Question about Superex Canada Ltd Emergency Jumpstart Mobile Power Supply Rechargeable
How do I get a charging plug (one that plugs into a wall) for this unit?
  • Karla Boone
    Karla Boone Mar 30, 2015
    I threw it out, by mistake!.
How do I charge my Motomaster Mobile Power Pack Model 11-1540-2?
It should have a small 120V to DC wall adapter charger with a DC wire / connector jack that plugs into the back of the power pack. Plug the wall adapter into 120V outlet and plug the DC connector jack into the back of the Power Pack. Leave on charge until the unit indicates it is charged fully (several Hours if it was fully discharged).
Nov 20, 2016 | Electronics - Others
I have AT&T cordless phones (4). All of a sudden, they all say "no line". Please help
Dianne:
The phone cradle that is plugged into the telephone line coming from the outside of the house is having problems. Check the wall plug where you plug the phone charger into the wall (not the power plug... the telephone wire plug) check to see that both ends of that wire are plugged in properly... One plug goes into the wall, and the other plugs into the charging unit.
Oct 01, 2015 | AT&T E5865 5.8GH Cordless Phone with...
MY GPS MAGELLAN IS SHOWING LOW BATTRIE, WHAT DO I DO TO FIX IT.
You should have received either an AC adapter or a USB cable with the unit to use for recharging your battery. The AC adapter would just plug into the wall socket and then into your unit. The USB cable would be connected to your computer while it was running and then the other end would fit the GPS. This will also charge your unit. If you do not have either of these cables you should be able to go to your local Best Buy, Circuit City, or even a Walmart, and you will be able to purchase at least a USB cable that will charge your unit. There are adapters out now that will plug into the wall and then plug into the USB port on the GPS for charging purposes.
May 15, 2011 | GPS
Won't turn on.
if you still have an issue with this, ill be glad to help you..just reply to this post ..(see my feedback)
YOU CAN NOT CHARGE A MAGELLAN 4040 WITH A USB CABLE!
if the green light is on, on your car charger, the charger is working..if its on (the green light) and still wont start after holding the power button for up to ten seconds, let me know and i will help you further.
May 06, 2010 | Magellan Maestro 4040 GPS Receiver
My garmin 765 T won't turn on- I have charged it overnight
If you are charging your unit with the USB cable STOP - use only a wall plug. The unit will not charge using the USB cable. If you don't have the wall unit - try charging it with the car plug charger for 15 minutes. Just let the car charge it running or not. You will see it work. Once it is charge over half way - the rest will charge up. It is a problem Gamin is working on.
May 05, 2010 | Garmin nuvi 765T GPS Receiver
Craig, portabale, dvd player has been lying around for months. When I plug it in I have no power. Do I need to let the, internal, battery charge even if the unit is plugged into the wall?
Yes,u must let the litium battery fully charge,if u want to use the DVD player as a potable player.Without plug in the power outlet from the wall.
Feb 27, 2010 | Televison & Video
Need to know how to charge garmin nuvi 255w using home wall charger.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Jun 26, 2009 | Garmin nuvi 255W GPS Receiver
Battery will not take charge from wall unit
Remove the battery for several minutes, replace the battery and plug the wall socket in, leave it for several hours. The battery is probably too dead to do anything, and recharges very slowly. If this doesn't work, try a replacement battery, before you send the unit in for repairs.
Jun 15, 2008 | Garmin zumo 550 GPS Receiver
Superex Canada Ltd Emergency Jumpstart Mobile Power Supply Rechargeable Logo
300 people viewed this question
Top Superex Canada Ltd Computers & Internet Experts
David Payne
David Payne
Are you a Superex Canada Ltd Computer and Internet Expert? Answer questions, earn points and help others
