATOR HOSE DONT GET HOT WHILE ENGINE IDLING YOUR THERMOSTAT COULD BE STUCK CLOSE CAUSING CAR TO OVERHEAT.IF TOP HOSE IS GETTING HOT.CHECK FOR COOLANT LEAKS CHECK TOP RADIATOR HOSE AND BOTTOM RADIATOR HOSE FOR LEAKS.CHECK FOR LEAKS AT THE RADIATOR CORES AND PLASTIC SIDE CONTAINERS.IF ALL IS GOOD ENGINE OVERHEATING WHILE IN A LONG TRAFFIC LINE, COOLANT FANS NOT COMING ON.COULD HAVE FAULTY ENGINE COOLANT TEMPERATURE SENSOR OR BLOWN COOLING FAN FUSE OR RELAY.COULD HAVE PCM FAULT.MAKE COOLING FAN ELECTRICAL CONNECTORS AND WIRING NOT DAMAGE OR BROKEN.
Jul 17, 2011 | 1999 Oldsmobile Alero
I have a 07 chevy aveo ls 5 with a 1.6 ltr engine and it's automatic trans so here's my problem my wife was driving home from work and the car overheated and shut off when i got there i found that the...
Check for power to the fan and for a good ground. If those are both present then you would need a fan. If your old fan rubbed a hole in your radiator then I would definately check to see if the fan has play in it that would case it to hit the radiator.
Dec 25, 2010 | 2006 Chevrolet Aveo
Car overheating, coolant in resevoir cold, radiator top hose boiling hot. overheating problem comes and goes. 1999 VW passat
Check that your electric radiator fan is working. When the car is hot and idling it should come on.
Replace your therostat. I had a Chevy Citation that the thermostat would start to open and then close instead of opening all the way.
Mar 21, 2010 | 1997 Volkswagen Jetta
Hi Honda crv (98) R overheating.
SOUNDS LIKE YOUR THERMOSTAT IS STICKING,REPLACE THERMOSTAT FIRST OVERHEATING WILL DAMAGE ENGINE.IF THAT DOSEN'T WORK HAVE WATER PUMP CHECKED.FANS WON'T TURN ON IF HEAT FROM ENGINE IS NOT FLOWING INTO RAD BECAUSE THEROMOSTAT STUCK CLOSED,OR WATER PUMP FAILING
Jan 28, 2010 | 1998 Honda CR-V
Miscellaneous Logo
106 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
